Question about Whirlpool Electric Range
Whirlpool Electric Range Model WGE83301 oven won't work
Oven doesn't work, burners do work
jsrock516
  • 5911 Answers
SOURCE: Whirlpool electric range model # RF261PXSQ oven not heating
I'm afraid you may have a blown Electronic Oven Control (EOC) board. The EOC controls all the functions of the oven. The surface elements are controlled by individual infinite switches behind each control knob.. That's why the surface elements all work, but the oven does not. A replacement EOC can be purchased on line at searspartsdirect.com. Just type in your COMPLETE model number and you will find it under the "Control Panel Parts" heading as item number 12. There are several listed, based upon the color you need (White, Biscuit, and Black). This is a very simple repair that any do-it-yourselfer can accomplish if you wish to perform this on your own. All you have to do is UNPLUG the appliance and remove the back panel of the console to access.
Before assuming the EOC is defective, however, inspect the board to see if it has a fuse on it. I do not have a wiring diagram to confirm. Some of these boards do have fuses and that's all that it may take to repair it. However, if the board shows signs of burned components, replace it. NOTE: Check for any loose connectors to the board as well.
I hope you find this information helpful. Let me know if you have questions and/or require additional assistance.
Posted on Sep 25, 2008
huuum
  • 750 Answers
SOURCE: whirlpool electric range burner power light stays on but no heat
Hello givemeanidth.
Welcome to Fixya
You said, have a Whirlpool electric range (model rf363pxpt0) with standalone burners - the burner power indicator light stays lit whether the heat control knob is on or off, there is no heat coming from the burner on or off. You pulled the burner from the receptacle and one of the tabs broke off and stayed in the receptacle. You removed the tab and made sure no pieces remained in the receptacle then bought a replacement burner, no change. You put the replacement burner in the back burner of the same size and had heat within 10 seconds. You changed out the burner with the one that had been in the back of the range, no heat. As long as the breaker to the range is on the power light stays lit but no power to that one burner only.
What is the model number and the age of your range?
Waiting for your reply.
Huuum
Posted on Oct 03, 2008
SOURCE: whirlpool electric range won't work
We read on another site that sometimes an electical surge messes something up and that if you unplug the range for a few minutes it will reset. So we unplugged our range and when we plugged it in again it worked fine.
Posted on Mar 24, 2009
SOURCE: Whirlpool eletric range model RF363PXDW w/F1 display
The manual to this oven is here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196274.pdf
That should fix almost any problem you have
Posted on Apr 03, 2009
jsrock516
  • 5911 Answers
SOURCE: Opening the cook top in a Whirlpool electric range
The cooktop on this model range will lift up, exposing the surface burners and wiring harness. The screws are located along the bottom of the frotn edge of the cooktop. You will need to open the oven door to see them. Just follow these steps:
Before you begin:
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
a. Unplug the cook top and leave the elements in place.
b. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
c. Remove the bad surface element by removing only the bracket pair that the affected element is attached to. Leave the rest of the elements wired together. Write down the wire color codes so you can be sure the new element is installed correctly. HINT: A digital camera can save you some time.
d. When installing the new surface element, make sure you use the same alignment marks (the numbered positions around the perimeter) as the old element. Avoid touching the burner surface and handle with care. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure. The elements are fragile.
If the wiring harness does NOT unplug, prop the cook top in place and install the surface element from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
If you have any questions about this repair, please let me know. You can reference searspartdirect.com for some helpful exploded view diagrams of you range for assistance if you need it. I hope you find this information helpful.
Posted on Nov 12, 2009
Testimonial: "Did not update until late, thanks for the detailed directions. No hinges on my stovetop, just detach and remove. Thanks, again!"
Oven won't come on
Test the temperature sensor in the oven to make sure it ohm's out between 1060-1100 ohms. Here is the sensor to order in case it is bad.
Nov 30, 2012 | Whirlpool Electric Range
I have an electric whirlpool range model RF368LXPQ. The stove and oven quit working but the clock still works.The day after it quit working I tried it again and a burner started to work. Once turned off it...
Maybe unplug your power cord from the wall and check the connections on the range. Ranges do not come with power cords attached on them. The installer has to put the cord on, maybe they didn't get the connections tight. While you have the cord unplugged it may be a good idea to check the power at you outlet in the wall and make sure you have 220 volts on it. You will need a volt meter to do this, be real careful not to touch the probes while checking this. Please rate my answer so I get points for it.
Jan 16, 2012 | Whirlpool RF367 Electric Kitchen Range
My whirlpool oven locke with F5 E1 what to do
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks
Oct 05, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
I have a Whirlpool Electric Range GY399LXUS. The oven will not turn on. The top burners work, the only button that works on the keypad is the warm button.
I am an Appliance Technician...... and you need a new clock/ECM The part where the clock is & the oven controls... under there is a big circut board that is basicaly the motherboard for your oven. And I'm sorry to inform you that I just used your model number to look up the board and it is NO LONGER AVAILABLE.... that means they just don't make that part for your oven anymore. Whirlpool didn't use that design very long because they didn't sell well, they were expensive to produce, and they had a few too many problems out of em. So BAD NEWS is they don't make the part you need to fix your oven....GOOD NEWS is you get to go shopping for a Range!!! And BUY WHIRLPOOL!!!!!! DO NOT BUY LG,SAMSUNG, GE, FRIGIDAIRE, OR ELECTROLUX!!!!
Aug 05, 2011 | Ovens
I have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Stove top ignitors do not ignite but oven does.
Mar 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Whirlpool  Electric Range Logo
273 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
