Question about ViewSonic PJ560D Projector
Pj560d 2 red lights on startup and no image
Viewsonic PD560D no picture green LEDs
there is a colorwheel inside the dlp projector that spins and the light shines through the colored lenses on the wheel, onto a dmd board, and reflected out through the lens. however, if the wheel motor is bad and won't spin, the light won't even turn on. i recommend replacing the colorwheel
Feb 25, 2014 | ViewSonic PJ560D Projector
Wont startup, on screen says "no signal", both
on screen says "no signal", both green & red diode light are up :
plug vga cable tightly else check with new vga card
Feb 12, 2011 | AcerPower F1 PC Desktop
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
My remote won,t turn on or off my projector. I tried to change the batteries but it didn,t help . I aslo can't seem to find my manual so I was hoping that you may help me. My projector is the PJ560D....
Take a pencil and scratch the metal contacts in the battery compartment, then use the eraser to get the pencil marks off.When you insert the new battery press your thumb on them and roll them.I have been doing this for over 20 years,works 95% of the time for me.The medal becomes oxidized and get a film over it.
Oct 23, 2009 | ViewSonic PJ560D Projector
Red light upon startup.
possibly 5w ceramic resistor in the psu start up stage
Sep 17, 2009 | Philips 26PF5320 26 in. LCD Television
Xerox 7700 won't get past the startup screen
Make sure the image control board is not missing anything.
and maybe try replacing it with a diffrent image control board.
Goodluck!!!!
Feb 25, 2009 | Xerox Phaser 7750DN Laser Printer
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
KV-32XBR250 Has about twenty Horizontal, Light Red bars aternating
your problem is called retrace lines it is due to 1 supply to red out put is absent 2 problem in red video output 3 loose contact in red output ckt 4 connector loose 5 crt base loose 6 circuit from red output of chroma ic to red video input 7 chroma ic defective regards
Sep 11, 2007 | Sony KV-32XBR250 TV
ViewSonic PJ560D Projector Logo
32 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
