Question about Yamaha iiyama 17NE1-S e-yama 17" LCD Monitor
Yamaha iiyama 17NE1-S white vertical colum
I am Yamaha iiyama 17NE1-S e-yama 17" LCD Monitor and i have a white vertical colum to center the screen...just in the monitor is on.....not off thank you to resolve
  • midge123 Dec 04, 2007
    2 pink 1 white thin vertical lines on left of screen perminantly
Give it a light bang with your hand to the side.. really.. it says so on their website. it happened because of dis-alignment of some grid, probably happeden during transport
Posted on Dec 10, 2008
  • kneejo Dec 10, 2008
    hmm, sorry, i have the crt version, not the lcd :) so banging won't work, i guess
SOURCE:
Have owned a iiyama 17" pro crt for a few years,
These were a fine monitor and with the kind of image quality you cannot get on TFT's.
If you know the graphics card you are using is working ok, have checked the VGA cable connection and socket at the monitor and computer and have tested the monitor on another computer, that would rule out any problems as far as connected devices are concerned.
The problem you describe, and it is unusual that it has happened so quickly, points to a failure of the monitor internal board. You may be able to get this repaired at a reasonable cost by seeking the opinion of a TV repairman, who might be able to fix it.
Jul 25, 2011 | iiyama Vision Master Pro 400 (White) 17"...
I have E-Yama 17inch LCD monitor having display problem, left side of the is became dark and the right side little bid bright/visible. It may be effected by the high power speakers which were installed on...
LCD monitor is not affected by manetic field like the CRT type monitor which uses electron beam to light up the phosphers. It is more like the power supply is not supplying the full voltages as needed by the backlight inverter circuits. Look the power supply section for bad DC caps with leaking/bulging tops, or they may have high ESR (you need ESR meter to test it).
You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Jul 21, 2010 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
Do I need a software Cd for instalation ?
No, your Operating System will choose the optimum settings.
Jun 28, 2010 | iiyama E431S-W1S (White) 17" LCD Monitor
I have an e-yama 17NE1-S Monitor, but have misplaced the power cord. Know where I can get a replacement?
    • Better go to the shop from where you bought it  they will provide you the replacement
    Jun 17, 2010 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
    Iiyama Prolite 434S monitor is too dark
    Dim or dark display can be caused by a faulty inverter board or faulty CCFL lamp. The inverter supplies high voltage to the CCFL lamp, the CCFL lamp is a miniture fluro tube and these dim with age.
    Check out LCD Parts for service, parts and DIY info - click on this link to their WEB site. :-
    www.lcdparts.net
    Sep 28, 2009 | iiyama ProLite E434S 17" LCD Monitor
    There is a vertical thin line going up the center of the screen. It's appears when I turn the monitor on and the only time it disappears is when the screen is white.
    change your vga setting and monitor setting by right clicking on desktop try using your monitor different htz setting in advance tab and monitor setting
    Jul 22, 2009 | HP L1702 17" LCD Monitor
    E-yama monitor "out of range"
    The fix was pretty easy in the end.
    Instructions are based upon Windows XP Pro OS.
    Re-boot computer but inerrupt start-up by pressing F8 (option will vary between computers)
    Select SAFE mode but with VGA option in order that the screen will actually display.
    Once fully loaded click:
    Start
    Control Panel
    Appearance and Themes
    Display
    Settings
    Using the mouse cursor adjust Screen Resolution sliding scale until the ratio matches your monitor e.g. 1280 x 1084
    Then click Apply and OK (important to do it in this order otherwise changes will not be saved)
    Reboot as normal and the monitor should now display correctly.
    May 11, 2009 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
    Need a replacement LCD
    Yes you can go to any tv engineer tell him to replace crt (picture tube) if he agree then purchase new picture tube and replace it if only cabinate is brocken then replace cabinate take care that the reparing cost will not exceed monitors cost if you are a engineer then while reparing yoke coil connect properly it can fit only right not reverse
    Oct 31, 2008 | iiyama E-yama 17NE1 (Silver) Monitor
    PC monitor wont come on.
    Check that the power cord is fully plugged in first.
    It is probably the inverter board inside the monitor.
    (if the screen does properly display ever then it is not the screen)
    It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
    If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
    Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
    Screen keeps fading
    I don't know for sure if this will help but it's worth a try. Go to Start, control pannel, system, advanced, performance, settings, and click adjust for best performance. This is a Windows XP fix but the same thing may apply to older OS's (95, 98, 2000, ME, NT (although you may have to set it a diferent way). Many other things could be your problem but this is an easy thing to try.
    Feb 01, 2007 | Yamaha iiyama 17NE1-S e-yama 17" LCD...
    Yamaha iiyama 17NE1-S e-yama 17" LCD Monitor  Logo
    203 people viewed this question
    Top Yamaha Computers & Internet Experts
    Marvin
    Marvin
    Harrie
    yobo007
    yobo007
    Are you a Yamaha Computer and Internet Expert? Answer questions, earn points and help others
