Question about Photography
Benbo 1 ball head sticky
Own a Benbo 1 w/ ball head that have not used in years. In good working order I can screw the tripod mount plate into bottom of 35mm camera for instance. The condition its in now I have to do the reverse ..... screw the camera in essence on to tripod head. Is there quick fix lubricant/coating that can be applied to resurrect normal function .... aka .... like the Tinman in the Wizard of Oz? Or am I #@!! --- even though were in a recession have to pack up my ballhead, ship it off to Benbo, and help bail them out too. I pray its the former! bienfang4@yahoo.com
    Problem Solver:
  • 5 Answers
"NeverSeeze" available at most hardware and auto parts stores.  A little (very Little) goes a long way.  Smear a small amount on the ball and start to work it around in its socket. will come out as new with a little effort.
Posted on Nov 03, 2008
Head won't secure to tripod
Two potential issues. 1. Perhaps you have just not screwed it on tight enough. Just tighten the black knob as much as you can then screw the head on your legs as tight as you can. 2. If you can't even do that I will assume that the hole on the bottom of the head is too large for the screw on the tripod legs, in which case you just need a a bushing adapter. Like this one:
http://www.bhphotovideo.com/c/product/882988-REG/Sunwayfoto_tn_15_Bushing_3_8_1_4_Stainless_Steel.html
Apr 10, 2014 | Gitzo Gh2750qr Series 2 Magnesium Off...
D60 error press shutter release button
Here's what I found on the Nikon forum and it also works for D60 Digital Camera.
Get a very small cross head screwdriver (watchmaker size)
A can of WD40
Sticky tape
A good light
Remove the Battery and SD card
Open up the bottom of the D40x putting the small screws onto the sticky tape in order of removal.
You know the camera well, so you know where all the screws go.
Remove the metal plate (used for the tripod mount, you will need to remove the back of the D40x as well, it's only 2 screws)
Now look at John C Ayr's pic of the D40xwww.flickr.com/photos/johncayr/3969534234/
Spray a SMALL amount of WD40 onto the red and white gear wheels.
(Don't use so much that it drips down onto the optics, you don't want oil in there!!!)
Put the battery in and hold it down to make contact, put in the sd card and switch on the camera and try the shutter button. (switch it to manual focus or it might try hunting around for ages for focus)
It might start working, if not move the red wheel a few stops and try again.
Once it's lubed up and the wheels move it should be ok.
Keep taking pics until you feel it is ok.
Then reassemble following the screws backwards on the sticky tape.
Mar 23, 2011 | Nikon D60 Digital Camera with 18-55mm lens
I am looking for advice on how to mount a Ball Head on the plate of a regular tripod, So far I have not found a Ball Head that has the same size thread in the bottom. Is an adapter available as a solution....
The bottom threads on most tripod heafs are 3/8", but some are 1/4"/ The mounting screws on MOST tripods are 3/8", but I have seen `/4" (especially on monopods. IF:
tripod=3/8 head = 1/4 need mounting plate 3/8 female to 1/4 male
tripod = 1/4 head - 1/4 nothing
tripod 3/8 head 3/8 nothing'
tripod 1/4 head = 3/8 there is an adapter/reducer that screws into the 3/8
' female and reduces that to 1/4"
Feb 20, 2011 | Photography
I have a SLIK Single Action Panhead Tripod. How do I mount the camera on the tripod?
it is a quick release plate. there is usually a button or lever to release the plate. you then screw the plate into the bottom of your camera or camcorder and mount the plate back onto the tripod. you can leave the plate on your camera when you store it to allow for faster setup.
Jun 03, 2010 | Slik AF-1100E Trigger Release Ball Head...
Nikon 70-200mm Tripod Mounting Question
There should be a mount that attaches around the barrel of the lens with a flat part that would allow you to screw that to your quick release plate. The flat part usually have several screw holes so you can mount the quick release plate for or aft for better balance. These mounts are removable so it may have been taken off.
Nov 22, 2009 | Nikon 70-200mm f/2.8D VR G-AFS ED-IF Lens
The quick release tab is on the top but there is no plate for a camera to mount on to...guess it's lost. no serial number on the tripod. Brushed aluminum legs and it's got to be about 8 or 9 years old. Can...
Unfortunately not. It's a budget, no-name model with absolutely no back up support so you have no chance of buying a replacement quick release plate. The plates themselves are not standardised and are not only unique to each manufacturer but often not even standard within a single manufacturer's product range.
You'll only get the kind of support you're after from established brands such as Velbon, Slik, Benbo, Manfrotto to name just a few.
If the basic tripod is still solid though you can usually unscrew the head from the tripod and replace it from another one (doesn't usually have to be the same make/model) which has suffered leg damage. To remove the head on most models you tighten the locking screw which prevents the head from panning and then turn the head firmly counter-clockwise. The screw thread which holds the head assembly is usually a universal one.
If you have ALDI or LIDL stores in your country they regularly sell surprisingly good tripods with a no-quibble three year international warranty for around £10. They come complete with a carry bag and spare quick release plate. Neither company has any at the moment but they regularly reappear in their weekly specials listings.
I hope that you've found this posting to be of some help even though it's undoubtedly disappointing news. Please return the favour by rating my answer.
Oct 21, 2009 | AmbiCom V0552 Tripod
Gitzo off centre ball head
Go to big lots or other discount house (I went to sears and spent $4.00) and buy the cheapest mini tripod you can find and scarf the screw/knob off that. That is what I did.
Jun 04, 2008 | Gitzo Photography
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Mar 16, 2008 | Bogen Communication Bogen Manfrotto 3047...
Photography Logo
204 people viewed this question
Top Photography Experts
pontelemon
pontelemon
Tony
Are you a Photography Expert? Answer questions, earn points and help others
