Question about Toshiba 43A10 43" Rear Projection Television
Screen comming away form housing
My cat jumped up on top of the tv and the screen has come away from the side how do i fix this
    President:
  • 3,130 Answers
I need a picture as I dont understand how the screen can come loose?
Posted on Aug 13, 2006
I'm having issues with my secondary clutch belt riding high on taking on the housing. It is a 2012 artic cat mud pro. How can I correct it?
mudpro issues - ArcticChat.com - Arctic Cat Forum
www.arcticchat.com > ... > ATV's > General ATV Discussion
Apr 11, 2012 - 10 posts - ‎5 authors
It seems that the belt is riding to high in the secondary clutch and there for hitting thehousing. The top of ... As far as the housing gasket my OEM gasket on my 02 was metal and can be reused. If yours is ... Take it to the dealer. 2009 700 H1 with oil in belt housing issue
Jan 6, 2014
H1 clutch side disassembly
Nov 2, 2011
water in belt housing need help!!!!
Apr 25, 2011
clutch housing clearance for belt rubbing
Jun 3, 2009
More results from www.arcticchat.com
Dec 28, 2015 | ATVs
Jumped solenoid now no power
Sounds like you blew the fuse under the seat
here are the service manuals for all Arctic cat ATVs
Parts House Lawn Mower Parts and Chain Saw Trimmer Parts
Feb 19, 2014 | Arctic Cat 2004 500 4x4 Automatic TRV
I have a Samsung LN46A650 LCD TV and recently I started getting a white line across the top of the screen. Sometimes the white line is thicker on the left side of the screen. Sometimes after the white...
Yes, it's the t-con board, a well know problem in this tv. Here it is
http://www.partstore.com/Part/Samsung/Samsung/LN46A650/Samsung/Samsung/BN8101697A/New.aspx
Sep 13, 2011 | Samsung LN46A650 46 in. LCD HDTV
I have a samsung lns4095d and it has short horizontal white/red lines going down the center of the screen. They jump around, and it's on every screen....setup, cable, hdmi, etc...what is my problem?
Hi, Make sure that you don't have any florescent tube lights near your TV. The light has some affect on TVs. Move the TV away form light.
Do you have anything connected to the tv other than cable. If problem persist call repairman and see what he has to say. Good luck.
Jul 20, 2011 | Samsung LN-S4095D 40 in. LCD HDTV
Our TV has been perfect for many years. We now suddenly have the picture compress, if you will, to the bottom 2/3's of the television screen, and it makes an angle like a triangle going toward the bottom....
This fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around $120, possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it could possibly damage the system.
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Hope this helps!
Mar 08, 2011 | Sony KV-32S42 32" TV
Rewiring a house putting in a net work for the future . what cable cat5e ,cat5e screened , cat6 , cat6 screened . would cat5e screened be better than cat6 unscreened ? cables away from mains ,
I'm guessing when you say screened and unscreened you mean shielded or unshielded. Shielded wire is used when there is a higher possibility of electrical or RF interference. In a typical household those type of interferences are uncommon. As far as the Cat.5e or Cat. 6 decision, Cat 5e is tested to 150 Mhz. compared to a 250 Mhz. rating on Cat. 6 therefore with future speeds in mind I'd go with the Category 6.
Aug 25, 2010 | Dynex 7' Cat 6 Network Cable - Gray
My l6 fell and now the screen is blank what should I do
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hello,
What you have to do is simple.
1. Remove the battery cover, battery and SIM
2. Use the screwdriver or tweezers to gently pry off the RF grommet located on the antenna cap (below)
  • Removing the antenna cover:
    3. Carefully use the flat end of the tweezers to release two latches on the top end of the antenna cover, then carefully lift the antenna cover away from the phone.
  • Removing the transceiver PC board shield:
    4.Using the T5 screwdriver, remove the 6 housing screws from the phone. Set the screws aside for re-use (see Figure 10).
    5.Lift the metal shield away from the phone.
  • Removing the housing:
    6. Insert the plastic shim between the front housing and the chassis assembly. Slide the plastic shim around the phone between the front housing and the phone to release the housing catches along the sides of the front housing
    7. Carefully lift the bottom end of the front housing over the phone. The earpiece will still be connecting the front cover to the rest of the phone at the top of the phone so be careful
  • Removing the earpiece speaker from the front housing:
    8. Use the plastic shim or tweezers to separate the earpiece speaker from the front housing
  • Removing the LCD screen:
    9. Use the tweezers to release the display module assembly latch located at the side of the display module
    10. Lift up the top edge of the display module
    11. Carefully thread the display flex cable through the slot in the chassis assembly and lift the display module away from the chassis
Replace the old screen with new an
d reverse the whole procedure for reassembly
Take care
Jun 18, 2010 | Motorola Mobility L6 Cellular Phone
My cat jumped on my keyboard and now the screen has a dark hue like you are wearing sunglasses
The bizarre figure then jumped on top of a night table and disappears as the ... A very tall human like figure then descended, he was wearing a bright silvery ...www.ufoinfo.com/humanoid/humanoid1978.shtml
Dec 06, 2009 | Dell UltraSharp 2707WFP 27" Widescreen...
Poppoing noise and the picture jumps
Flyback Transformer is bad cost 125.00 maybe alittle more.
Dec 14, 2008 | GE 32GT740 32" TV
Screen Jumping
Try and adjust your screen frequency in the wii system settings.
Mar 26, 2008 | Nintendo Wii Console
Toshiba 43A10 43" Rear Projection Television Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
