Question about Kenwood KDC-MP338 Car CD Player
No sound. new install.replaced hole in dash.existing wire harness did not match new plug.i spliced wire color for wire color with 1 difference.kenwood harness wire color,blue/white (power control/motor antenna wire) i spliced to unknown blue/white wire on old harness.radio lights up and when in tuner mode shows stereo light w/no sound.does the same when playing cd.
  • itshimself Oct 24, 2008
    whats a simple way to check wiring to speakers?can i do it with a multimeter?WHAT settings to use?
    excellent diagnosis!the speaker ground wires were the culprits.they were refastened with fresh soldered terminals and i now have the pleasure of mozart in my ears.regards to the guru.
  • Kenwood Master
  • 19,396 Answers
The first thing you need to do is doublechecking all the new wirings, it sounds like a contact.
Posted on Oct 24, 2008
  • 2 more comments
  • Ginko
    Ginko Oct 24, 2008
    You need to get the wiring diagrams and check the wirings.
    Check all wirings to speakers first.
    If radio display works and change stations etc, but there is no sound, then it is speaker wirings, check them out.
    If radio is stuck and display on, but does not operate , then is a contact or a bad wiring.
    If the wirings are Ok, then the amp is gone.
  • Ginko
    Ginko Oct 24, 2008
    Depends on what problem you have.
    If the radio operates but there is no sound, check the ground wiring to the speakers.
    If radio does not operates then check power connectors.
    If there is no sound you can connect the radio to a test speaker to ensure that is not faulty.
    If the radio operates, check also settings.
  • Ginko
    Ginko Oct 24, 2008
    If you use a multimeter you can test cable to speakers for continuity, and find out which connects to the speaker.
    If wirings are factory ones, you find complete wiring diagrams in the Haynes manual.
  • Ginko
    Ginko Oct 24, 2008
    Lol, nice!
    Thanks.
How to install a boss bv9982 7 inch single din?
You will need a GM dash kit designed for 2004 Impala (see picture below)...Lower steering...Remove radio...Unplug harness and antenna...Boss wiring matches colors wire for wire in factory plug...Splice one wire at a time to matching color...Plug in antenna...However it is much easier to buy a plug-n-play harness ($25) designed for your vehicle eliminating the need to splice...The Brown wire goes to ground via switch...saailer
4c37a5a7-0e7a-40b3-86da-e0f7039aac1f.jpgCost $15
May 05, 2014 | 2004 Chevrolet Impala
Does any radio work for a 1986 camry?
As in aftermarket like a Sony or Kenwood or..???? Yes.
The easiest way to install one is to get an installation kit. One that has a bracket/face that fills the hole in the dash and the new radio sits in and a wire harness. The harness makes things so simple. You don't need to know what wire color is what. The cars factory harness plugs right in and the new radio wires will be the same color on the harness.
Sep 06, 2011 | 1986 Toyota Camry
How to install Kenwood KAC-1502S into factory 1998 Chevy Z71. I feel like I'm missing a wire.
There are a few things you will need. You will need a wiring harness, dash kit, and instructions. You can get them all at www.crutchfield.com . The wiring harness will make wiring it up a breeze. The harness uses the standardized color code for the wires, but the harness plug is set up to match those wires to the vehicle. All you do is plug it in. The dash kit will have mounts and trim pieces to make your install look good and hold the radio in correct position. The instructions....well that's self explainatory. hope this helps
Aug 29, 2011 | Kenwood Car Audio & Video
I do not know how to wire nenwood kdc-422 to a 94 buick century?
You should have a wire harness pigtail that comes with your kenwood.
you can also purchase a harness adapter plug/pigtail at most audio auto stereo shops to fit your car make and model.
Be sure to save the packaging because the plastic bag has the color/codes for the harness. This harness is designed to plug right into the factory plug inside the dash just like the stock radios do.
All you need to do is splice the kenwood cables to the adapter plug pigtail you purchase for your car.
match up each wire as described here:
1994 Buick Century Car Stereo Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 22, 2010 | Kenwood KDC-422 CD Player
I tried to install a cd player in my late 99 model daewoo lanos but the wires are different can anyone help
I would strongly recommend splicing back in your original stereo plug, and going to your local best buy or any car audio retailer and buying the proper wire harness- this will likely cost you between 5 and 30 dollars, but it will make your installation much easier because the color codes are all already properly matched.
Oct 25, 2009 | Kenwood Car Audio & Video
How to hook up a kdc-105 kenwood in a sunfire
There are 3 things you need to purchase for this install. 1) The factory spec install kit. 2) The factory spec additional wiring harness. 3) Antenna adapter.
