Question about Sanyo Permax SC-U125 Bagged Upright Vacuum
I need a new belt. Where can I purchase one online?
My dyson dc33 beater bar won't turn
There are belts in the clutch, which is the lever you can move to adjust the vacuum from floor to tools. The belts become stretched and need to be replaced. You can purchase just the belts or purchase the clutch assembly with the belts installed. There is also a belt change tool that makes the job much easier to install because the new belts will be much tighter than the old belts. The parts are available from thatvacguy.com.
Jul 10, 2014 | Dyson DC-33 MultiFloor Upright Vacuum...
How to remove clutch on dyson dc07
This service is hard to explain. Try googling it so you watch a video of how it is done. You can purchase belts and rebuild the clutch with the new belts or you can purchase a new clutch with belts already installed
Mar 27, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Can the Turbo Brush on a Bissell vacuum be repaired?
Hey Teri! If you have good suction from the end of the upholstery hose, the turbobrush should rotate as long as there isn't anything binding the brush. Otherwise, a new turbobrush will need to be purchased.
Here's a quick link to ordering one online.
http://www.bissell.com/parts/?id=9143&sc=product&productid=2433&st=2&cid=ccsocial
Feb 02, 2013 | Vacuums
How do you change the belt
If your DC07 is a model equipped with the brush control feature, the belt should not need replacing. If it doesn't seem to be working correctly, it's probably best if you get in touch with us directly using the details provided below, so we can help you resolve the issue as quickly as possible.
If your DC07 is a model without the brush control feature, you can find out how to replace the belt here:
http://www.dyson.co.uk/support/help.asp?article=18&product=DC07-ORIGIN
You can purchase replacement belts from our online store:
http://www.dyson.co.uk/store/partsDetails.asp?part=ACC-DC0104BELTS&product=DC07-ORIGIN
If you have any further questions, or if you'd like to order the belts via our Helpline, please call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Sep 16, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Brushes do not turn
HI there,
There are a couple of reasons that your brushes may not spin.
1. The hard floor / carpet dial is set to hard floor.
2. The clutch to motor belt is broken
3. The clutch to brush belt is broken.
4. The roller brush bearings are siezed.
5. The clutch is faulty.
THis sounds like a lot of things but if you watch my video I will show you all these issues and you can get your machine going again.
I also have a blog at vacuumsmart.info if you have other Dyson questions.
If you need to get a new belt for your dyson or a brush roller you can purchase them online.
If this is a helpful guide please take a moment to leave a review or rating
Jan 18, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
I need a belt for a kenmore vacuum cleaner model # 721.36078601
seras parts direct has the belt. some of the sears store where you purchase the new vac, they have the belts on the shelf. might be a 5275 belt.
Feb 24, 2010 | Vacuums
I need to buy at least 2 new belts for my vacuum.
You can order belts online from http://www.totalvac.com/parts/BR-1007.html
May 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Where to purchase Fantom Vacuum parts? Not filters, belts, bulbs
I am sorry to inform you but fantom is out of bussiness and the parts are no longer widely available. If anyone has them it would be the guy i am refering you to.
ask for joe
302-698-2133
I am not sure of his hours but take into consideration he is on the east coast.
Apr 13, 2009 | Vacuums
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
I have a Hoover Vacuum Cleaner, Runabout Supreme, on which the belt has broken. I purchased a new belt, part number 38528-040. I need some instructions on how to install the replacement belt? Thank...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=728341
Generic problem for all Vacuums
Posted by Jimbob48 on Jul 01, 2008
I need some instructions on how to install the replacement belt? Thank you. JBS
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Usually there are screws, clips or levers on the bottom of the vacuum and you need to either remove the bottom plate and once you have taken the screws, etc. out the top cover will come off. And then you can proceed with the removal and the install of the new belt. 1st you need to remove @ least one end of the Hoover brushroll and take of the old belt and slide on a new belt. Once the belt is on the pulley side of the brushroll; then re-install the brushroll. Make sure that the brush is spinning freely B4 you install the new belt, then take a belt puller or a screwdriver with a left or right hand hook to use as a belt puller and then stretch the belt onto the motor pulley, then take and roll the belt until it is tracking straight and then re-install the top cover and or the bottom plate, tighten down the screws, levers or clips. So, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 01, 2008 | Hoover Elite U5061-900 Bagged Upright...
Sanyo Permax SC-U125 Bagged Upright Vacuum Logo
26 people viewed this question
Top Sanyo Vacuums Experts
Gerry Harvey
Gerry Harvey
ray gallant
Thatvacguy.com
Are you a Sanyo Vacuum Expert? Answer questions, earn points and help others
