Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Service mode convergence - Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
  • Erik Feb 14, 2012
    I have a pt47x54j rear projection panasonic TV. I am having convergance issues around the border of the image, up to about 4 inches from the side. The 9 point convergance adjustment doesn't seem to do the trick, is there a 'service mode' where you can do a more accurate adujstment?
  • Erik Feb 14, 2012
    the picture in the middle area looks great.
  • Panasonic Master
  • 3,459 Answers
Your convegence has gone out. You can get complete kits with instructions from sites such as www.TvRepairKits.com or just the parts from www.ConvergenceChips.com . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
Posted on Mar 06, 2012
I have a 52" rca hdtv. the screen looks like its in 3d. can this be fixed? model# hd52w67
It seem like a convergence trouble. I tink it is a ITC222 chassis in this set. If it is, you probleme is eeprom for convergence need to be reprogrammed and cause no power on convergence board.
Apr 22, 2010 | RCA R52WM24 52" HDTV Projection Television
"Perfect Focus" problem on Samsung HCN4727W
You have a bad sensor, a bad digital convergence board, or the new board is not working correctly. I would start by swaping out the convergence board or exchange it for another one. Good Luck
Nov 08, 2007 | Televison & Video
Toshiba 57H82 convergence problems. TouchFocus
See my solution <http://www.fixya.com/support/t2795690-convergence_off_blue_line_only_vertical>.
You need to get to the service menu--it's been 4 years so go to AVSforum.com to turn off the different guns and get the better pattern.
At your risk: To get into Service mode:
1. Turn your TV on. 2. For X81 or earlier series: Press MUTE on your remote and release. 2. For H80/H81/HX81 series: Press MUTE on your remote and release two times ("Mute" on-screen) 3. Press down MUTE on your remote again and hold. While holding, press the MENU button on your TV set's front panel. 4. Release both buttons. 5. An "S" should appear on your screen. Press MENU again on your TV. 6. Now you're in service mode. Channel Up/Dn - Scrolls through Parameters and Volume Up/Dn - Changes Parameter Value
To get into convergence mode:
Get into Service mode, then Hit '7' to bring up the convergence grid. Buttons 100, 0, and ENT control which gun you want to turn off (if you want to align the red to the green without seeing the blue gun and other variations). 2=up, 8=down, 4=left, 6=right, 3=change gun to converge, 5=converge that point. To exit convergence mode you press 7 once and your screen should look like it's imploding then return to normal and then you press 7 to get back into regular service mode.
I have more info found on the board. -Ken
Jul 31, 2009 | Toshiba 57H82 57" Rear Projection...
Adjust Convergence on Zenith B27A11Z
You don't adjust convergence through a service mode on one of these sets. With a conventional CRT, convergence is done by physically adjusting the convergence rings on the neck of the tube, and the position of the deflection yoke near the bell. You would also need a crosshatch generator to provide the required test pattern for adjustment.
Feb 09, 2009 | Zenith B27A11Z 27" TV
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
Convergence problem
reset your tv with defaults settings.f chip and resstor blown then it need change.
Jan 06, 2009 | Philips 55PP9401 55" Rear Projection...
Convergence blue
to enter service mode MUTE 183
Oct 21, 2008 | Samsung HCL4715W 47" Rear Projection...
Rear Projection Samsung w/ convergence out
I believe it is mute-1-8-3 to enter the service mode, HOWEVER, I have also read that until the convergence problem is repaired, i.e. - depending on the configuration, either 2 individual IC's located on the lower board with 'playing card' size heat sinks or a simple replacmenet convergence board, adjusting the convergence through the service mode is comparable to "ripping the transmission out of your car to fix a flat tire". I myself have not gone into the service mode since I am still waiting for the replacement IC's - I get to do a component level repair.
May 05, 2008 | Samsung PCL545R 54" Rear Projection...
Convergence service mode
I don't know how to deal with the power settings part but the convergence service mode is "Mute, 1, 8, 3, power".
Jan 03, 2008 | Samsung PCN5425R 54" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
