Question about Kenwood KDC-X590 CD Player
Multi pin connecter for car stereo
Hi, I have a kenwood cd reciever model # kdc-mp4032 and the multi pin connecter for power and high level speaker outputs is in disarray,I need the diagram for this coonecter showing me the placement of each lead into this connecter
  • 15,935 Answers
Need a stereo wiring diagram
Hiya,
Here's the wiring connections for the Kenwood KDC-3025.
Black: Car chassis (-) ground wire
Yellow: Battery (+) wire (must connect to retain memory settings)
Red: Ignition/Accessory wire
White (w/black stripe): Front Left speaker (-)
White: Front Left speaker (+)
Gray (w/black): Front Right speaker (-)
Gray: Front Right speaker (+)
Green (w/black): Rear Left speaker (-)
Green: Rear Left speaker (+)
Purple (w/black): Rear Right speaker (-)
Purple: Rear Right speaker (+)
Blue (w/white): Power Control wire (used with ext. amp only). Do not expose this wire, if no amp is used.
Blue: Antenna Control wire
Brown: Telephone Mute wire (used with handsfree carkits).
Hope this helps,
Cheers,
Scott
Feb 01, 2013 | Kenwood Sirius KDC-3025 CD Player
Kenwood kdc-152 protext mode
Disconnect the power, check your speaker wire connections behind the stereo and at the speakers. Reconnect the power and test.
Aug 19, 2012 | Kenwood KDC-MP2035 CD Player
KDC-MP4032 head unit wont turn on
hi, seeing that your kenwood showed up "protect" you may have an audio circuit/amplifier fault within the unit. try resetting the unit to see if unit comes "on" again. if the unit comes on and protect flashes again, then you definitely have an internal audio circuit fault. if not then check all power connections(yellow and red wire voltages, as well as ground connection), as well as the condition of the face pins!
May 31, 2012 | Kenwood KDC-MP4032 CD Player
I have a Kenwood car stereo KDC - MP4033 and the word "Protect" is flashing and i can't get it to work, no sound or stereo
check your speakers and speaker wires for shorts, and then disconnect power to the radio for a few seconds and reconnect it.
Nov 24, 2009 | Kenwood KDC-MP4032 CD Player
Need to reset the code on my Kenwood deck.
you should try the defaults 0000,0123,1234. in most cases unless you or the original owner put in the security code. Worse case it will just keep turning off till you get it right.
Apr 13, 2009 | Kenwood KDC-MP4032 CD Player
It turns off when in high volume
a few things...your speakers may not be a perfect match for the unit. at high volume where the radio starts to distort there is an internal protection circuit that protects the radio...it's kicking in.
solution.  Buy a power amp and take the load off of the radio.
Apr 01, 2009 | Kenwood KDC-MP4032 CD Player
Kenwood deck cd eject problem
Actually, yes! That could very well damage any unit without a protection mode. Unfortunately, in my long time experience in car audio, a deck that spits cd's out has a damaged or misaligned laser lens. This could be caused by driving to fast through pot holes, speedbumps, or going down train tracks. Find an electronics repair shop locally to see if having it repaired will out weigh a new deck. I found one new in box on ebay for $89 + shipping.
http://cgi.ebay.com/Kenwood-KDC-MP4032-KDCMP4032-AM-FM-CD-MP3-WMA-Remote_W0QQitemZ290298523697QQcmdZViewItemQQptZCar_Audio_In_Dash_Receivers?hash=item290298523697&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Mar 15, 2009 | Kenwood KDC-MP4032 CD Player
Kdc-mp4032
Hi, there
I think that there is a code error in your device. You should take it to a Kenwood store and they will put a new code in it.
Good luck.
Oct 18, 2008 | Kenwood KDC-MP4032 CD Player
Un lock code
hi you have 2 options:
1 - pay for the code/remote via kenwood service agent you will need proof of ownership
2 - send for re-codeing - the code system can be switched off.
we can do this for you if you are in the uk, please see: http://carradiospares.co.uk/kenwood-recode-p-213.html
Regards
Mark
Jun 08, 2008 | Kenwood KDC-MP4032 CD Player
Kenwood KDC-X590 CD Player Logo
142 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
