Question about Hoover Vacuums
Hoover hygiene with HEPA manual - Hoover Vacuums
2 Suggested Answers
jmeredith
  • 417 Answers
SOURCE: Hoover hygiene full bag light
hi,
theres other filters that may be dirty and need to be washed or replaced below or around the bag, study the owners manual for alternate filter locations, basically the machine isnt getting the airflow it needs and is letting you know. The hepa filter is the most expensive, try and run the vac without it and see if the light goes out. Its okay to run it without but I suggest vacumming then dusting, not the other way around..
replace it as soon as possible
J
Posted on Jul 11, 2008
How do I clean and with what,a Hoover elite lifetime hepa filter?
Hello! Please follow the instructions below to clean the lifetime Hepa filter on your Elite Rewind.
1. Press on the tab located on the side of the filter cover to remove.
2. Remove the HEPA filter and brush with the combination tool to clean or tap side of filter against a trash receptacle. Return the HEPA filter into the filter cavity.
3. Align tab on filter cover with slot. Press cover closed until you hear a snap.
Hope this was helpful!
Jun 09, 2014 | Hoover U5507900 Elite Rewind Bagless...
Model vc358 hygiene. Where can I purchase a repair manual?
Unfortunately repair manuals are only made available to service centers, they come directly from the factory. Its a way to ensure that the machine is taken to a service center. What seems to be the issue with it?
Jun 16, 2012 | Hoover Vacuums
I don't have a manual. How do I clean/change the hepa filter? I have Hoover windtunnel cyclone model U5780 900l
Greetings,
Please see the below Instruction manual that has instructions on how to maintain your filter. This should help you;
http://www.hoover.com/pdfs/manuals/U5780900.pdf
If this helped, please be sure to rate it as helpful by clicking the four thumbs up icons in the top right hand corner of the repair solution. This is how Fixya rewards their Experts.
Thank you,
Chris J.
Mar 21, 2010 | Vacuums
How do I clean the lifetime hepa filter
Check with the manufacturer. I have always had good response from Hoover.
Sep 23, 2009 | Hoover U5507900 Elite Rewind Bagless...
Clogged hepa filter
If the hepa filter is clogged chances are it is not turning like it is supposed to. Hoover apperantly has a terrible R&D department because this is a bad unit. The filter is supposed to be self cleaning because it spins and a little tab is supposed to knock out dirt but does a crappy job of that. The transmission is what spins the filter and this must be replaced. If in warranty take it to your local Best Buy for service.
Dec 15, 2008 | Hoover U8361-900 WindTunnel 2 Bagless...
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the Hepa filter on this model (*this model uses a vacuum cleaner...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=794479
Generic problem for all Vacuums
Posted by gohornsgo on July 17, 2008
I own a self-propelled Hoover Wind Tunnel vacuum cleaner (Model U6425-920). I do now have an owner's manual and was wondering how to clean the HEPA filter on this model (*this model uses a vacuum cleaner bag also).
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The best way to clean the HEPA filter is to take it outside and use a blower over the trash can and blow off the dust and dirt, or use things like an old paint brush and brush it off, or you can vacuum it off with another canister vacuum or shop vac if you have an extra one. For the best filtration is to replace it, there fore the air flow will catch most of the dust and dirt and then you would have to watch how fast it gets dirty and then do the maintenance.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Hoover hygiene full bag light is on but the bag is empty
hi,
J
Jul 11, 2008 | Hoover Vacuums
My hoover wind tunnel vaccum has a hepa filter that is supposed to be self cleaning but continues to plug up. it is not easy to get to and takes forever to clean it out so the suction is strong again.
do you have the SELF-CLEANING, rotating HEPA filter?
I just fixed my HEPA filter not rotating!!
It involves taking apart the vacuum HEPA area. All screws are the same size. There are a LOT of 'em. Really straightforward putting it back together too.
ok, once you take the HEPA canister area off the vacuum, careful with the wires! Unplug them from the controller board. You open up the HEPA chamber by removing more screws until you see where the motor that turns the filter is mounted on the side. Remove motor from the green chamber. Note where the washer goes. Once the motor is off, you'll see that the center hub that drives the HEPA filter is rounded out. What I did was jam little bits of aluminum from a pop can into the space between the circle and the square to force the walls back to square. I started by folding a little piece of aluminum over and over so it was about three layers thick. Jammed that in. That wasn't quite enough thickness so I shoved another piece with it. If you can find something that is about 4 times the thickness of a pop can aluminum, that'd probably work too. Slight wedge shape on the tip would help. Any sort of tiny shim.
To test your work, just put a couple of holder screws into the HEPA cannister housing, plug in the cover/switch, plug in the HEPA moter. Turn it on for a few seconds to make sure the filter turns. Then you can add more thickness to the hub or put things back together.
Apr 29, 2008 | Hoover U5444-900 5100 Wind Tunnel 15 Inch...
Hoover Z-400 - Hepa Filter
These filters should be changed at least once a year, they get clogged up and won't clean out. So I would try a new filter and go from there, make sure there are no clogs in the hose and down below where the dirt inlet is.
Feb 20, 2008 | Vacuums
Vacuums Logo
129 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
