Question about LG Computers & Internet
How to open a lg monitor 196wtq
No power light when turned on
  • 1,684 Answers
Here is a link to a dis-assembly and repair guide that should get you going.
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate my solution.
BuddyMc
Posted on Feb 14, 2012
Testimonial: "that was exactly what i needed, thank you"
When I came home today the blue monitor light was on, but there was no picture. When I moved the mouse to get the monitor up, the light went out. I've tried unplugging it and plugging it into...
Here is a link to a repair guide for the LG L196WTQ. It sounds like you have a power supply failure and the guide shows how to open the unit, check the power board and then what to replace if you do find bad capacitors.
Problems like wavy or flickering picture, flashing power light, slow to display the picture or no power at all are all symptoms of a failed or failing power supply board.
BuddyMc
Jul 25, 2011 | LG L196WTQ Monitor
My LG monitor will not powerup
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 22, 2010 | LG Flatron L1919S LCD Monitor
Open lg 22' wide screen
disconnect all the cables except the power cable and then turn the monitor on you would see a test screen if it still happens your monitor is faulty and better buy a new one as repairing is usually expensive .
Apr 13, 2010 | LG 22" FLATRON LCD Monitor
The monitor LG Flatron L 1710S turns ON only for 1 sec and then turns Off. If  turn  On  again is  the  same
You may have capacitor failure (bulging or leaking) in the power supply (very common problems in ALL monitors), failed transistors or transformers in the back light inverter circuits, or bad lamps due to poor solder connections, poor solder joints on PCB. You need to open it up and look inside, post back what you see so we can guide you further. See example of failed monitors for guide: http://s807.photobucket.com/home/budm/allalbums
Mar 25, 2010 | LG Flatron L1710S 17" LCD Monitor
LG L196WTQ monitor just quit working. won't turn
Look in the power supply section first for bad caps, post back what you find inside, pictures will help a lot to guide you through, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 24, 2010 | LG L196WTQ Monitor
Lg Flatron 17" monitor turns on you see the green light then
it's prb.. your video card not the moniter if a moniter goes from green to yellow " standby" it's prb the computer not the moniter
Dec 27, 2009 | LG Flatron L1715S 17" LCD Monitor
My 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this monitor ? how can i fix this ?? ive confirmed 120v at power inlet and some dc voltage on various mini pins on...
Same problem as above. Had mine for 2.5 years and worked fine until I tried to turn it on this morning - won't come on at all. I have tried another power cable and verified that another monitor works on the old one.
Oct 03, 2009 | LG L1915S 19" LCD Monitor
LG 1718S-BN comp monitor, power light off; monitor won't display.
I know this may seem simple to you, and I'm not talking about the power light. Your monitor tilts up and down at the top of the stem connected to the base. At the top, where the stem connects to the back of the monitor is the hinge that allows the monitor to tilt up and down and it should be covered in plastic. You should be able to see what looks like a metal rod going through the stem and the monitor. If you squeeze together the plastic on both sides, they should come off to reveal the screws that hold the stem to the monitor.
As far as the power goes ... my first thought is a fuse (won't turn on and no power LED) or something has blown your power supply.
After you get it open let me know what you see.
borna49er@yahoo.com
Mar 04, 2009 | Computers & Internet
LG Monitor Problem
What I did?
are you interested?
nothing is opened on my monitor,
it's just sort of reconfiguring with the tool i downloaded from LG website.
If you're interested email me at xerrose@yahoo.com OR
just buy a new monitor and throw the defective(you think).
Sep 01, 2008 | LG Flatron F700B 17" CRT Monitor
Lg 19
Is it over heating? Is your computer set to let the monitor go into standby after a certain amount of inactivity? Check any and all power settings. Next time it happens, have a feel to check and make sure it isn't over heating...
Dec 18, 2007 | LG L1920P 19" LCD Monitor
Computers & Internet Logo
1,165 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
