Question about Motorola Mobility FINITI Headset
How to disassemble a motorola finiti bluetooth
My finiti broke apart ( separation be ear piece and the actual bluetooth head set itself
Why does my new motorola finiti hz800 does not charge when plugged in?
Hello Lizbeth,
For better assistance please contact our technical support team
CONTACT US
Regards,
Kenny
Motorola Support
Aug 27, 2015 | Motorola Mobility Finiti Hz800 Hz-800...
Problem with the Motorola Motopure H12 Bluetooth Headset I can't hear anything on my h12 headset. other people can hear me but i can't hear them.
Hi.
I'll really advise you to perform a FDR on the bluetooth. You will need to Press and hold the Call button while turning on the headset to turn on Reset to factory default. Follow the voice prompts to make changes to the settings.
You can find this information on the Link How do reset my FINITI to factory default
Hope it helps.
Marge
Motorola Mobility.
Aug 06, 2014 | Motorola Mobility Motopure H12 Bluetooth...
How do i connect my motorolla hz800 bluetooth to ps3
I think i've figured it out. I have turned the multi-point connection off and then paired the Finiti with my phone and PS3 separately. Just make sure that you have your phone's bluetooth connection or other device turned off before turning on your PS3, and then make the connection between Finiti and PS3 and you should be good. Then when you're done using the PS3, and its powered off, you can turn the phone BT connection back on and you should be good.
Jan 07, 2012 | Motorola Mobility FINITI Headset
I have an older triple head Tycos Stethoscope that has a metal spring-like bridge at the bas of the ear tubes, and which holds the ear tubes separate. This broke near the connection with one of the ear...
If it's less than ten years old, it may be under warrantee. When mine broke, 15 years ago, I had to replace the whole Binaural/Spring Assembly piece- the metal ear tubes and the spring are all one piece.
Major med equip suppliers- Schein, Darby, etc., stock the parts. WA has them, probably for sl more-plus $10 extra charge for orders under $100.
I found them here:
http://www.steeles.com/catalog/Harvey_parts.html
http://www.welchallyn.com/support/service/default.htm
Jun 27, 2009 | Welch Allyn Tycos Harvey Dlx Triple Head...
The thing that holds it on your ear broke off...I need a new one
I had the same problem losing my "ear hook". You can google ear hooks for Motorola H3 or go on ebay to purchase one cheap.
Apr 04, 2009 | Motorola Mobility H3 Bluetooth Headset,...
Broke the ear hook for the Motorola h500 bluetooth headset
I searched on google for motorola h700 and found plenty of sources? Amazon.com and others.
Aug 30, 2008 | Motorola Mobility H700 Wireless Headset
They do not make earhooks alone. You must send it back and they will replace the whole unit.
May 12, 2008 | Motorola Mobility H700 Headset
Bluetooth repair
i have a blue tooth motorola h350 and it just quit working it's under a year old can you get me the 800 number so i can get it replaced
Dec 10, 2007 | T-Mobile 81339TMIN T?•MOBILE BLUETOOTH...
The ear hook on my H500 broke as well.  I called Motorola (866-289-6686) and they are mailing me a replacement.  Even though This bluetooth has a 1-year warranty.  I purchased mine in Jan. 2007 and was covered but the rep didn't verify anything regarding the purchase date so even if you're outside of your warranty, you might still give it a shot.
Sep 14, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility FINITI Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
