1999 Daewoo Lanos Logo
Posted on Oct 24, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Oil pressure have a 1.5L SOHC - when hot -oil pressure light comes on & have rocker noise - need to know where the sensor is to remove & install master guage to check pressure. Also need to know what the pressure hot should be at idle. Thanks again, Chris Craig, Aruba, DWI
Steve Allison
Level 3:
  • Daewoo Master 5,569 Answers
  • Posted on Oct 27, 2008
Steve Allison
Daewoo Master
Level 3:
Answers
5569
Questions
Helped
2001138
Points
16452
This doesn't sound good, the pressure sensors fail more often than the oil pump but not with prominent rocker noise. I can't help you locate the sensor but you might want to consider downloading the complete manual for $9 US from this site:
Trade bit manual
The range of oil pressure falls between 30-60 PSI (2-4 bar or ATM). The warning sensors are somewhat useless as they typically will switch at ~ 4 PSI which is pretty much a disaster zone.
2answers
I have a 1996 gmc jimmy and I have a ticking noise
It could be that the valve clearances need doing, if that doesn't fix it then put a oil pressure guage on it and check the pressure,
1helpful
Replaced oil sensor light still comes on
MAY---May-be you really have low oil pressure.. The way this sensor works is when you turn off the engine it closes to ground.. and when you start the engine.. the oil pressure opens it and the light goes out.. SO.. if the wire going to it is grounded out somewhere between the sensor and the dash board the light will stay on.. 3 choices.. 1. bad sensor (even though you replaced it) 2. wire is shorted to ground.. remove wire from sensor while engine is running.. light should go out. 3. you actually have really low oil presure. next.. after you have exuasted #1-2. you can remove sensor and install a real oil pressure guage and see what the pressure really is.. If you have very low or no oil pressure..1. Check oil level.(probably should have done this first) 2.pull oil pan and replace oil pump.. while you are there check a main bearing and a rod bearing for wear.. worn out bearings will cause low oil pressure. If you have good oil pressure install the pressure guage permanetly and forget about light.
2helpful
2answers
Losing power,tapping noise in valve cover. could it be the rocker arm and the cam?
could be bad lifters or loose rocker arms, bad oil pump or low on oil, possible bad cam (but not likely)
first thing i would do is check your oil real low oil will cause this
if oil is fine check for oil pressure if oil pressure is low assume bad oil pump
if oil prssure looks good look for bad lifters or loose rocker arms
I have a 2002 Jeep Libertywith a 3.7 engine. The oil pressure light and chime comes on at 1700 rpm according to my mechanic. He changed the sending unit,the connecter to the sender still does it. Put a...
a mechanical gauge properly installed using copper line not plastic is a good idea ( plastic gets hard and breaks or melts if it gets hot)
do not consider turning off the light or the noise as it will hide a pressure failure
remember that the average driver doesn't look at the gauges while driving
2003 Chevy Malibu, oil light is on. I changed the oil and filter...light remains on. Rockers and lifters are clattering and no oil is reaching the valves on the oil fill valve cover. How do I diagnose...
could be a bad oil filter, plugged sump pick up tube screen, have a mechanical oil guage installed to ge an accurate reading, althoug i suspect if the engine is making noise it may be damaged, best to remove the oil pan for inspection, metal shavings in the bottom indicate serious problems
1helpful
2answers
The oil light comes on at times and goes off as the rpms go up. What can be done about the light?
Maybe your engine is idling too slowly, If the revs are below say 700rpm the low pressure warning light could come on especially when the engine is hot.. If the idle speed is ok try a heavier grade of oil in the engine. Next try a new oil pressure sensor. It's got to be one of these things. Check the engine running temperature . An over-hot engine will cause the oil light to come on too.
When first starting the 2000 jeep grand cherokee the oil pressure is fine, after driving 15 to 20 miles when you stop the oil pressure guage indicates the pressure dropping near 10 pds or less and the...
When the pressure reads low, are you hearing any knocking or tapping noises from the engine? If so, you may have worn engine bearings. I'd check the actual pressure by having a mechanical gauge installed on it in order to determine the actual pressure (your gauge is electro-mechanical and not quite as accurate) If pressure is actually that low the oil pan must be removed and bearings, oil screen etc need to be checked.
The reason pressure is always higher at first is that when cold the oil itself is thicker...as it gets hot and thins out pressure will drop somewhat, but should not go that low. Only other thing that can affect pressure in that way would be either a bad sending unit (you will know that after testing) or gasoline contamination in oil (happens if an injector is not working properly)
Good luck with it!
3helpful
2answers
Oil pressure question
Hello daebbers: My name is Roger and I will be glad to help you. I assume by the way your question is written you have no objectionable engine noise. I would suspect a bad oil pressure sending unit. To check the switch will require a mechanical oil presser test. You can buy a kit at any parts store. With a cold engine. Remove the oil switch from the block. Install the mechanical gauge. after all connections are tight start the engine. Note where the pressure is at. Observe the pressure through engine warm up. As the oil and engine warm up the oil pressure will drop. According to All Data information the oil pressure at curb idle is 6 psi. This would be a min. oil pressure. If the oil pressure is higher then that is great also. Any thing less you have a internal oil leak. This would likely be a bearing issue.
PLease rate the quality of your answer. This way we know the answer you received was helpful.Should you need further help please just ask. Thank You for using Fix Ya. Roger
1helpful
No oil pressure on guage
change oil pressure sending unit. remove oil fill cap start engine to determine if oil pump is delivering oil to rocker arms. it it easer to tell if you remove one valve cover and then start engine. if rockers are not recieving oil change oil pump and clean oil strainer in oil pan
1helpful
When my truck gets real hot the oil preasure guage starts bouncing when truck idles as soon as truck is put into park or is reved up a bit it stops bouncing
You may have a Faulty Oil Pressure Sender.
Here are some reason why your guage is bouncing:
  • Corrosion or faulty electrical connections
  • If the oil pressure gauge is pegged low after the engine is running, or is pegged high after the engine is running, or if there is intermittent illumination of an oil pressure indicator light, the sender could be faulty
You can find the oil sensor on the left hand side near the Oil Filter, as long as you don't hear your lifters ticking and making lots of noise. it's not your oil pump failing.
Good luck and hope this helps
Top Daewoo Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Daewoo Expert? Answer questions, earn points and help others
