Question about Canon PIXMA MP150 All-In-One InkJet Printer
Canon pixma mp150 saying paper jam but cant see one
My printer keeps saying there is a paper jam, i have looked in all parts i can see but i cannot find any paper jam. I have read other peoples problems and one says to make sure the sensor is clear from dust/paper but i cannot see a sensor, can anyone tell me where to find this or if there might be any other solutions Thanks
  • 10 more comments
  • Anonymous Feb 21, 2008
    I also have the same problem E3 but no paper crump anywhere visible. Paper is able to scroll out but still show E3 when printing/scanning.
    Tried blowing/vacuum, cleaning but still same problem. Can anyone help ?
    thanks
  • Canoncrap100 Mar 23, 2008
    My printer keeps saying there is a paper jam. I have cleaned every part I can without taking it apart. No Parer in sight
    I have read other peoples problems and one says to make sure the sensor is clear. Where is the sensor located?
    Thanks!
  • poetry1006 Mar 25, 2008
    Paper jam on Canon MP150 with E3 error. I have cleaned & cleaned with no results. Please help!
  • Anonymous Mar 26, 2008
    I do not have a paper jam.I haven't been able to use this printer since i've had it.i have searched this printer thru and thru and have not been able to find teh problem.i've had new ink put in which was not the problem to begin with.nothing is laying on top of the printer either.It slso says that the printer is off line but its not.the printer ie plugged into tn computer and electric socket properply.Can you please help me.urgent.
  • Samah88 Apr 21, 2008
    i have the exact same problem - i get E3 flashing on my printer and then researched what that meant and apparently it's supposed to mean there is a paper jam. BUT THERE IS NO PAPER IN THERE.
    what do i do?
    i need your help ASAP
  • Anonymous May 04, 2008
    same problem
  • Anonymous May 14, 2008
    printer keeps indicating that the paper is jamed
  • Anonymous Sep 28, 2008
    My printer won't work either. Paper Jam! I'm sick and tired of it. HELP!
  • Anonymous Dec 11, 2008
    i have the ip1800 and it says the same..i cant figure this out! ahhh! someone help!
  • mazzy02 Apr 04, 2009
    paper jam keeps coming up on the monitor and the printer goes silly with an E or back2front E on the screen. I try to print or I have tried cleaning the rollers thru the computer monitor, none of this works. Alot of cursing is going on too. I have a Canon Pixma mp150
  • gdawghawks Apr 13, 2009
    my printer keeps saying i have a paper jam. there is no paper visible nor is there any paper stuck in there. i tried using the air trick to blow any pieces out and that did not work.. i am getting pretty pissy about this. can anyone suggest anything else?
    is there any hope for a paper jam with the canon pisma mp150?
You are a genius, it WORKED!
Posted on Apr 18, 2007
I solved paper jam message E3 on Canon PIXMA MP150 by selecting a different paper type.
Want to share this information: Always when I tried to print a photo I got E3 displayed. But I could print any other things well. After many attempts to solve this problem I found out that my photo print works fine when I select "Professional Fotopapier" (I live in Austria so I installed a german driver - but I think this selection is for PR-101) although I use "Fotoglanzpapier Plus" (PP-101). I also got the E3 when selected "Fotoglanzpapier Plus" and tried to print an empty word document on standard paper.
Hope this helps
Posted on Sep 21, 2011
I had the same problem. I knew I didn't have a paper jam, but I used my garage air compressor to blow out the inside and also the paper tray area. I didn't see any bits of paper or debris come loose, but it worked.
Posted on Aug 17, 2007
Take the paper out and gently curve all pages. Then put them back in with the convexity facing you. I had the same problem and this fixed it after long cursing, trial and error. All the printers in this line seem to suffer from this problem as far as I know. Hope this helps! ben
Posted on Jan 23, 2007
I was looking for a solution for my HP and found the answer at an obvious place...HP's website...
I was able to fix it by taking off the rear door panel and for some reason putting the panel back on fixed it...
So if you have a rear panel on your printer then try taking it off and putting it back on...if this doesn't help go to the website of your printer and troubleshoot that way.
Posted on Apr 25, 2008
Ditto! Saved me from certain insanity over this problem. Thanks.
Posted on May 23, 2007
I have a mp 160. I did all the other solutions and nothing worked. Then I MOVED the printer forward a few inches, and voila, the printer began printing. Who knows?
Posted on Aug 15, 2009
2 Suggested Answers
Ajkill
  • 2035 Answers
SOURCE: Canon pixma mp150 saying paper jam but cant see one
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Dec 11, 2008
Please help with cannon PIXMA MP150 printer problem, when trying to print, It reads that paper is jammed but I've checked several times and no paper is jammed. Printer will not print due to this...
Hello and Welcome to FixYa!
Paper jam means their may be small bit paper jam in side
, actually there are some "micro sensors" that detect a paper jam. There will be tiny piece of paper inside those sensors, thus tripping the sensor and paper jammed keeps coming up.
To solve this first of all Open printer cover and check to make sure no paper or foreign objects obstructing the printer feeder
, If you become sure that now really there is no paper, dust or foreign objects then Turn the printer off, and disconnect the AC power-cable. Open the printer cover & now give the printer a "blow-job" by compressed air.
If still problem exist then best & final option is to just contact to any Canon Printers service provider.
I hope this solution helps you
Thank you for using FixYa!
Aug 04, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Paper Jam error
unplug the printer and then restart your computer and plug the again. if not work, please try cleaning some part of the printer inside by blowing air.
Jan 18, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My printer keeps showing E and saying paper jam but it is not any paper in there
power down. recheck all printer heads are clean, no small bits of paper jammed?
power on
run self clean test if allows the funcionality.
Oct 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error E-3.jammed paper and there is no paper jam canon Pixma MP150
The printer needs to be opened and greased. It happened to me too.
May 12, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam (e3) BUT no paper jam
make sure you open all check points, if yours has a rear feed through, look in there also. it only takes a tiny piece of paper to cause it to say that. use a flash light, have had to use one to find several that way.
Feb 03, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My canon pixma mp150 have an E3. How can I fix
The E3 error indicates paper jam. If there is no paper jammed then look that if something is stuck inside the rollers. This may solve your problem.
Aug 31, 2009 | Office Equipment & Supplies
Canon PIXMA Mp150 paper jam, how can I get the cover off to remove the jam?
open printer scaner liake as change printer cartridge open jum paper
Aug 28, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma MP150 keeps blinking E 3 saying there is a paper jammed even though there's no paper in the printer. I found a little screw inside, could this be the problem?
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
tokio-5
Aug 02, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Alarm/error and paper jam when not jammed
Power up printer,then press & hold (STOP/RESET)button for 5 sec. Then restart printer.I think it fix your problem.
May 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Dec 11, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Canon PIXMA MP150 All-In-One InkJet Printer Logo
6,224 people viewed this question
Clive
Clive
old marine
old marine
