Question about Whirlpool LSQ9600L Top Load Washer
Maytag A512 H top loading (1988 washer)
During the initial filling of the machine, both the hot and cold water fill at a full rate.When it gets to the rinse cycle it takes about 45 minutes to fill.The water barely trickles in. This is followed by no agitating and empties out the water. This occurs in the permanent press cycle. The hose and screen filters are fine. When run in the regular cycle the washing machine works just fine. Would this be corrected by replacing the filling valve and or the dial controller for wash selection.:::::?????
  • kwjscuba Oct 25, 2008
    I did run it in the normal cycle for filling the way you suggested. It fills fine both ways, good volume and flow. When the cycle gets to the fill cycle in the rinse stage of the cycle the water only trickles in and after a long filling time it will empty the drum and stop the cycle. However this condition only seems to occur when I use the permanent press cycle. The other cycles , regular and gentle cycles seem to fill in all parts of the cycle just fine.
    kwjscuba
  • butch welch May 11, 2010
    Lets try something to help narrow this down. Put your washer on normal cycle and turn it on, put your selector on hot water and notice how much flow you have, then put it on cold and notice how much flow, then put it on warm and notice the flow. Switch the selector between hot and cold and see how much the difference. May even take the cold water hose off the washer and check your cold water supply to the washer.(Run it in a bucket) From the way you describe your problem I think it will be the cold water supply
catriver
  • 878 Answers
SOURCE: Washer fills slow only in the rinse cycle
The first thing I would do is remove the hoses from the inlet valve and make sure the screens are not clogged in the valve. On some models the valve will compensate on fill opening both hot and cold. It will not do this on cold rinse. Before ordering any controls check this out first. If it's still the same I tend to believe it's a valve problem. The buzzing you are hearing is the valve. Catriver, post back.
Posted on Aug 06, 2006
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
  • 1028 Answers
ck and clean screens first both sides be sure hoses are not reversed timer has no affect on fill rate if screens are clean replace valve
Posted on Sep 20, 2008
BNewberry
  • 93 Answers
SOURCE: water barely trickles out for rinse cycle
It sounds like you have some buildup in the cold water valve screen. Where the hose connects to the washer there should be a screen inside the valve. Remove the cold water hose from the washer and clear any debri on the valve screen.
If this doesn't fix the slow cold water flow then you will have to replace the whole water valve assembly. The water valve is the piece that the hoses connect too and supply water to the washer.
If you have anymore questions about this please ask. I will be more than happy to help you out.
Thanks
Posted on Jan 12, 2009
buffalonyman
  • 1865 Answers
SOURCE: cold water in the rinse cycle of the washer just trickles
Sounds like cold water solenoid is not opening all the way, its easy to replace, and is found inside the wash machine where the hose connects
Posted on Apr 25, 2009
My Maytag Neptune will not go into the spin cycle, instead the letters "nf " come on the display. What can I do to prevent this and to have the cycle completed?
Bonnie,
NF = No Fill the control board receives signaling for the washer during the water fill cycle. With most cycles the depth of water is around 3.5 inches in the wash basket. I know a Bulky Wash cycle selection will fill the wash tub to a high fill which is about 7.5 inches of water in the wash basket.
Is the washer filling the machine with any water? Do you hear water entering the machine? If you are doing a cold water fill and there is no or very little water in the wash basket with the NF error code. Try a Warm or Hot fill and see if the machine will fill and start the wash cycle.
Assuming you are doing cold water wash loads. You could have a water line block at the inlet screen or a failed cold water inlet valve which will not open. Try the above and let me know the results..........Rich
Sep 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Performa wont fill hot water
The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Nov 27, 2009 | Maytag Performa PAV2200
Only hot water will fill, cold water will not
If it is equipped with ATC automatic temp control turn it off and see if if you can get cold if so its the ATC sensor
Sep 08, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Does not agitate, will fill and spin out water. How to diagnose?
take top control panel off and check your lid switch odds are its the problem
May 26, 2009 | Maytag Washing Machines
My whirlpool front load washing machine accept hot water and no cold water entering on the machine.
Apr 01, 2009 | Whirlpool GHW9400 Front Load Washer
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Cold water inlet on maytag top load washer not working
switch the hoses fill hoses and if no hot enters you have a defective inlet vavle,,replace...onthejob
Jan 13, 2009 | Maytag PAV2300 Top Load Washer
Sep 19, 2008 | Kenmore 24032\24036 Top Load Washer
Does Not Rinse
Check each temperature during initial wash fill. Set to hot water, is hot water coming out? Set to cold water, is cold water coming out? The rinse cycle is cold only. If cold water is not working machine will just stop at rinse.
If cold water not working:
Disconnect cold water hose from machine. Inspect the filter screen on the cold water connection. DO NOT REMOVE SCREEN. If full of debris, use a spray bottle with a hard spray to remove debris. If unable to remove or cold is still not working, replace valve.
Jun 14, 2008 | Whirlpool LSR6332K Top Load Washer
Whirlpool LSQ9600L Top Load Washer Logo
240 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
