Question about HP DesignJet 500ps InkJet Printer
Broken printing We have a problem printing in a 24x36 paper in a full scale...if you are going totake a look at the pictures that I am posting you can clearly see the evidence and it sucks!!! and sometimes it's printing in a double lines how will we solve this problem? please let us know and help us..Thanks bony of Bij Joe lift....by the way we are using autocad 2007lt and a combination of adobe photoshop
  • 138 Answers
Try first replacing the ink cartridges. If you have done that already you probably need to do a printhead or carriage calibration. Below I have incuded a link to a free HP Service Manual to help walk you through it.
Hope that helps you.
http://www.feedroller.com/Store/Service%20Manual/DESIGNJET%20500,%20500PS,%20800,%20800PS%20Service%20Manual.pdf
Posted on Feb 19, 2009
How to shrink document to fit screen size when printing
Scaled Printing
The procedure for specifying a scaling value and printing a document with pages enlarged or reduced to match the document to the paper size is as follows:
1. Open the printer driver setup window, and select Scaled Printing from the Page Layout list on the Page Setup tab.
figure:Select Scaled Printing for Page Layout on the Page Setup tab
2. Using Page Size, select the page size that was set with your application.
3. Do either of the following to set a scaling factor:
Select a Printer Paper Size.
Select a printer paper size, which is different from the Page Size, from the Printer Paper Size list. If the printer paper size is smaller than the Page Size, the page image will be reduced. If the printer paper size is larger than the page size, the page image will be enlarged.6c3578e0-f243-44b0-aa8e-f7bb7752ed56.jpg
figure:Printer Paper Size on the Page Setup tab
Specify a scaling factor.
Directly type in a value into the Scaling box.
figure:Scaling on the Page Setup tab
The current settings are displayed in the Settings Preview on the left side of the printer driver.
4. Click OK.
When you execute print, the document will be printed with the specified scale.
Note
If the application software with which you created the original has the scaled printing function, configure the settings on your application software. You do not need to also configure the same setting in the printer driver. When Scaled Printing is selected, the Staple Side list box appears grayed out and is unavailable (when Duplex Printing is not selected). When Borderless Printing check box is checked for the Page Layout list, Scaled Printing cannot be selected.
Tip
Selecting Scaled Printing changes the printable area.
Hope this helps
Mark
Sep 13, 2014 | Canon PIXMA MX310 All-In-One Printer
How do i only print black n white pics
Hello!1. Please press Ctrl + P after opening your picture.2. Go to Set up/Advance.3. Select your paper.4. Select Gray scale on the top of your paper size.5. Now press print. Your picture will be print with black & white... Good luck
Jun 09, 2011 | Canon iP2700 Inkjet Photo Printer
My printer won't print on a full scale.. meaning
this has to be set from the wizard for the printing job ...look for the edges size..but when you print on paper ..something like a full size A4 image ...it will always leave a 5 mm edge as default setting ..But like I said..initiate printing ..and in that wizard set the edge to 0 or ..click to remove edge if it is possible..anyway if it is possible there is the only location where you can change it ...and I'm not sure if it can be done permanently
Apr 29, 2010 | Office Equipment & Supplies
How do i get full size 24 x 36 at 1/4" scale?
I just ran through the HP site and it now appears that the GL2 code is an upgrade item.
I also now believe that you need to be able to manipulate the image in an application such as Adobe PhotoShop family or Adobe Illustrator.
So we come back to exactly what are you tyring to do? How is the image being sent to the printer"? Does your printer driver allow you to do "NUP" printing as in "4UP". This allows the printer to automatically reduce the image of 4 pictures on the 24X36 page.
Don
Nov 18, 2009 | HP Designjet Z2100 InkJet Printer
My HP DesignJet 330 prints for the first 6" of 24x36 paper. Then the led lights start to flash. The printer keeps going, yet no ink goes on the paper
Guys
1. Thanks for coming up for air
2. We figured out the problem
3. It's a master panel board in the bottom right corner of the printer
4. At this time we will be throwing out this HP 330 and getting another
Thanks for your help.
Oct 01, 2009 | HP DesignJet 330 InkJet Printer
Printing grayscale
in MS office you change pictures 's colour and print them in garyscale go to picture tool bar and change its colour and in printing prefrence from printer properties change dpi setting to save ink
Aug 09, 2009 | Dell 810 All-In-One InkJet Printer
The images are too big.
go to the printer perference or setting on your pc, there is option says scale to fit the page, click it , and some of printer allow you to select the paper size you are using. its simple problem its just driver setting issue.
Good luck
Mar 19, 2009 | Dell Office Equipment & Supplies
Printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Nov 01, 2008 | HP Photosmart C4280 Aio Printer
HP 500 inkjet
You need to firstly have an HPGL2 card in your machine with the additional 128Mb ram chip. Secondaly you need to do an advanced head alignment and thirdly in your drivers set your memory to "not run out of memory" under the advanced tab.
Regards
Dave
Oct 27, 2008 | HP DesignJet 500ps InkJet Printer
Print Orientation issues
find autorotate in the driver. find paper settings, more sizes, arch b, then pick that for those smaller plots. Good Luck!
Oct 14, 2008 | HP DesignJet 500ps InkJet Printer
HP DesignJet 500ps InkJet Printer Logo
151 people viewed this question
Seeker5211
Seeker5211
