I was unable to find any mention of "AV Mode" in the user manual.
The user manual is available for download from here: (click here)
SOURCE: panasonic sdr-h80 will not download videos to pc.
u can download here put your download driver query here and download driver free for refine your search use drop down section
SOURCE: software incompatible window 7
Step by step instructions for Windows 7 32-bit follow:
Insert the Panasonic CDROM.
Don't use autorun - Cancel autorun popup.
Right click on CDROM drive in "My Computer" and select 'Open'.
Right click on Setup application & choose 'Troubleshoot Compatibility'.
Select 'Troubleshoot program'.
Select "The program worked in earlier versions of Windows but won't install or run now' & click
the "Next" button.
Select 'Windows Vista (Service Pack 2)' & click the "Next" button.
Click on "Start the program..." button.
Proceed with program installation.
When installation finished cancel out of the 'Program Compatibility' window.
If you have Windows 7 64-bit the instructions are:
Insert the program CDROM.
the "Next" button.
Installation will start.
VideoCam Suite will probably be flashing on the taskbar so select it.
The window will show: 'This application does not support this 64-bit operating system. Are you
sure you want to install?'
!!! Click the "Yes" button !!!
SOURCE: Importing Video to PC with Panasonic SDR-H80
There should be an extra cable that plugs into the battery charger and then into the camcorder to supply power to the camcorder.
SOURCE: Connecting Panasonic SDR-H80 video to PC / Mac without AC lead?
hi, you can record on a SD card that you can then remove and read through an SD card Reader (a usb key where you slip the card and pof! you have it).
For the Mac/ Pc/ Power adaptor I have the same problems. tell me if your quest for knowledge was fruitfull anywhere else.
W
SOURCE: how to download video from panasonic SDR-H80(PC or MAC)
Google a program called
Video Download Studio
then you can use it FREE download video or audio form YouTube, google, metacafe, redtube, dailymotion etc. attention: download function is no need to register
you can also use it to convert video to audio, video to video, audio to audio.
use it convert video to mp3 mp4 for your iPod
tutorial;
http://www.downloadvideos-convert.com/how-to-use
