Question about Haier 32 in. LCD TV
Audio ok no video - Haier 32 in. LCD TV
Tvs3290yhb. main board mt8227. Video OK but why no audio?
Check whether the audio is muted by accidental press at remote control button. Enter its sound menu, and check it. If muted, as you know there will be no audio output. If not muted, check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Feb 01, 2016 | Sansui Televison & Video
I downloaded the new vidzone app,and it downloaded ok and installed ok but when i start it it loads every thing but refuses to stream any videos.all i get is the video advertisments but no music or videos...
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
May 10, 2010 | Sony Playstation 3 (PS3) Console
I am hooking up a new HDTV Yamaha YHT-292 LG 42" LH55 LG Blue ray Video Blueray to receiver to HDTV OK Satellite to receiver to HDTV OK Audio Receiver to FM tuner sound OK No sound from Satellite or Blue...
what audio cable type are you using, if its digital, you might have to assign that digital audio input with the video signal? go back over your cabling, and make sure the audio is not going to the wrong input and also check that SP/DIF (coxial or toslink) is enabled on the setup menu for the blue ray player and satilite, they normally disable it by default to save a little bit of power, also on a yamaha receveir should have a indication light that lights when a signal/decoding is in action, refer to your documention and trouble shooting section of the manual, hope this helps
Toby
Mar 21, 2010 | Yamaha HTR-6090 Receiver
No video
Send this to them.
Normal 0 Web Camera’s have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype set it up as follows:
  1. Go to TOOLS, then OPTIONS, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
  2. Then click on the Video Settings.
  3. The camera if installed properly will come up and show a picture.
  4. Then on the bottom of the page click on Save.
The camera and audio should function properly. Your friends and Family will now see and talk to you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger set it up as follows:
  1. Go to Messenger at the top left and click on it.
  2. Next go down to Preferences and click on it.
  3. Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
  4. Next go to the Test Audio section and (in blue writing) click on “Open the call setup assistant” and follow the instructions on the left window.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
Hope this helps. Bud
Oct 16, 2008 | Computers & Internet
No sound on olympus sp-55ouz video playback
To turn on audio, go to the video setting. Hit the menu button. Hit ok to select the camera menu. Go down to the picture of the microphone and hit ok again. Select on and then hit ok again. Your sound should be set. Hit the menu button twice to get you back to taking videos.
Jul 13, 2008 | Cameras
Samsung VP 500 L Help !
BAD CCD. SAMSUNG IS KNOWN FOR THIS. YOUR OLD TAPES WITH GOOD RECORDINGS PLAYBACK GOOD? YOU CAN RECORD AUDIO BUT NO VIDEO ? IT IS A BAD CCD
Oct 17, 2007 | Samsung VP-W70U Camcorder
Help me
first, verify your taped video is ok by doing this: connect your audio out RCA jacks to a cable to the input of a stereo. now play it. if audio ok, then problem somewhere from audio amp section to speaker on SONY.
Jun 05, 2007 | Sony Handycam DCR-TRV265E Digital...
Haier  32 in. LCD TV Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
