Question about AT&T Blackberry Curve 8300 Smartphone
8300 will not charge
Neither charges on USB port or original charger. The USB port on the phone does not seen active. What can I do, I'm out of battery already
  • mfisher916 Nov 04, 2008
    Have the same problem...phone is plugged in, shows that it is charging but battery power is not increasing. Have taken the battery out and put it back in, and did a full power down and it still isn't working. Not in a place where I can plug into computer. Going to alltel this afternoon...
  • Anonymous Jan 03, 2009
    Im having the same problem and don't know how to fix it
My charge port is broken out of my 8300. I bought an extra battery and an external charger off of eBay for a little of nothing. You can also by a pod that will charge your Blackberry. The two gold tabs on the back of your device beneath the battery is an external charger connection for a desktop pod.
Posted on Nov 25, 2008
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
My iphone won't charge
Please try your charger with another iphone.
Try a friends charger with your iphone.
If your charger charges your friend iphone, your charging port may be bad.
- If your friend's charger works with your phone, then your charger may be bad.
Mar 30, 2014 | Apple iPhone Cell Phones
Iphone will not charge..... message says charging is not supported with this accessory.
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Oct 21, 2012 | Apple iPhone4 4G iPhone 4
Omnia 2 charging problem
I have the same problem with mine, It charges fine when its turned off and plugged into the wall charger but dussnt recognize the charger when its on. kinda retarded. Could be a manufacturing fault thats coming up now =(.
Planning on sending it in coz its still covered under its warrenty. I suggest you do the same if yours is, otherwise u might just have to charge it from the usb port from now on... kinda dissapointing from samsung, thought they wouldve defntly got everything together after the original omnia failed so much
Jun 26, 2010 | Samsung Omnia Cell Phone
Will not charge
Are you using the AC Adapter, or USB sync cable to computer to charge? If using your computer to charge, you will need to have USB Driver for your BlackBerry Model installed. Download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5It
Could also be that your USB Port on your BB is damaged. You can use an external Battery Charger to charge your Battery http://www.amazon.com/Blackberry-External-Battery-Charger-8300/dp/B002YGYLA8/ref=sr_1_2?ie=UTF8&s=wireless&qid=1263514496&sr=8-2
Dec 23, 2009 | AT&T Blackberry Curve 8300 Smartphone
My phone went out of battery last night, today i have put it to charge from my computer for three hours but it is not working yet
try using the travel charger if that does not work then try another battery if it still does not work then you may need to either reflash the OS or replaced the USB charging port.
Sep 09, 2009 | AT&T Blackberry Curve 8300 Smartphone
My blacberry 8300 wont charge up , i think my charger terminal on my fone is not working can ne1 help?
If you are sure that your charger is ok, then it is the USB port on your phone. This can be replaced. Please contact me or another dealer near you from the Cellular Repair service directory at the buttom of the page for help on this
Mar 12, 2009 | AT&T Blackberry Curve 8300 Smartphone
No power
Make sure you have an original OEM charger for the MDA. Many of the knock off chargers don't provide the right amperage for the device. What happens is that since the phone is completely dead, it can't regulate how many amps the battery should get during the charge and an incorrect charge current won't charge the battery. I'm guessing that someone sold you a Motorola RAZR charger or another knockoff made for the RAZR. This might charge your phone when the battery is working, but not when it's DEAD. Also you won't have luck plugging it into a computer USB cable because, again, the phone can't tell the computer what charge to send and most computers only produce <0.5 amps in the USB port.
Get a charger that states it is an OEM (original eqipment manufacturer) device or one that is specifically designed for the MDA (or Cingular 8125). eBay is full of them.
Bad charger (probably won't work for a dead battery)
Good Charger (correct amperage and designated for the MDA)
Jul 08, 2008 | T-Mobile MDA
Motorola W370 will not charge
Motorola provides a USB driver for just charging the W370. I installed it using the installation instructions from the Motorola website, but it just wouldn't work. The USB driver would install but would not activate (error Type 10). The W370 said that it could not charge. I recommend not bothering with this device driver, at least not with Windows XP.
However, I did figure out how to get the W370 charging from a USB port by trial and error. It's a pretty simple process.
1. Before plugging in the USB cable, turn on the W370 and wait for it to fully boot.
2. Connect the phone to the USB port of the computer.
3. When the phone asks "Connect phone as storage Device?", press the phone's left soft key, choosing "YES".
4. The phone will say "Please Wait...... Connecting Phone as Storage Device"
5. Eventually, the phone will display a white screen with the message, "In storage mode, no regular phone activities can be done."
6. Flip the phone closed. The yellow battery indicator will be lit. The phone is charging.
You'll note that the computer will see the W370 as a storage device with around 512 Megabytes of free memory, with empty "picture" and "sound" directories. The W370 appears to be a generic mass storage device to the computer. No special device driver is needed to charge the W370!
Mar 02, 2008 | Cell Phones
AT&T Blackberry Curve 8300 Smartphone Logo
517 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
