i m facing problem with 2.4ghz and intel 845gvsr problem, when i start my pc after sometime it automatically shutsdown after few minute when i re boot i get a message unxpected shutdown due to thermal heating of cpu, where as the cpu heatsink fan is quite cool, it gives a alarm sound of cpu heating, i tried with other heatsinks the result is same, where does my problem lies in cpu or motherboard.
-   system shuts down automatically
-   Guest
Apr 07, 2008
-   thermal heating problem Facing-   Guest
Mar 19, 2008
-   m facing problem with dual core 1.8 ghz and MSI intel 945 MB problem, when i start my pc after sometime it automatically shutsdown after few minute when i re boot i get a message unxpected shutdown due to thermal heating of cpu, where as the cpu heatsink fan is quite cool, it gives a alarm sound of cpu heating, i tried with other heatsinks the result is same, where does my problem lies in cpu or motherboard.-   Guest
Hi, the cpu temperature should be under 50c, in you press delete when you start the pc it will go into the bios and under hardware monitor will give you the temperature. could be either or but its usually cpu related.
Sorry cant help anymore..
John
Was this helpful?
Yes
No
Solution #4
posted on May 05, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
sent proccessor to warranty u will get a termal paste from intel that will help to fix ur probs
By all means put a bigger fan on the thing that pulls more air and possibly turns a higher rpm.
Comments:
Aug 07, 2007
- Also be sure to use thermal grease or silicone grease to prevent over heating. If it is over heating due to the fan or a lack of thermal grease it is a good thing the shut down is working or it would of already fried your processor.
My Uniwell 6600 series cash register showed error code 18, replaced paper, both sides, then went to...
(More)
My Uniwell 6600 series cash register showed error code 18, replaced paper, both sides, then went to error code 3, redid cashier code. We tried to reboot by using the inital reset, now we get beeps and no error message and no ability to run cash register.
I have an ASUS 8bne motherboard. The Hard Drive LED wasn't working after my son did some fiddling,...
(More)
I have an ASUS 8bne motherboard. The Hard Drive LED wasn't working after my son did some fiddling, so I switched some of the connections around according to what was printed on the motherboard, and now the power switch doesn't work. Is there a diagram somewhere that shows how the connectors are supposed to go?
