Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Picture on my rear projection TV
My Pioneer SD-T50W1 rear projection TV (1996 model)the video does not come on for a few moments when turned on. audio is heard immediately. Video screen shows a blank white screen for about two minutes and then comes on by itself.This only happens the first time it is turned on each day, after being off through the night.Any suggestions? THX Parnell M. Campbell (puzzled)
    President:
  • 3,130 Answers
Your set will one day soon not come on at all. theres several capacitors on the PIP board if your set has PIP or the capacitors in the power supply. A good tech should know where to check as this set some say is hard to work on but i quess its like anything you work on for a bit gets easyer. Call an authorized repair center for pioneer. Good Luck
Posted on Aug 13, 2006
SOURCE:
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer 52" projection TV, SD-533HDS,
It is likely that the CRT's (picture tubes or bulbs) are weak. It is a major job to change and all three should be changed to make the picture like new. However, it is not costwise to repair this old of a TV even if you can get the tubes. I estimate the cost of each tube is at least $200 each. I would call Pioneer and give them your model number and see if they are available. Only a trained technician should change the tubes because it requires a lot of time and setting up of the tubes and other things.
Jun 04, 2011 | Pioneer SD-533HD5 53" Rear Projection HDTV
Blue tint on rear projection tv
If this is a crts model , then one of the crts had blown, if it is a lamp rear projection, then it is a fault on the video circuit.
Mar 14, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-P4552 turns off immediately after turning on
Good Day, vash4056;
Don't dig a hole yet I'll will have to some more research.
Okay?? big IRISH.
Aug 07, 2008 | Televison & Video
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
Pioneer Tv SD-P4553
You have incomplete vertical deflection at bottom of screen. Replace C155(2.2uf@16v) on video/deflection assy. Use part number ACH1131
Feb 03, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
181 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
