Question about Radio Communications
Just received this meter after buying online - RMS reads ok, peak reading position buries the needs all the way to the left - looks out of alignment. Anyone have ideas?
How to align peak reading
    Genius:
  • 1,212 Answers
Most meters have a calibration adjustment or two internally.
However- some meters- especially the old VTVMs used a 1meg resistor in the AC test probe. and they had a seperate DC and AC terminals and test leads because of it.
If it were mine, I would open it up and look for non factory modifications. I would suspect a 1 Meg resistor is missing or shorted somewhere in the Peak section. it may be some other value but should be proportional.to what is present the RMS section.
Posted on Feb 14, 2012
My Greenlee digital multimeter reads line voltage about twice what it is. What do I need to look for?
Is it possible you are seeing some variation on peak-to-peek voltage vs AC RMS which is more commonly used? Are you positive you were using the proper AC range rather than a DC range? Instead of double it should be more like 1.414 x the actual RMS voltage. If you were using the right range (AC) then your meter probably has an internal diode out. Because of isolation and other safety features in a VOM, factory repair may be preferable to possibly having a less safety aware tech repairing it.
Do you know what kind of meter abuse caused this damage?
Instrument repair has always been a more specialized and demanding arena of electronic repair.
If it's a $25 meter it could easily be more expensive to repair
than to replace with a new one.
This is all general information because you did not specify
which model of Greenlee multimeter you have.
It's easy to blow a VOM by putting it across a circuit when it's
set to the wrong range.
Sep 08, 2017 | Greenlee Measuring Tools & Sensors
Line voltage indicator false indication of voltage variations
Voltmeters usually read RMS on ac volts therefore 120 volts is OK while the indicator is reading peak volts. If unit is operational there is no problem.
Mar 31, 2014 | Tripp Lite G1000U Intelligent LCD 1000VA...
3300hp how many watts output, what swr/ power meter should be used
That style will get about 60w PEAK.. on older styles.. the newer Mosfets will do about 30-40ish..
Meters, are preference.. most are just RMS styles. and you wont see the Peak reading which is fine. there are alot of meters and brands.. Bird, Dosy, MFJ, Siltronix. they all have pros / cons.
if just want simple workman makes some lower end styles. also para dynamics..
there are some MFJ and other brands that have cross needles that show both power and swr at same time. but they will start in the $60ish range and go up from there.
Oct 24, 2013 | Connex 3300 240-Channels Base CB Radio
My ANT light comes on when ever i push the mic button but my SWR isnt that high
The meter will be more accurate and an external meter will be even better. If they show good disregard the ant light it is adjustable. It may have been set to sensitive from factory. These erroneous SWR reading can be the side effects of a PEAK & TUNE if the coils have been spread but that should also show on meter.
SWR meter calibrations
  • Switch (S/RF SWR CAL) to the CAL position.
  • Push and hold mic button
  • While holding mic button adjust the SWR CAL knob so the meter needle swings to the CAL mark on the meter
  • While still holding down the mic button, set the (S/RF SWR CAL) switch to the SWR position, to read the SWR reading. Note: When switched to SWR position the meter needle should ideally be as far to the left as possible. Anything over 3 is not acceptable.
Jul 28, 2011 | Cobra 29 LTD CB Radio
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
Only doing about 45 watts this is the 80 watt version s- meter not working
What kind of meter do you have. That may be correct If it's an rms only meter that's all it will show it won't show the peak wattage. You would need a peak reading meter. If you do have a peak meter then check your swr's. If they are high then it will hurt the output of the radio. We. Dont charge to check out any radio.
May 15, 2011 | Magnum 257 CB Radio
Our online UPS is giving only about 204-206 volts, instead of 240. I changed the batteries, but the output voltage hasnt changed. What could be the problem? Could you suggest some things I can try?
oh that voltage is ok if you are measuring voltage by digital multimeter then it shows wrong value measure voltage by anologue multimeter it will show 240v correctly dont suspect on measured voltage
Feb 27, 2010 | APC Symmetra RM 2 kVA UPS System
I got a output voltage of 100.1 on a trace dr3624
The rms voltage is what counts, because it tells how much power the output will deliver to a resistive load. Inexpensive multimeters on their AC ranges are usually average-responding rms-calibrated meters. This means they measure the average of the absolute value of the AC component of the signal, and display that average multiplied by about 1.11 (actually, pi over sqrt(8)), the ratio of rms to average value for a pure sine wave. That way, the meter will give the right rms reading for a sine wave.
If the signal is a square wave, where the average and rms values are equal, the average-responding meter will read 11% too high.
Many inverters put out a modified sine wave (MSW), which sits at zero for a while, goes to a constant positive level for a while, goes back to zero for a while, and goes to a constant negative level for a while to complete the cycle. The positive and negative parts of the signal have the same magnitude and duration.
The rms and average values of an MSW depend on its duty cycle D, the fraction of a cycle for which the signal is not at zero. In a well-designed inverter, the duty cycle will be adjusted when the DC input voltage goes up and down to maintain the nominal rms output voltage. If we use peak voltage Vp to mean the magnitude of the positive and negative voltages the signal goes to, then Vavg for an MSW is equal to Vp times D, and Vrms is equal to Vp times the square root of D.
The duty cycle for which an MSW will have the same rms to average ratio as a sine wave is 8 over pi squared, or 81%. For any duty cycle less than this, an average-responding meter will read a lower voltage than the inverter rms output, and for a duty cycle higher than this, the meter will read too high.
If your MSW inverter is putting out 120 volts rms and its duty cycle varies from 50% to 75%, the meter reading will vary from 94 volts to 115 volts. I avoid the problem by using a Radio Shack 22-174B true rms digital multimeter.
Aug 27, 2009 | Xantrex Technology DR2412 Inverter /...
New Radio too powerful for 15 Watt speakers?
Hello mike_mccuske,
The OEM speakers will still work OK with your new Pioneer. Just don't turn it up too loud. Of course you'll get improved sound if you replace the speakers. Your Pioneer's RMS power is 14 watts, and the peak (maximum) power is 50 watts. The door speakers in a 2000 Honda Civic are 6.5" and you can get a set of Pioneer speakers, the TS-G1642R's, from Crutchfield for less than $50. Their RMS power range is 2-30 watts and they can handle a peak power of up to 180 watts.
Hope this helps.
May 22, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Auto decks and speakers
That's a 200W total output, which in a four-speaker system means 50W to each speaker. Keep in mind that this is a peak output, not a continuous power output. When you shop for amps or head units, pay more attention to the RMS rating (most of the better brands will give you both). This is the amount of power the unit puts out continuously. The peak power rating is how much it can put out in a burst. Similarly for speakers, buy based on the RMS rating more than the peak rating - you want to know how much power you can safely pump into the speakers continuously - the RMS rating will give that to you.
By definition, RMS value would be (peak rating) x(.707) but for ease of use, look at a peak value and figure on an RMS (continuous) rating of about half that - it allows you to err on the side of caution.
For what it's worth, 25W continuous to each speaker may not seem like much, but a lot of factory stereo systems put 15W or less to each speaker. 25W by comparison is a significant step up.
Jul 09, 2008 | Car Audio & Video
Radio Communications Logo
43 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
