Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My whirlpool cabrio washer is stuck on sensing
5 Suggested Answers
Nicesuit
  • 61 Answers
SOURCE: I have a Whirlpool Cabrio washer (WTW6400SW). It
try cleaning the dispencer first, it has a small syphon assembly in it whcih can get blocked with concentrated fabric softiner and sometimes powder.
Posted on Jul 30, 2009
  • 180 Answers
SOURCE: Whirlpool Cabrio top loading washer F1 Error
F1 means the control board is shot. Call whirlpool and they should take care of the parts and labor even though your machine is out of warranty.
Posted on Nov 27, 2009
  • 122 Answers
SOURCE: Whirlpool Cabrio WTW6600SBT Top Load
f1 is the error code for your main control board at console, replace boad
Posted on Aug 22, 2010
blueextc3221
  • 15935 Answers
SOURCE: display shows F1 top load cabrio whirlpool washer
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
Posted on Sep 20, 2010
Cabrio Washer Problems
That error means that it is sensing an OVERLOAD. If it does this when it is empty, then there is something causing the error. IT could be something stuck in the drum around the seal or the bearing or it could be the bearings itself
May 02, 2013 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
My cabrio wtw5500xw starts sensing then it won't stay locked to start the cycle
This is a common problem with the Cabrio washer. The RPS sensor needs to be replaced. Here is the part to order.
Here is a video to show you how to do the repair.
Nov 10, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washer cabrio stuck on spin cycle
solution- ID- is in the control program and the door lock. If, there is any warrenty on it, call Whirlpool and a Tech can help you with it.
Sep 10, 2012 | Whirlpool WTW6400SW Cabrio Washer
Washer saying f 50 whirlpool cabrio
f50 is a stalled motor fault. try to move drum freely. if stuck look and see for anything obvious.
another problem could be the rps sensor not sensing the motor turning. check sensor for anything in its way. hope this helps
Jun 20, 2011 | Washing Machines
What does sensing mean on a whirlpool cabrio
This means that the washer is sensing if there is enough water in basket with quantity of cloths.
Jun 10, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine motor not turning when loaded but turning when empty, and it's getting hot.
Inspect the rotor position sensor for loose or frayed wires. The washer tub and motor are all suspended on 4 rods. See page 59
More about the rotor position sensor is on page 57 of your service manual.
Whirlpool Cabrio Washer with 6th Sense Technology.pdf
Google Docs. 16 megs. Printable version.
Was this helpful?
Sep 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Display shows oL - Top-load washer
That oL is overload. You need to remove some clothes. On this model the motor can sense to much weight in the washer. If it does it without any clothes in there check for something jammed between the tubs.
CABRIO SERVICE MANUAL
May 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Another Whirlpool Cabrio Sensing issue
Hi-- none of the solutions I've read here are working. Same problem, dryer not starting, it says "Sensing..." and then "Wet" and does nothing. It worked fine on the last load, except I noticed it read 11 minutes for a very, very long time (I think it got stuck). New load? "Sensing..." etc.
Mar 29, 2009 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
F1 error on Whirlpool cabrio
it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,208 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