Find the easied way to remove the plastic cowling around the radio and ac controls. Usually you can locate screws helping to retain the plastic dash parts. Be careful not to break the plastic dash by taking your time and looking over and over the part ofr connection hardware. Once you have located and removed all/if any screws, carefully pry out on the piece you are removing. There are often metal clips on the back of the piece that also help to retain the dash. Once that is removed, unbolt/unclip the factory stereo and slowly pull it out of the dash. Remove the factory harness from the backside of the factory stereo. DO NOT CUT THE HARNESS!! The wiring harness you have purchased is designed to plug and play into the factory harness. All you hae to do is color match the Kenwoods harness with the one you purchased. When wiring the two harnesses together use connectors **** a **** connectors, crimp connectors so forth and so on. If there is wiring you will not be using, take some electrical tape and tape the bare wire. We don't want a short. Once you are sure and have doubled checked that all the wiring is secure and matched, reverse the order of disassembly.
The plastic install kit should replace the factory radio size difference. Just remember to take the metal sleeve tha came with the kenwood and install it into the plastic install kit via the instructions provided. Slide the Aftermarket stereo into the sleeve you just installed. Then you are ready to make all the needed connections. Before you reassemble everything make sure to do a test run with your stereo. If all is well reassemble and jam on.
Sep 10, 2009 | 1999 Pontiac Sunfire
Trying to hook up last few wires and not sure what they are
Hello jtracer,
Here's a link to the Kenwood manual at Crutchfield.
Here's a link to the color code for the 2000 Dodge Durango.
If you are splicing directly into the vehicle wiring, just match up the wires from your Kenwood to the appropriate vehicle wire by function, not color. If you are using an aftermarket vehicle specific wiring harness, such as the Metra 70-1817, the colors should match up with the Kenwood wires.
Hope this helps.
Aug 31, 2009 | Kenwood Excelon KDC-X789 CD Player
After I pulled the old CD player out of my car the wires end plug dosnt match up to my new Pioneer DEH-11E. Is there a way to make it work or should I take it back.
Hello al_will00,
The color coding of the wires from aftermarket equipment will not match up with vehicle color codes. The new player will work OK when you have matched up the wiring by function. There's 2 ways to do it: 1) Find the color coding of your vehicle wiring and splice/tap into the existing harness; 2) Purchase an aftermarket wiring harness that plug in directly.
The 2nd option is best. It allows you to make all of the connections (usually color for color) sitting at a table or workbench insted of from behind the poorly lighted dash. It also allow you to reinstall the OEM radio if you ever decide to do so. Splicing or tapping will make it more difficult.
I'd visit one of the online retailer like www.crutchfield.com or www.sonicelectronix.com to purchase a wiring harness. You can determine the correct model number from various sources, including the manufacturer, such as Metra here. Just enter your vehicle make, model and year information to see a list that the vehicle.
Hope this helps.
Aug 10, 2009 | Pioneer DEH-1100 CD Player
Pioneer DEH-P3300 and 94 Mazda
Hello ryan_jaime,
It's good that you have an aftermarket Mazda wiring harness. It will allow you to make all of the connections in a well-lighted and comfortable location rather than fumbling around behind the dash.
If you are somewhat skilled at soldering, the most secure, electrically conductive, and positively insulated splices are made with solder and heat-shrink tubing. You can get the needed equipment from any Radio Shack, Lowe's or even WalMart. Be sure to put the heat-shrink tubing on the wires BEFORE you solder them together. I had to say that! Because I've forgotten many times! But if the soldering route is not for you, get properly sized insulated inline crimp splices and the appropriate crimping tool. Match up each wire by function on the Pioneer harness with the corresponding wire on your aftermarket harness. Most of the time, the wires will be color-for-color matched. But make sure, sometimes wires for things like "illumination", "dimmer", "mute", etc may not be the same colors.
Disconnect the negative battery terminal while you are working behind the dash. After you have the harnesses spliced together, plug the radio end into your Pioneer, remove the old radio from the dash opening, unplug the antenna and wiring harness plug and plug the other end of your spliced harnesses into the vehicle plug and the antenna plug into your Pioneer's antenna connector. Slide the Pioneer loosely into the opening, but don't secure it yet. Reconnect the negative battery cable and test the receiver. If everything works, slide it into the dash opening and secure it. Use the rear support stud and rubber bumper if needed. Install the trim ring or separately purchased dash kit as required. Put the "face-fixing" screws in to prevent removal of the faceplate if desired. Reinstall any dash trim removed and you're finished.
Hope this helps.
Jul 08, 2009 | Pioneer DEH-P3000 CD Player
After market cd player to go into holden jackaroo
Best advice, go down to Target or Wal-Mart and purchase a wire harness kit for your vehicle. Splice it to the wires on the deck. If the deck is aftermarket it should be all color matching. Then once that is done all you do it plug it in just like the factory radio did.
May 09, 2009 | Kenwood Car Audio & Video
Kenwood KDC-MP338 Car CD Player Logo
229 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Pablo Gonzalez
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
