Question about Aiwa Televison & Video
I have an xd-s260 dat recorder.
Hi, my recorder will only play for 2 seconds or fast forward for about 30 minutes worth of tape before stopping totally and showing the word "CAUTION" can anyone offer any help please? cheers, paul.
SOURCE: Help with my Panasonic nv-ds1 camcorder ? ? ?
I had the same problem with my camcorder. I removed the battery for about 3 days and when i turned it back on it worked. is there a battery in camera to keep the time and date? maybe it is in safe mode and by removing power for long enough it will reset itself. paul sa
Posted on Jan 09, 2007
jackboy
  • 2985 Answers
SOURCE: Disc error message
Computer Burned discs are a grey area for some players[different firmware/chipsets] There is a list on the web of players and what they will play a Google/Yahoo will reveal. Also checkout the manual that came with the player.
Posted on Jul 01, 2007
Benimur
  • 6966 Answers
SOURCE: VHS player stops after 5 seconds
Hi, Based on your post/description, sounds like a mechanical problem with the take-up spool. As this would involve mechanical diagnosis and repairs, your best bet may be to seek the services of a qualified professional. Should you want to venture do-it-yourself, you need to remove the top cover and expose the inner mechanism of the VHS tape player. Of course the usual safety precautions when working with electrically powered devices. Once the inside mechanism is exposed, you will notice that there are 2 spools where the tape would be sitting when fully loaded. The right side is the take-up spool responsible for winding the tape when played or fast-forwarded. When fast forwarding during stop-mode it is direct gear driven however during play and fast-play, the take-up spool is driven by a clutch sandwiched between the top portion and the bottom wider portion. You need to disassemble the take-up spool. It may be held in place by hard press, force-fit, lock or retaining clip. Normally there is a spring near the top. Upon disassembly, you will notice the clutch which is a white fabric/cloth/cotton appearance. This has to be replaced. Probably available in eBay. In my location, such spare part is not readily available and we have to make do with work-around (not necessarily technically right but as long as it works and for your info only). Things we try:, Stretch the spring, the idea is to put more pressure on the clutch when assembled back; roughen the contact portion where the clutch mates with the spool assembly; worst case scenario, forget the clutch, dab a drop of rubber adhesive on both sides of the clutch. In certain models/versions, it is possible that a slipping belt is causing the problem. In some instances, it could be the driving motor. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Posted on Sep 18, 2007
  • 579 Answers
SOURCE: VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Posted on Jan 22, 2008
  • 476 Answers
SOURCE: My philips dvd player has
Usually "ROOT" is an indication that the player has read the DVD.
ROOT means that the DVD is in the main menu screen.
Sounds like the DVD player is ok, but you may have a loose connection somewhere.
Check all of your AV connections between the TV and DVD.
Also make sure that the TV is set to the same AV channel as the connection you are using.
E.G. if you have connected the DVD to the AV 1 socket of the TV, make sure that the TV is set to channel AV 1.
Posted on May 02, 2008
I taped a TV show. But I can't fast forward to see the end part that I want to watch. It just advances to the end.
I'm not surprised that it advances on the end. The VCR doesn't know where the end of the taped programme is. You will have to search manually for it. Start at the end of the tape and rewind a few minutes worth of recording then press 'play' and see what you get. If not successful rewind further and try again, etc,etc. Alternatively you could press "play +rewind" which should allow you to watch the record on what is fast (=x2) rewind. It will help you if you know how long the show was and at what point the tape was when recording started.
Mar 26, 2015 | Televison & Video
My video recorder was working perfectly now all tapes stop when I hit play, some do rewind and fast forward, any fixes please? Tried user manual cleaned heads best I can still no joy.
Goosed? A quaint way of saying it's trash? Well, it can be fixed, but unless it's vital to your video, it may not be worth fixing. You probably have a lack of torque, which would not unusual for an old video recorder.If you need more assistance, or would like to inquire about a repair, please visit my website, audioserviceclinic.com. you may contact me there. Thank you.
Nov 30, 2014 | Sharp Televison & Video
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
I have a VHS tape that has an hour worth of recorded material on it, but when I play it, it plays the first 11 minutes, then it goes to static and the counter stops counting. I can fast forward but when I...
You may think the tape has an hour of material on it, but the machine thinks otherwise. Either it didn't actually get recorded past the 11 minute point, or something erased the tape past that point. There's nothing to play after that time, so you're seeing the snowy screen. On most VCRs, the tape counter only works when a valid video signal is detected, which is why it's not advancing as the tape plays. There's nothing you can do to recover whatever was on the tape, so I hope it wasn't anything important.
Aug 11, 2011 | TDK E-HG 120 VHS Tape
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
My VCR tapes skip or only play in fast forward
If you are recording the tapes in a slow speed, then I would suspect that the tracking pulse is not being recorded properly. Since this is a new VCR, return it for an exchange. One of the recording heads is bad.
Dan
May 30, 2008 | Televison & Video
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Televison & Video Logo
110 people viewed this question
Top Aiwa Televison & Video Experts
romy sibug
romy sibug
 Grubhead
Grubhead
Are you an Aiwa Televison and Video Expert? Answer questions, earn points and help others
