Question about HP Pavilion 513n (P9850A#ABA) PC Desktop
Trying to add a printer to computer via usb 2.0 printer cable
I have many usb ports here and the printer wizard cant instal it cause can't find it and i have to do it manually...but I dont know which port I have it in...I put it in the rt. port at the front of the computer...how do I find out if which port that is when i am on printer wizard...LPT1, LPT2, LPT 3, COM 1, COM 2, COM 3, COM 4 ?????? HELP ME!!!!!!!
  • HP Master
  • 27,725 Answers
Plug your printer into any usb input point on your computer
found new hardware wizard should start or you might have to do it manually
click start control panel administrative tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port
you might see a yellow? ! question exclamation mark or a red X this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps you
Posted on Feb 14, 2012
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
My Officejet Pro 8500 Wireless will not print in landscape mode no matter what I try. Last time I had this problem, HP had me install a generic printer; but I don't remember what exactly I had to do...
here's how:
FOR WINDOWS XP:
  1. Click Start .
  2. Click Printers and Faxes folder.
  3. Click File . Then select Add printer . NOTE: This step launches the Add Printer Wizard .
  4. Click Next .
  5. Uncheck the Automatically detect and install my Plug and Play printer checkbox.
  6. Click Next . The Select a Printer Port window displays.
  7. Click Next . The Install Printer Software window displays.
  8. Select HP from the Manufacturer list .
  9. Select hp deskjet 990C model from the Printers list.
  10. Click Next . The Name Your Printer window displays.
  11. If the printer name is correct, click Next .
  12. Click Next . The Printer Sharing window displays.
  13. Select No when the message Do you want to print a test page displays.
  14. Click Next . The Completing the Add Printer Wizard displays.
  15. Click Finish . NOTE: At this point, the driver installation portion of the process is complete.
  16. Connect the USB cable to the printer and the computer. NOTE: Windows will start to Plug and Play the device.
  17. Click Cancel for each Found New Hardware Wizard window that is prompted. NOTE: The number of Found New Hardware Wizard windows prompted by Windows will vary depending on the device plugged into the computer.
  18. In the Printers and Faxes folder, click the hp deskjet 990c printer icon.
  19. Click File . Then click Properties .
  20. Select the Ports tab.
  21. Scroll to USB00x Port and check the checkbox for the port.
  22. Click Close .
Jun 03, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
How to install deskjet 2500 series without installation cd?
Hello
Welcome to Fixya!
My name is damnor01
See my guide entitled How to Install the latest drivers for Hewlett Packard Printer!!!
With the aid of this guide you will be able to download and install the drivers for your printer.
First install the drivers and then connect the printer to power and via the USB cable.
Take care!
damnor01
May 07, 2011 | Office Equipment & Supplies
INSTALATION
Try to connect the printer by using another USB Cable and in different port may the USB port in computer side or the usb cable is damaged that is why fail to send signal to your acer then try againt to install by using add hardware wizard
Jan 17, 2011 | HP DeskJet F380 All-In-One Printer
How can I install HP Officejet 6310 All in one printer without an installation disk?
you cant install printer device without the driver disk. you can connct the printer to your computer but your computer wont recognize the printer. please click this link for your printer driver.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 04, 2010 | HP OfficeJet 6310 All-in-One Printer...
Computer can's see Print Server in Add Printer Wizard The WGPS606 installation -- part 1 -- seemed to go fine. It sees our wireless network, we assigned it an IP address, it sees the printer connected to...
Make sure the printer has been connected locally first and that the print drivers have been installed. This should then allow you to add the printer via the set up.
Regards gaz
Sep 28, 2009 | NetGear WGPS606 (WGPS606NAR) Print Server
I have just purchased a HP Officejet J5750 All-in-one and have no connection to computer even thought all cables are connected and software has been installed. Where can i find a trouble shooting guide?
While installing the software, did you use the MS PRINTER INSTALLATION WIZARD? Try this: left click mouse on WINDOWS START on lower left corner of screen. Left click on CONTROL PANEL, then left click on PRINTERS.On the PRINTERS window, left click on ADD A PRINTER on the upper toolbar. The ADD PRINTER window will appear, displaying CHOOSE A PRINTER PORT. Left click on USE AN EXISTING PORT. From the drop-down window, choose any port starting with the letters USB. You may have to try each USB port individually to see which one will work with your printer. Just follow the wizard's instructions and your printer will then be connected.
