Static electricity shorted as I went to turn my speakers off. now I have no sound, but the power light comes on.
Static electricity shorted from my finger to the off / on switch. Something shorted out and now I have no sound. The power light still comes on. There is nothing obvious on the circuit board. Any ideas?
  • 27,725 Answers
Click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow question / exclamation ? ! mark or a red X right click to update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
if your computer came with a motherboard disk the drivers could be on it
hope this helps
Posted on Feb 14, 2012
Static sound builds up in the sub pops, then no sound comes from it. The sound comes back once I reconnect the power source and fiddle with the power plug. The problem then repeats.
Look for a wire strand or solder splash on any circuit boards or connections that might be 'almost' shorting out anything. Next, if there are any metal screws with very pointy tips (like sheet metal screws) that might be just a smidge too long and clip the very tip off so that it can't possibly short a frame to a component.
The idea is to find any reason why electricity might be bleeding over into another area of a circuit board that uses capacitors where a charge could build up causing the symptom you are describing.
May 09, 2016 | Altec Lansing Audio Players & Recorders
I have a panasonic pt-56lcx16 and it needed the bulb replaced, i got a new one and installed it. I turned on the power button on the tv, then it makes a electricity sound where the bulb is but doesnt come...
If the electricity sound was loud and static sounding then you had a short with arcing which is not good and you blew a board or the socket that the bulb went into. Check that there is current at the bulb fitting.
Mar 02, 2014 | Televison & Video
Speaker produces noice/static/buzzing sound when it is off
That means that if too much power is going to the speaker or extraneous signals are being picked up by the wiring, it can come through the speakers as static. Stopping static requires finding and eliminating that extra electricity from transmitting through your speakers.
If you're still hearing distortion, turn down the volume on your amplifier until the distortion goes away. If the volume is too low to be easily heard, the problem may be that your amplifier produces too much power for your speakers to handle or that your amp and speakers have different impedance ratings.
Apr 04, 2017 | Boston Acoustics Duo-i Horizon Clock Radio
Static electricity shock blew a circuit for the speakers. The power light is on, but no sound.
click start control panel administrive tools computer management device manager scroll to sounds video and game controllers ther might be a yellow question / exclamation ? ! mark or a red X right click to update driver
hope this helps
Feb 13, 2012 | Altec Lansing ACS 45.1 Computer Speakers
There is static coming out of my speakers on my stereo. I I checke to make sureall the wires are connected properly and the power is plugged in securely. There is static with the sound on all...
Don't worry, it's more possible that you have the static electricity and through your stereo this electricity goes to the ground. Try touching another metalic surfasce (refrigirator, oven etc), try to change your shoes (especialy if your stereo is on a carpet floor and you walk on it) Sometimes when we are very nervous the static electricity on our body is higher. So keep calm.
Stelios.
Feb 20, 2010 | RCA WSP155 Main / Stereo Speaker
Lights are on in the small speakers but no sound is produced...there is a short scratchy sound when I juggle the speker wire from sub woofer. I hooked speakers up to a different MAC and now am trying to...
Hi there , the green light just means its getting Power, it doesnt mean that its going to give sound, It could be that you dont have Drivers installed for your Sound card which is causing it too not get sound , but when it makes that static noise , its the Wire just causing Static with the Sub , just means its getting power , The + and - sign is the volume control ...Try see if you can turn it louder with the + . maybe it is low enough not too hear.....Hope this helped Bud
Happy new year.
Jan 03, 2010 | JBL CREATURE II Computer Speakers
Clip light
It sounds like one side of the power amp has shorted. May be hazardous to the speaker so best take it to a shop for repair. If speaker stills sounds OK, probably the clip detector transistors have failed.
Nov 08, 2009 | Behringer Eurolive B212A Speaker
Static noise from Front Left Speaker
It would probably be with the speaker. That is easily checked by simply unhooking the speaker and running the test again.
Jan 15, 2009 | Yamaha RX-V661 Receiver
Static noise coming from interior rear by speakers
CHECK REAR AMPLIFIER (INSIDE TRUNK) BAD CAPACITOR OR BAD CONNECTION. REPAIRED MINE TODAY.
COST $30.00-
Jan 08, 2009 | 2003 Jaguar S-Type
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
147 people viewed this question
 Grubhead
Grubhead
