Question about Samsung Tocco F480 - Pay Monthly Cellular Phone
Water damage.... my phone got contact with water and i can not turn it on again....
  • Anonymous Nov 30, 2008
    does turn on but touch screen isn't working...pls help
Having teens we have had many contacts with water and phones. A guy at TMobile told us to use a hair dryer, diligently for several days being patient, only low low heat. It has saved at least 3 phones and even one iPod that went throught the washer. Just be sure to lower the heat and don't do it for longer that about 10 minutes at one time. I hope this will help. you have nother to loose right? g.l.
Posted on Oct 24, 2008
Lg vx6100 won't turn on or charge
There may be liquid damage present. First using a flashlight, inspect the battery contacts and data/charging socket for green mold/water damage. If nothing unusual is discovered you could disassemble and inspect the inner circuit boards for white residue that would be left behind from water calcium, clean the calcium from the circuit board with a slightly wet toothbrush and dry with compressed air or a hair dryer.
Dec 22, 2013 | LG VX8300 Cellular Phone
Samsung galaxy ace, not sure if there is water damage as the phone has not been in direct contact with water but the phone wont turn on even with the charger plugged in.
check the battery condition usually the charging IC is the one which gets affected when it is contacted by water replacing it wont cost much
Apr 10, 2012 | Android Galaxy Ace
Samsung phone model B3410 after full charge turns off after 10 mons, phone was sent away and they rejected claim as they said it was due to water damage, but i know for a fact the phone has not had any...
Samsung warranty does not cover water or physical damage, you need to check if the phone was sent to a Samsung authorized service centre, if it was not then you need to call samsung.2ndly if the handset was assessed by samsung service center , and your adement that it was not water damage then you can contact another samsung service centre. or my all rights you can contact DFT
May 03, 2011 | Cell Phones
Looked at the timne this morning after being at work a little bit (started at 8pm) thought damn its going slow today looked again a little wile later said the same time 8:21 tryed turning it off wouldnt...
There could be many problems, but none of them can be solved by troubleshooting.
The two most likely issues are water damage, or a hardware/electrical problem caused by damaged internal components.
To determine if there is water damage, open the back panel and remove the battery. Behind where the battery normally rests, or below it, there will be a small circular sticker. If that sticker is white, then it has not been exposed to moisture. If it is any other color then your phone has water damage.
If you cannot find water damage then your phone is either suffering from a damaged hardware. However, in the off chance that your phone is only suffering from a minor error hold down the power button while the phone is not plugged in and there is no battery inserted for about one minute. Then insert the battery and attempt to turn the phone on.
If this doesn't help your only hope is contact your carrier and see if you can get it replaced.
Mar 21, 2011 | Samsung Wave S8500 Smartphone
I dropped my n97 in water immediately removed the battery and dried it as much as poss even left it in a bag of rice for 3 days to absorb any moisture but now my touchscreen won't respond any help would be...
The problem you are having is a common one. All water - even fresh water - contains salt. Salt is an excellent conductor of electricity. Once water comes into contact with the circuit board in your phone, and then dried, salt deposits remain.
The salt (even in minute quantities) begins to move around on your circuit board short circuiting anything it comes into contact with.
Even having your phone professionally cleaned and repaired does not mean that it will remain in good working order for long. You'll just be chasing good money after bad in the long run.
If you carry insurance on your phone with your service provider, I'd make a claim. If not, you should contact your service provider and make arrangements to purchase a new phone. You'll be much happier in the long run.
Feb 04, 2011 | Nokia N97 mini Smartphone
I have a droid 2 that fell in water it still works but the screen is to dark i have to put under a lamp to see the screen how to fix it to see the screen again.
Hi, what causes the screen to go dark,is because of the water that it fell in. It didn't try properly inside the phone. Water is not friendly with phone, they damage phones so easily.
The water has damaged the tube that makes the light display .
Phone is a little bit complicated, so i would advice you contact a skilled personnel for assistance in replacing the light that was affected by the water.
Thanks for using fixya...
Jan 11, 2011 | Motorola Mobility DROID 2 Cell Phone
HOW TO REPAIR WATER DAMAGE GT-S5620 BRAND NEW
First of all, do not turn it on, it could cause more damage to your phone. Take out the battery, and completely dry the phone before trying to use again.
Here is the procedure to take out all moisture trapped in the phone: Dry the phone, battery, any accessory, etc. with cloth and wrap each piece, phone and accessories, in newspaper. Place a few handfuls of rice into a plastic bag and then place the wrapped phone in the bag with rice. The newspaper wrapping avoids direct contact of rice with your phone because the dust from the rice can get into the small areas of the phone. The newspaper and rice will absorb moisture. Leave it there (with the bag open) at least 24 hrs. Hope this helps!
Jun 08, 2010 | Samsung SGH-a737 Cellular Phone
Samsung Omnia damaged
First of all, do not turn it on otherwise will do more damage. Take out the battery, and completely dry the phone before trying to use again.
Apr 15, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
Water logged mobile repair
you will never get it to work again, sorry, a chemical reaction happens imeadiately upon water contact, this causes catastrophic damage and is not recoverable.
Mar 22, 2010 | Motorola Mobility SLVR L7 Cellular Phone
My nokia 3110c was immersed in water and refused to turn on, after few month when i trie to switch it on is bring message "contact service" can i get help on this?
When a phone falls into water, there things that needs to be done fast in other to prevent damage on the phone because water is not friendly with phones.
Why contact service came up was because the phone was not attended to earlier.
When a phone drops into water, first you need to remove the battery in other to prevent I C in the phone to bridge, depending on the capacity of water that entered into it, some might make the phone start getting hot.
The phone you are using has two option:
servicing the phone,
or
the phone might not stop showing contact service.
When you service the phone, the contact service might go off or might still be displaying the phone.
It is a 50-50 trial, might work or might no work.
Take care and good luck.
Mar 21, 2010 | Nokia 3110 Cellular Phone
Samsung Tocco F480 - Pay Monthly Cellular Phone Logo
214 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
