Making Memories Slice machine will not turn on
The machine was working fine and has not been used no more than 10 times. I attempted to cut a figure out of thin cardstock with the card in the macine, I tried to turn it on. It made a beeping sound that slowly died away and I have not been able to start the machine since!! I have left it plugged in to charge overnight, no response. I have left it hooked to the power cords, no response, I don't know what to do! The machine is just over a year old :(
  • 33 Answers
SOURCE: HELP!
i have the same onebut fridgeair but mine would only wash and nothing else and it turned out to be the motor was weak
Posted on Jul 13, 2008
SOURCE: Bosch WFL 2872 washing machine
A similar thing happened to mine. I think it starts when there is a power cut or something similar mid cycle. The solution (which you would never guess!) is the following:
Select any programme - say 30 Cottons
Press and hold any function button - NOT Start Signal will sound at varying levels - release button when it gets to the level that you want, off in your case. De-select programme Good luck!
Posted on Aug 28, 2008
SOURCE: HELP!
I have a kenmore front load washing machine 44052 that is 2 years old. It has stopped working. Call repairman he said 800 to fix. Need a new tub. What I found out after taking apart myself is the inside is loaded with mold, Bearings are faulty and the spyder rack in back is made of aluminum that will corrode. I am trying to start a recall on this machine for faulty bearings, spyder rack and mold.
Posted on Sep 17, 2008
gittos73
  • 244 Answers
SOURCE: zanussi Turbodry 1200 spin problem
if this washer is used alot then it will more then likely be the carbon brushes which u will need to take the lid off undue 4screws out where it joins front to the back screws at the back to the bottom and 1screw either side of the bottom where the panels join together behind a little cap which will have an hole in the middle of it to get it out u will then be able to get to the motor to replace the carbon brushes
Posted on Nov 25, 2008
SparkyNZ
  • 43 Answers
SOURCE: Candy Eclipse washing machine blows the circuit breaker
It's possible that the current rating of the MCB is too low to run your washing machine PLUS all the devices plugged into the other sockets on the same circuit. If possible, try plugging in the washing machine on a circuit with fewer or no other appliances plugged in. MCB's are much faster tripping than circuit breakers and are rated to trip at the current rating on them. Circuit breakers, may carry a current slightly over the rated current which may be why it never happened before. The permanent solutions (if the overloaded circuit is the problem) would be to install a circuit solely for the washer and dryer or install a MCB with a higher current rating. The latter solution is not practical, however, since an overload on lower power devices may never reach the current rating of the MCB creating a hazardous shock potential.
Posted on May 11, 2009
Slice machine wont home in proper position
The same thing happened with mine so I changed the blade and it worked.
Aug 13, 2013 | Making Memories Slice Die-Cut Machine...
Making memories Slice machine starting point and ending point not the same
This is making memories's blog:
http://www.makingmemories.typepad.com/
I think that its best if you send them your quetion
Apr 15, 2013 | Memory Lane Making Memories Slice Hands...
Bobbin case knocking on stylist 7258
Sounds like the timing is off, bribean01. I just fixed mine. It wasn't hard, but taking the machine apart, finding the right screws to loosen, set the timing and figure out how to put it all back together again was not easy. It's been days of work. I took it apart three times. I have an extra screw left over (you know that's not good). Singer did not make this easy to fix. There is a complicated metal casing around the parts you would be attempting to reach from one angle while needing to have a grip from another. Several sets of eyes would be helpful, too-if only!. It will require english and metric allen wrenches several screwdrivers pivotable lighting...My point is- you can do it, but in retrospect, it probably would have been better to spend $125 to let someone else to do it- someone who can then be blamed. When my machine jammed I also broke a tiny piece off the rim of the bobbin case. I was hoping it wouldn't matter, but it catches the thread, so...i'll order the $15 part and use the time to consider how badly I need to take apart the machine again to find the hole that is missing a screw. Good luck Gals!
Jul 19, 2012 | Sewing Machines
How do I reduce my clipper's rattling noise and still be able to cut properly?
The power screw is the correct way to adjust the problem you describe. If you have attempted to adjust it as instructed in the user manual and have not had satisfactory results, there may be a problem with the clippers.
Most Wahl clippers have a 1 year or longer warranty. You can call Wahl for warranty service at 1-800-334-4627
Nov 12, 2011 | Health & Beauty
Not toasting at all. Worked on 4 slices the nothing,
Rotate the dial all the way one then the other a few times. Maybe something behing it. It this is helpful, please post as such.
Jan 10, 2009 | Dualit CTS4E 4-Slice Toaster
About adobe photo shop
298ead6.jpgPhotoshop has many kinds of tool to make copy (or cut) and paste, such as magic wand, pen, lasoo, etc. For simple cut & paste, use the simple selection tool, see my picture the left arrow. Click on it then make the selection on the picture you want to copy/cut. Then click copy (or cut) and put your cursor in the place you want to paste --> click paste.
Slice tool is more for making webpage, not for cut and paste.
For detail, you can click "help" menu in the Photoshop.
Mar 24, 2008 | Adobe Photoshop 7.0 for PC
Upper Thread Error
I just posted this under another Brother machine...mine is a se 350 but, might be the same problem!! Hi....I also kept getting the check and rethread upper thread message, I'd sew about 15 stitches and it'd stop. Here's what I did. On the left of the machine, in the back there is a screw....loosen that screw, take cover off, then lift straigt up and out on the cover that has the 3 on it in your threading seqence. Next, I started inspecting and cleaning the thread route from top to bottom. Lo and behold....I get to the place where you come down the front of the machine and turn to go back up and I spot a little slice/cut in the plastic piece so, when I was threading the machine I guess I was pulling it to far to the left causing it to wear a little slice/cut in that piece....so, I finished cutting it off with a utility knife, used an emery board to smooth it down, put the covers back on and it works GREAT!!!! Who would've ever thought that it'd be so easy and save me a bunch of money!!! I sure hope this helps someone.
Oct 22, 2007 | Sewing Machines
Washing Machines Logo
274 people viewed this question
Top Washing Machines Experts
