Question about Texas Instruments Office Equipment & Supplies
Error message graphing derivatives
I am trying to graph the first, second and third derivatives and I come up with an error (ERR: INVALID DIM).
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Posted on Feb 14, 2012
  • 56 Answers
SOURCE: My TI-82 wontdraw graphs!
one of your stat plots is on. either go to 2nd y= and turn off yout stat plots. Or reset your caculator. 2nd then + then 7 then 1 then 2
Posted on Feb 05, 2008
SOURCE: my graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
Posted on Jul 15, 2009
  • 7993 Answers
SOURCE: WHen trying to graph anything, ERR: INVALID DIM
The easiest and quickest way to start graphing is to reset the RAM. Press [2nd][MEM][7:Reset][1:All Ram][2:Reset], then [CLEAR] to clear the RAM Cleared Message and go to the main screen.
Hope it helps.
Posted on Oct 16, 2009
  • 7993 Answers
SOURCE: ERR: INVALID DIM displayed on graphing calculator
The solution for the problem is simple. When you use the calculator to create statistical graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem. In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram every time you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Posted on Jan 16, 2010
  • 102366 Answers
SOURCE: ERR:INVALID DIM
Posted on Jan 23, 2010
Fix the ERR:INVALID DIM message on my TI-84 plus, please.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd, STAT PLOT , and
Mar 26, 2012 | Texas Instruments TI-84 Plus Calculator
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
Error message invalid dimensions
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
Getting ERR: INVALID DIM when pressing the Graph button
If the message appears when you try to graph functions deactivate the statistical plots. To do so:
Press [2nd][Y=] to access (STAT PLOTs)
Select [4:PlotsOff] then [ENTER]
That should solve your problem. Post a comment to this thread if you still have trouble graphing.If the message appears in another context, it sure would help knowing the context of the error.
May 12, 2010 | Texas Instruments TI-84 Plus Calculator
TI-83 Plus Calculator: I am trying to graph an equation and I get the "ER...
May 07, 2010 | Texas Instruments TI-83 Plus Calculator
Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Restart your graphs.
Dec 28, 2009 | Texas Instruments TI-83 Plus Calculator
When trying to graph anything, ERR: INVALID DIM appears..
Hope it helps.
Oct 07, 2009 | Texas Instruments TI-84 Plus Silver...
I get the error message ERR: INVALID DIM with
If you are in the stat mode and entering points in list 1 and list 2, it could be that one list is longer than the other.
If you are just trying to graph from the y= screen, one of your plots is probably turned on. The easiest way to fix this is to press the 2nd button the the plus button, then 7 and then 1 and then 2. This will reset to factory settings.
Jul 24, 2009 | Texas Instruments TI-83 Plus Calculator
79 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