Aug 04, 2008 | HP Office Equipment & Supplies
HP 7280 printer/internet access
It's just the printer she cannot access? Is she able to ping the printer? or possibly, connect to the printer via your computer? You can also try adding the printer manually. It's share name can be found either via your own computer (in the printer properties), or via the printers web interface (192.168.x.x). To do so, click Start > Printers and Faxes > Add Printer Select "Local printer attached to this computer". Click Next and select "Create new port", then from the dropdown list, select "Standard TCP/IP Port" and click Next. Click Next on the dialog that appears, then enter the printers IP address, and a port name for it (for example for my own I entered "192.168.0.100" as that is my printers IP address, and "IP_192.168.0.100" for the port name (Windows enters this itself when you put in the IP address - you can change this to whatever you like)), and click Next. You will now see a dialog showing you the printer it is going to add. Click Next on this screen.
May 26, 2008 | Office Equipment & Supplies
Installation for canon pixma ip 1500
Hey you again, you rated me yesterday Inappropriate. Actually, fixya expert afraid to give some solution because you will rated us Inappropriate even the problem is came from you where you was not clearly stated your problem.
Ok, but anyway I am still to help you, Is it the problem goes to the manual installation you need or the driver instead?
Printers used to be the bugbear of computer users. They were difficult to set up and ornery in operation. That's no longer the case and it's likely you'll have no problems getting your printer up and running. This is particularly the case if your printer comes packaged with your computer system or if you stick to well-known brands such as Hewlett-Packard, Epson, Lexmark and Canon.
Connecting a printer involves four steps:
  1. Unpacking your printer, removing any packaging material and installing the ink or toner cartridge. Refer to your printer's instructions to guide you.
  2. Connecting the printer cable to the printer and to the back of your computer.
  3. Connecting the printer's power cord to a power outlet.
  4. Installing the printer driver and any additional software. The printer driver is a piece of software that tells your computer how to interact with your printer.
If your printer comes as part of your system, you may find that its driver is already installed. In that case, all you'll need to do is unpack it, connect the printer cable and power cord and switch on your computer.
geekgirl.tip: Get a cable One word of warning: Make sure you purchase a printer cable! Often, this is not included in your computer system, despite it being an essential item. You'll need the correct type of cable for your printer: If it's a USB-enabled printer, you need a USB cable (note, the new USB 2 cables work with older USB 1 printers, too; so if in doubt, get a USB 2 cable); if it's a parallel printer, you'll need a parallel cable.
Make sure you get a cable long enough to reach easily from your printer to your computer. However, you should avoid cables longer than 10', because long cables can cause problems with communication between printer and computer. Try to position your printer so a 6' (or shorter) cable can make the connection.
Follow the wizard If your printer's software has not been pre-installed, read any installation instructions that accompany your printer and follow those instructions. If no instructions are provided, follow this procedure:
(Note: This procedure applies to printers which use a parallel connection. If your printer uses a USB connection, you should connect it while Windows is running and it will be recognised.)
  1. Make sure you have your original Windows CD-ROM handy. You may need it.
  2. Switch the computer off.
  3. Connect the parallel printer cable to your computer.
  4. Connect the printer's power cord to a power outlet.
  5. Switch on the printer and the computer.
  6. In most cases, Windows will detect that you've attached a new hardware device and it will launch the Add Hardware Wizard and attempt to search for the appropriate software. If the wizard doesn't launch and Windows appears to ignore your printer, you can launch the Add Printer wizard yourself by clicking the Start button, selecting Control Panel, clicking Printers And Other Hardware, and then clicking Add Printer.
  7. If the printer is directly connected to your computer, select the Local Printer Attached To This Computer option. If you will be connecting to the printer via a network connection, select the Network Printer option, then click Next.
  8. The wizard will first try to search for any Plug and Play devices (these are components that should, by rights, automatically notify Windows when they're first connected). If the wizard discovers your printer, it will display further instructions to complete the installation. You may need to restart your system to finish.
Nov 23, 2007 | Computers & Internet
HP Pavilion 513n (P9850A#ABA) PC Desktop Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
