Kenmore Ultra Bake Oven reads a code EOF2 . it will not work.
Ours is a Kenmore Ultrabake but it is not a double oven. When pre-heating the oven, it will beep (once I believe) and stop pre-heating. When not pre-heating, it will occasionally beep and stop displaying the time. When either of these occur, it displays EO F2.
you might want to check where the thermometer is located on older models it can be knocked out of position perhaps to close to the roof of the oven which gives false heat reading
that's a bad touch panel or key panel,the number you sent isn't the full model number off of the oven so when you call to order the part you will need that.if you try to fix this yourself make sure the power is off.good luck
Thanks for using FixYa. Error F2-E0 on your oven means that the keypad is shorted and to resolve this issue you'll have to replace the electronic range control/clock(ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.Reconnect power to the range and observe for an hour.If the error code reappear - replace the control board.If not - replace the membrane switch.
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
I found I have this exact problem. Same bake preheat issue: I can bake if I set broil first. However, the oven doesn't work if I press bake first. The control board has already been replaced a couple times over the years. Is this another replacement??
It is a model number 665.95029101
to help diagnose this i need the model number of the appliance
thanks
Phil
kenmore ultra electric oven drawer stopped working
