Question about Ingersoll Air Tools & Compressors
INGERSOLL RAND SS3P OVERHEATING OF CYLINDERS
AIR COMPRESSOR WILL OPERATE NORMALLY UNTIL AFTER 15 MINUTES OF OPERATION UNTIL IT REACHES NEAR CUTOUT POINT, THEN BECOMES TO TIGHT, THEN KICKS THE MOTOR BREAKER OUT IT IS A MODEL 33SP COMPRESSOR FROM INGERSOLL RAND
  • ttkreider Feb 14, 2012
    IT IS ACTUALLY A SS3P NOT A 33SP
    THE HEADS AND LINE THAT FEED THE AIR TO TANK BECOME SO HOT IT HAS DISCOLORED BOTH
    Genius:
  • 1,212 Answers
Heat in that location noted is to be expected, but to the degree that it is should be of some concern.
When was the oil changed in the compressor last?
If you are running with a multiviscosity oil, use it only if the manual indicates it. Running straight weight oils, especially in extreme conditions is prudent insurance against failure. If you are running 10W20 for example- run 20 weight instead until regular air temps are below freezing- then the switching to 10 weightshould be a consideration..
The oil sump serves 2 purposes- 1- Coolant. 2-lubrication.
However I think the bearings in in the compressor are needing attention.
More because it sounds like there is an oiling problem in the compressor itself. At an absolute minimum it sounds like the head should be pulled to inspect for galling in the cylinder walls and to look for trace oil on the cylinder wall.
Posted on Feb 14, 2012
  • 583 Answers
SOURCE: ingersoll rand compressor T30 model 7100
I would wonder A if the wiring was heavey enough to carry that sort of load with out overheating B if the motor is big enough to do it for the same reason( ?what is the duty cycle?) C if the receiver is big enough to allow reasonable time between shut down and start up --- remembering that at start up the motor pulls double the current to start up and if it doesn `thave sufficient time to cool alittle before being called on to do it again and that would prompt the question ,does it have sufficient ventilation? these are all queries that would need addressing before I would try to offer a solution ,one thing is certain ,--there is something wrong
Posted on Aug 17, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 243 Answers
SOURCE: i have an ingersoll rand P185WJD Compressor that
possible that one of the protections switch it off check oil levels motor and screw can also be a sensor, can check these by briging them one by one. first indication is control lamp. or possible fuel problem check filters and tank. also check wiring complete. is weak point for ir machines. good luck.
Posted on Feb 10, 2010
compman66
  • 169 Answers
SOURCE: what type of oil for ingersoll rand model 2475 air
Ingersoll Rand likes you to buy their all season select oil for their air compressors, most piston air compressors use an R+O 100 oil it is equivalent to n SAE 30 wt oil.
Posted on May 12, 2010
al_kupchella
  • 843 Answers
SOURCE: I have an Ingersoll Rand
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Posted on Aug 30, 2010
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
When max pressure reached engine dies instead of idle down
Has Pressure Switch Issues - About Air Compressors
www.about-air-compressors.com/has-pressure-switch-issues.html
Many times folks think that they have a pressure switch problem since air leaks out the ... The pressure switch does not kick off when the compressor has reached itsmaximum pressure. ... compressor sits humming and trying to turn the motor insteadof cutting out. It is a ... I have an old, about 20 year old, Ingersoll-rand T21.Missing: idle
[PDF]21 Front St. - Celtic Distributors Ltd
www.celticdistributors.com/content/Celtic/.../BasicCompressorTraining.p...
The air compressor motor and/or engine will get hot while in operation. .... enters thru the intake ?lter and the intake valve on the down stroke of the piston. .... My gas unit builds pressure but instead of idling the engine dies? 0 Check ... most single stage compressors only reach maximum pressure of 125 to 135 PSI. A slight.
[PDF]ALTRONIC GAS ENGINE GOVERNOR OPERATING ...
www.altronicinc.com/pdf/engine-controls/govinstall.pdf
Dec 16, 2015 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
Hi,I got a Ingersoll Rand type 30 model 234 compressor.It looks good but it has no motor.I'm thinking like 120v,3horses?,but not sure about rpm.any help would be nice.thanks
According to the information you provided your looking at a 10 HP motor at three phase. Do you have three phase at your location? If not I would look into getting a single phase compressor. If you do want to get it going I would notify your local IR dealer so they can get you the right Model number, RPM, Pulley and Motor Frame Size to match your unit.
Please read below....Jim...if this helped you please send me a positive response...Thanks!
Ingersoll-Rand Type-30 Electric-Driven Two Stage Horizontal Air Compressor - 120 Gallon - Fully Packaged IR 2545E10VFP
  • Designed for heavy shop or industrial use, Ingersoll-Rand Two-Stage electric air compressors provide the quality and performance that are ideal for most applications and users, including: automotive service and body shops; fleet maintenance; machine shops; production and manufacturing lines; construction; wood working shops; dry cleaners; car washes; maintenance/repair shops and farms.
  • Durable cast-iron, two-stage design offers extended pump life for years of trouble-free service 175 PSI maximum operating pressure
  • 100% continuous duty for tough applications
  • Automatic start/stop control/pressure switch operation
  • Includes motor starter, oil sight glass (10-15 HP only), manual drain and ASME tank
  • 10HP, 3 Phase 200, 230 or 460 Volts
  • 120 gal, horizontal tank
  • 35 ACFM @ 175 PSI
Feb 14, 2011 | Ingersoll Rand Type 30 Electric Driven Two...
What is the spec on a ingersoll rand type 30 model 15
Hope this is sufficient information:-
Two-stage Type-30 replacement compressor pump for Ingersoll Rand Type 30 Reciprocating Air Compressors. U.S.A. Max. PSI: 175, HP: 15, Flywheel Diameter (in.): 18, Total Cylinders: 2, Bore Diameter (in.): 5 1/2 and 3, Stroke Length (in.): 4
Jan 25, 2011 | Garden
Air Tools & Compressors Logo
331 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
