Question about HP Deskjet F2210 InkJet Printer
HP Deskjet f2110 calibrate color
Is there a way to calibrate the ink color. It is printing red for blue.
SOURCE: HP Deskjet 6940 not printing after replacing ink cartridge
My HP Deskjet 6940 is not printing. The color (left) low ink light is dark and the black (right) low ink light is flashing. I replaced the black ink cartridge with a new one but the low ink light continues to flash. No tears/rips in the circuit strip and all the copper leads appear to be connected
Posted on Oct 22, 2008
  • 130 Answers
SOURCE: hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
Posted on May 02, 2009
  • 684 Answers
SOURCE: I have a HP Deskjet F4280 All-in-one. After
Was that a refilled cartridge???
Posted on Jul 24, 2009
eagle338
  • 4889 Answers
SOURCE: hp psc 2175 printer prints black fine and also
The hole he is referring to is probably the nozzle. Most of the HP all-in one's have this feature under the maintenance tab. Open control panel->Double click printers->Right-click on the HP PSC-> Click properties. Then click on the maintenance tab and click on the nozzle check option and insert a paper into the document feeder. The printer will check the nozzles and print different colors and patterns on the printer. Check to see if the printer is printing red and then post back on this thread with your results.
Sai.
Posted on Jan 22, 2010
Testimonial: "thanks for following up. I will find out how to change the print head or who can help me do this and hope it will solve my problem."
meanlean28
  • 10 Answers
SOURCE: HP deskjet 920C replaced both ink cartridges and now it prints in
How do you clean the ink reservoir?
HP Deskjet 3845 printing in blue yellow and green but no red. Print cartridges are new.
Check your cartridges. HP cannot guarantee the quality of remanufactured or refilled cartridges. Also make sure that the expiry date of the color ink is not reached. You should find it written on the cartridge itself.
Jul 12, 2011 | HP Deskjet 3845 InkJet Printer
HP Deskjet 990cxi Printer NOT printing B/W, only red.
To customer of HP deskjet 990cki: I purchased the HP photosmart Plus B209 ~ January 2010. 3 months into, I have learned that when the color ink that you don't use evaporates, the black ink will not work at all, no matter what you adjust or clean.To make it work you have to purchase more color ink...on & on & on..$$$$. Neither HP nor Best Buy will refund my investment. Spoken with HP customer service reps. in the Philippines & Canada both being outside of the US. NO customer satisfaction. No refunds. I suggest Boycotting both corps.
Jan 24, 2010 | HP DeskJet 990cxi InkJet Printer
Will not print true colors especially red and blue and green
replace the two ink caterage to a new one. it could be from the ink you refill that is if you refilled. bye
May 22, 2009 | Compaq Inkjet IJ600 Printer
Wont print colors correctly
Try replacing your red cartridge as it may be dry.
Mar 27, 2009 | HP Deskjet 5440 InkJet Photo Printer
Color is wrong
Have you tried replacing the cartridges? Some programs such as Adobe Reader will generate a "black" equivalent from the color cartridge. In this case, if the color cartridge is low in red, the outcome will be blue. This would signify that the color cartridge needs to be replaced. HP supplied a utility program for the HP6122 to detect and report ink levels. If you have this utility, check the levels. The utility will only work if the computer is directly connected to the printer -- not thru a print server. If you don't have the utility, you should be able to get it at the HP website http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=83028&lang=en&cc=us&taskId=135&prodTypeId=18972&prodSeriesId=88749
You might find that both the black and the color cartridges are out of ink. Some print drivers can detect when the black cartridge is empty, then attempts to print a black equivalent using the color cartridge.
Mar 16, 2009 | HP DeskJet 6122 InkJet Printer
New tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Jan 22, 2009 | HP DeskJet 960c InkJet Printer
Deskjet 970 unable to get test
ok...first...low color will do that blue effect..
and, you may need new drivers
remove old ones first
go here for fresh set
then reinstall
Feb 26, 2008 | HP DeskJet 970cxi InkJet Printer
HP Deskjet F2210 InkJet Printer Logo
74 people viewed this question
Seeker5211
Seeker5211
