Question about Singer 7422
Problem winding the bobbin movement of needle doesnt disengaged , then all lights light up as if its a warning after one winding a maximum of two times. singer 7422
Mine did this....fixed by gently and slightly adjusting the rubber tension arm bobbin winds next to. Somehow it got pushed too far to the right and I had to twist it back a bit to the left. Bobbin winder works just fine now without all the theatrics of lights and beeping and a complete halt on winding.
Posted on Oct 13, 2012
  • 27 Answers
Check the buttonhole switch ,if not there there is a microswitch on the bobbin winder that may be out of adjustment
Posted on Jan 10, 2009
I was given a 6510 still in the box. I have the bobbin in and threaded but the needle will not move.The bobbin winder is moved to the left.The motor runs but no movement. What can I try?
Did you disengage the bobbin winder? That is a safety feature to prevent the machine sewing at the same time as the bobbin is winding.
Nov 15, 2017 | Sewing Machines
Trying to rewind bobbin machine starts beeping and stops
Is the bobbin pushed over to engage the stop
Oct 01, 2017 | Sewing Machines
WhenI turn the inside nob the needle works but not when I turn the outer nob, it just turns and nothing happens WhenI use the peddle the outernob spins but again the needle doesnt work (nob=handwheel)
On most machines, when the inner wheel is turned counter clockwise, it engages the bobbin winder and disengages the needle movement.
To disengage the bobbin winder and sew, turn the inner wheel clockwise as far as it will go. This should engage the sewing capability and it should work either by hand rotating the large wheel (always counter clockwise!) or with the foot pedal. If it does not, then you most likely need to have your machine serviced.
Jun 29, 2016 | Sewing Machines
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
Won't wind bobbin
they have a free manual at singer pdf download
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 7422) & click search
Jun 08, 2012 | Singer 7422
Machine will not go forward when pressing the foot pedal. Manual says something about checking bobbin winder indent. What is a "Bobbin winder indent."
bobbin winder is the little spindle on top usually right side above the flywheel. you need to move it left away from the stop as this engages the bobbin winder and disengages the needle movement. your manual should show this under Winding a bobbin. these machines dont have a clutch on the flywheel, just moving the bobbin spindle declutches
Sep 18, 2011 | Singer 6038 Mechanical Sewing Machine
Needle not going up and down but power getting to the machine
Check your manual for the bobbin winding steps for your particular model.
On some machines there is a knob in the center of the hand wheel that is loosened for bobbin winding - this also disengages the movement of the needle. Tighten for sewing.
There may be an additional step, such as moving the bobbin winding pin to the right or the bobbin winding wheel to the left.
Apr 06, 2010 | Bernina Sewing Machines
How can I get the bobbin to wind on my singer 7422?
Your machine could be defective. Take it back where it was purchased.
Apr 18, 2017 | Singer 7422
Singer 7422 Logo
417 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
