Question about Philips SA5125/37 MP3 Player
Philips SA5125/37 Everytime i plug it into the computer, it flashes do not disconnect, and then seconds later, it says, "OK to disconnect" At first the tracks names were all in chinese instead of their usual titles. Then they dont show up on the mp3 I've tried to do the Repair and Recovery on the Philips Device Manager multiple times, yet it is still not working and now i cant even really plug it to the computer because the connection isnt stable.. its constantly connecting to the computer and disconnecting.. PLEASE HELP
  • anglegurlyy9 Nov 16, 2008
    it says do not disconect and then it says ok to disconect then it does not turn on
First you should hold down the go back button on your mp3 while still holding this button, plug it into the usb port. While still holding the button open up the philip device manager, this should instantly start to repair your device. While it is repairing you can let go of the go back button
Posted on Nov 09, 2008
I have a 50" Philips
Most likely the power supply capacitors are going bad.
Opening the TV and replacing any swollen caps may solve your issue.
Thanks
Roety
Aug 16, 2011 | Philips Televison & Video
When ever i connect my SA6025 to my computer - it doesn't detect it. It says 'Do not disconnect' and seconds later it'll say Ok to disconnect.
hello
you need to install cd first before
try connecting it to the pc
and run setup from cd
Hope I had help you my friend
Dec 04, 2010 | Philips GOGEAR SA6045 MP3 Player
The Philips GoGear 2GB MP3 Video Player, Black, SA3025/37, gives a ok to disconnect everytime I plug in the USP to my computer.
Whenever you are disconnecting the gogear from your computer please try to use the safe exit before the device is pulled off. in your tool bar click on safe removal harware and stop the function, you wll receive a script 'you can remove safely ' Also check to see that the device is not loaded with unwanted programmes not recognised by go ger except through the software recommended.reset the go gear by pressing on the small button below and try again.I hope this will help, good day
Jul 05, 2010 | Philips SA3025/37 Flash MP3 Player
Philips Power supply flashes 5 times
one day not start his open. stan by red led and after switch on ,his green bligkig is not open.sound is ok.(the relay his not click)
Apr 12, 2010 | Philips 50PF7321D 50 in. Plasma HDTV
How can i keep my mp3 on so i can put music and videos on it
Make sure the hold/lock switch is not engaged.
Try another USB port.
If that fails:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
Mar 04, 2009 | Philips GoGear SA3125/37 MP3 Player
This thing does not work always says ok to disconnect
When the mp3 player is connected to the computer, the only message it will generally give you is "OK to Disconnect" - this is normal.
Once you disconnect the mp3 player from the computer, then you can find your music, listen to music, etc.
If you are getting the "OK to Disconnect" message when the mp3 player is already disconnected from the computer:
Reset the player first.
If that fails:
-Tha Mp3 Doctor
Feb 28, 2009 | Philips SA3025/37 Flash MP3 Player
Still not working...
-Tha Mp3 Doctor
Feb 03, 2009 | Philips GOGEAR SA6045 MP3 Player
Philips GoGear audio video player 4GB...cannot update
Make sure the lock is not engaged.
-Tha Mp3 Doctor
Sep 13, 2008 | Philips GoGear Flash MP3 Player
Philips monitor 190b6cb/175
Same problem OSD main controls locked the 5 seconds later OSD main controls unlocked then system closes down sayingproblem with atkdisp, what does all this mean? Can still operate my computer but thid damned flashing OSD message continues.
Aug 10, 2008 | Philips 150S4FB 15" LCD Monitor
Philips SA5125/37 MP3 Player Logo
65 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
