Question about HP LaserJet 2840 Printer
Hp printer 2840 error message 10-1004 supply error. what does it mean?
Tonerman
  • 62 Answers
SOURCE: HP 2840 "Engine Error"
engine error is the fact the the printer isnt turning, also may have a fault in one of the circuit boards.
Posted on Jan 10, 2008
  • 3 Answers
SOURCE: 2840 printer 50.1 & 50.2 error dometimes 13.0 error
Thanks CoolDragon. Ifollowed your advice and eventually replaced it.
After trying to pull out and reseat the fuser a few times (I would even get one or two prints out of it each time), I finally ordered another fuser and problem has gone away. I did google and purchasing site searches (pricegrabber, pricewatch, etc) and found a decent priced site, that also gave discount for your returned bad unit (they gave you so many days to return it), otherwise they'd charge your credit card for the extra dsicount they had origanlly given.
Posted on Jul 04, 2008
SOURCE: HP LaserJet 2840 Scanner Error
when poering on this HP 2840 it says" Scanner Error 5"
what does it mean? How to get a solution?
Posted on Aug 06, 2008
leroyal
  • 2120 Answers
SOURCE: 49.c02 service error message on HP laserjet 4100
General printer error. Unplug the power cord for 10 seconds.
Posted on Feb 06, 2009
sys_admin
  • 829 Answers
SOURCE: 52 scanner error on HP Color Laserjet 2840
The device has experienced an internal hardware error. Recommended Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If the error is still unresolved, contact Hewlett-Packard for technical support to troubleshoot the problem. Call HP for telephone support
Posted on Mar 22, 2009
Incorrect Yellow
Are U installed specified yellow cartridge? Chk with old cartridge & chk for the message.. Same error? there is a mechanical issue, carousel unit might be misaligned..To align it technical skills required, better go to the nearest service center.
If different error replace with another cartridge.
Feb 22, 2014 | HP LaserJet 2840 Printer
Printer Supply Error 10.1004
This kind of error are cause for a toner cartridge, install a new HP toner, a your problem go.
Jan 12, 2014 | HP LaserJet 2840 Printer
I am getting scanner error 5 massage on hp 2840
A tech needs to look at it. It could be as easy as just reseating the 4 wire bundle connector that comes off the scanner and connects to the formatter.
But, in any event a tech has to check it out.
Jul 29, 2010 | HP LaserJet 2840 Printer
LaserJet 2840 Printer: I am trying to initialize a new drum. An error mes...
This means that the printer cannot read the E-Label on the cartridge, or it is not properly installed.
  1. Reinstalle the cartridge
  2. Power cycle the device
  3. If the problem is not solved, replace the cartridge. (Is the cartridge a remanufactured one? this can be a problem)
  4. Check if correct cartridge type.
May 10, 2010 | HP LaserJet 2840 Printer
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
The hp color laser jet 2840 does not print. message "50.2 fuser error" appears
HP recommended checks: 1. adequate 120 VAC power supply, 2. Remove Fuser Assembly, wait 5 minutes and then reseat. 3. Reset the printer to Factory Default settings (remember to copy down the IP address, mask and gateway numbers first).
While this may solve the problem, it is much more likely it's time to replace the fuser. Cost is approx $125 if you buy it online. Just do a Google search on HP 2840 fuser.
This link will show you where your fuser is and how to remove and replace it.
http://h20464.www2.hp.com/resultsCSR.htm?prodSeriesId=445194&MEID=631309C6-088F-43F9-931F-604BAE10EB69
Oct 21, 2009 | HP LaserJet 2840 All-In-One Printer
My hp 2480 has an error message 10.1004
the #10 error codes are supplies memory errors, it's saying toners installed don't match what's in the memory. Could be dirty contacts or generic toners.
Sep 29, 2009 | HP LaserJet 2840 All-In-One Printer
I am getting a an error message 5 on my hp printer model number 2840. please help
HP 2840 error message 5
Scanner Assy needs to be replaced, go to HP site for parts.
Aug 20, 2009 | Office Equipment & Supplies
HP 2840 10.1004 SUPPLY ERROR I am getting a 10.1004 error meassage after replacing the chip on the imaging drum. Previously I was getting a "replace drum"message so I know that it was the imaging drum...
there is something wrong with your drum.. try to replace a new chip for the drum make sure that the chip is working.... if that did not work. see if there is any damage in your drum.. If not replace a new drum..
Apr 20, 2009 | HP LaserJet 2840 All-In-One Printer
HP 2840 *(Error Message) = replace supply using black only Will only print in black All color and black toner are 75% or more full The drum was low so I replaced it just in case but error message remains.
By repalce supplies, it means that you have to replace the other toner cartridges and that it is only going to print black only
Al
Eliteprintersolutions@gmail.com
Apr 14, 2009 | HP LaserJet 2840 Printer
HP LaserJet 2840 Printer Logo
99 people viewed this question
Seeker5211
Seeker5211
