Question about Roper Dryers
Dryer stopped working in the middle of a load
    Sergeant:
    Champion:
  • 245 Answers
Check your circuit breaker if you tripped it.
Posted on Feb 15, 2012
2 Suggested Answers
ndguy2481
  • 251 Answers
SOURCE: CDE6000W, Crosley dryer stopped working in middle of load
it could just be the motor going out some dryers only last 6-8 yrs some dryers continue to be quite even if there going out i suggest call a repair preson to see if repairing it is worth it
Here To Help
Shaun
Posted on Nov 17, 2008
My dryer just stopped running in the middle of a load and will not turn back on. Is there a reset button?
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 06, 2011 | Dryers
I have a Kenmore 400 series top loading electric dryer that just stopped working right in the middle of a load of clothes. It was working just fine and then it just stopped. Now it will not turn on at...
Hi there....this sounds to be like you blew the breaker. Go to your breaker panel in your house and search out the fuse for the dryer. This will be a double 110 volt breaker. You need to reset both sides to be sure. It is easily locatable as they almost always have the items listed on the inside of the door of the panel. If this works for you great. Please try to remember to click on the yes box on your way out ...thank you and good luck.
Oct 10, 2010 | Kenmore 73952 Gas Dryer
Here To Help
Shaun
Nov 17, 2008 | Crosley CDE6000 Electric Dryer
Kenmore 90 plus series dryer won't work
Sounds like the belt has broken. You could probably also use new drum support rollers. Check out this site which shows how to change a dryer belt:
http://repair2000.com/wpoolbelt.htm
It's not a difficult job if you're comfortable working with hand tools.
Oct 17, 2008 | Kenmore 62872 Electric Dryer
Intermintent working
How old is this dryer and does it get slower on heavy loads? Or do you hear a hum when loaded ?
Sep 28, 2008 | Whirlpool LER7646E Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Stopped running in middle of cycle
hi thanks for the question when your dryer stopped and you tried to restart if no noise the over load thermostat embedded in motor is suppose to open and not allow it to start then the motor cools down now it works till the motor over heats again and shuts off again. i would vacuum out the inside clean motor and check the venting right to the outside and try it again but remember do this with power off thanks the appliance doc
Aug 31, 2008 | Whirlpool LER5636P Electric Dryer
need the model # from the unit should be where the door closes to the CYE4000AWW is not a Kenmore Model
Jan 21, 2008 | Magic Chef CYE4000AWW Electric Dryer
Electric dryer
Disconnect the power cable, remove dryer's cover and look for a loose wire.
Mar 26, 2007 | Magic Chef CYE4000AWW Electric Dryer
Dryers Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
