Question about HP iPAQ H6310
My hp ipaq h6310 won't work anymore..
When i turn my ipaq on, the t-mobile loading screen appears and after loading the screen freezes...even if you turn it off, the same thing happens...all you can see is the t-mobile loading screen....can someone please help me out on this...tnx
  • 198 Answers
SOURCE: my Wireless in the iPAQ hx2415 doesn't work anymore
Hi man. Yes you should first upgrade/reinstall the ROM. That includes your firmware, OS and drivers. Go to HP's web site and download these uprgades. Here's a dirrect link. Select your OS from the list first. Follow the instructions that come with these files. If after this it still doesn't work please let me know.
Posted on Jan 30, 2007
SOURCE: HP IPAQ 6315 Auto Hard Rest
my ipaq6315 shutsdown and resets,i keep losing me pls
Posted on Jul 31, 2008
  • 31 Answers
SOURCE: HP Ipaq 2910 wont finish the boot
Hey :), I'd be happy to help. I honestly don't think that you've physcially damaged your Ipaq, so you should probally hard reset your Ipaq. To do this you must hold down the reset button and the power button at the same time for like 5 seconds. This will get rid of data on your pocket pc, but It might solve your Ipaq's problem. Thanks! and I hope this helps, if it doesn't I'd recommend for you call Hp where they will repair it or give you a new one :)
Posted on Oct 13, 2008
  • 4 Answers
SOURCE: Replacing PDA Screen - HP iPAQ hx4700
Posted on Mar 10, 2009
  • 2923 Answers
SOURCE: my ipaq 214 wont boot up.
You could have a corrupted program on your PDA. You need to contact HP and have them re-flash or upgrade the firmware of your PDA and it should work much better than before.
Have a great day!
Posted on Oct 11, 2009
SOURCE: Hp rx4540.How to access the Boot loader mode??
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
Posted on Mar 11, 2010
0 characters
1 Points
I cannot access windows vista to sync with my hp 6310 ipaq
Greetings - I'm going to guess that perhaps you installed Activesync 4.5, For Vista or Windows 7 you have to install Windows Mobile Device Center which is available HERE.
If you are using mobile device center that isn't the problem and Microsoft has a dedicated section of their website dedicated to solutions syncing Windows Mobile device with Vista, way too much for me to go over here. There's a great deal of trouble shooting information about sync problems HERE.
Thanks for using Fix Ya
Mar 16, 2011 | HP iPAQ H6310
I haw a ipaq but my newsdhc 4gb do not want to install.
This HP Ipaq runs on Windows 5.0 , which is an old platform. For 4GB SDHC to work u will require an advanced handset. Even if it accepts it will freeze or the screen will stop working. Finally u cant install 4GB SDHC on ur HP IPaq :(
Mar 14, 2011 | HP iPAQ HX2100 Pocket PC
My ipaq 214 wont boot up. it just freezes on the HP screen. Ive tried pressing the reset button like over 100 times but it just freezes again. Ive also tried hard reset and that dosent work either. I have...
Have a great day!
Oct 11, 2009 | HP iPAQ 214 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
HW6515d Ipaq Sound with TomTom Sat NAv
The ipaq 6515 has a microswitch that will turn off the pda if the battery cover is removed. When you remove the cover and try to turn it on even with the external power supply plugged in, the red led will light up.
Jan 29, 2008 | HP iPAQ hw6515 Pocket PC
I got the same problem. I even tried to plug the battery to the second battery charging slot, still couldn't get it back to life. But the Ipaq screen lights on with progress bar progress for about 5 seconds, then dead again. I even doubted the battery was toasted.
I gave it a final shot:
1. Remove the battery, and then put it back.
2. While the screen lights on, within 2 seconds, cold reset the unit by press the hole with stylus and push the power button at top in the same time.
In my case, the progress bar will keep going until I see the tap screen instruction and everything back to normal. But it reminds me that the removable battery is totally discharged. So I put it in cradle and I am able to synch it with my PC. Everything seems o.k. while it sits in the cradle, except the charging light won't turn red.
When I remove it from the cradle, it still lights on, battery shows 99% which is healthy. but when I turned it off, it won't start anymore. I have to repeat the above steps to revive it. Sometimes I have to remove the battery and wait for a while and then put it back, so that the screen can light on to give me chance to cold reset.
Conclusion: Maybe need a new battery. I will check Ebay to get one.
Please post if you have other solutions.
Dec 22, 2007 | HP iPAQ h6315/h6365 Pocket PC
Frozen screen
hello :-) i just talked to another person who was having the same problem as you. And guess what?? the same problem happened to me on my IPAQ 4350. It turned out when I would hard reset my IPAQ it asked me to align the screen but it wouldn't move and it would freeze and not let me pass . But I later found out that my screen was damaged and I got a new touch screen installed and my IPAQ works perfect :-). I would recommend for you to do the same and call HP and see if they could install it for you. Thanks :-}
Nov 05, 2007 | HP iPAQ H2210 Pocket PC
Doesn't move past the initial screen even on reset
If soft AND hard resets do not work, you definitely have a major problem. Sometimes, there will be problems that cause frequent freezes in the boot process. These freezes, in my experience, though, have been random, and in different places in the boot process. Try constant hard resets (patience is key, as sometimes they take a long time to load) until you get to the main screen. If you cannot get there, I really don;t know what to tell you. If you do, even once, refer to
for a permanent solution to your problem. (I know you two have different problems, but the solution should be one and the same)
Happy fixing!
Jul 17, 2007 | HP iPAQ RX3715 Pocket PC
IPAQ turns itself on
Go to the ActiveSync options of your pocket pc and to go to Mobile Schedule and choose "Manually". I think it's set to sync automatically in a few minutes that's why it turns itself on.
Sep 11, 2005 | HP iPAQ HX2100 Pocket PC
HP iPAQ H6310 Logo
19 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
