Question about Maisto Harley Davidson 1997 XLH Sportster 1200
Starter moter wont stop running 1988 harley 1200sportster
How to repair starter moter that wont stop turning
Your starter plunger is sticking you can take it apart and lube it or drill a small hole in the side case big enough to get a skinny screw driver trough lube through that hole and work the plunger back and forth make shure you dissconnect battery first
Posted on Feb 14, 2012
2007 FXDWG wont turn over
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
For a prime suspect please visit website below:
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Good luck
Feb 18, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
1976-harley-davidson-FX-1200- starter-moter-installation
Hi Anonymous, I'm sorry you can't find the very first and best tool you ever bought for your Harley Davidson. Despair not, for a mere $6.50 you may be able to download another one from the website below: Harley Davidson Manuals Mark Workshop Good luck
Jan 29, 2014 | Harley Davidson FLHR Road king Motorcycles
Starter motor not working
For a prime suspect please visit website below and good Luck.
Jan 16, 2014 | Harley Davidson Motorcycles
2006 1200 portster new battery new starter wont start or turn over
Harley Davidson Sportster error codes and how to access them
Jan 06, 2014 | 2000 Harley Davidson FLSTC Heritage...
Harley wont start
3.Discharged battery, loose or corroded connections check negative cable at both ends. (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to on.
7. Security alarm not disarming
Harley Diagnostic Codes 04 to Present
May 20, 2013 | 2005 Harley Davidson FLTRI Road Glide
How do u wire a three phase squirrel cage motor with a motor starter with a remote start/stop/inch station and warning indicator light ?
You would first run a conductor fromL1 to L1 on the motor start then run a second conductor from L2 to L2 on the moter starter, then run a third conductor from L3 to L3 on the moter starter. next run L1 and L2 to a step down transformer so you can reduce your working voltage to 120vac, then run a conductor on one of the outputs from the step down transformer to one side of the normally closed contacts on the STOP push button, from the other side of the stop button run a wire to one side of the start button, on the other side of the start push button run a wire to one side of the magnetic motor starter coil, the other side of the coil run a wire to the other empty terminal on the transformer, this will be the neutral wire. next you need to run a wire from the normally open contactor on the magnetic moter starter to one side of your push button start switch, then run one wire from the other side of the start push button switch to the other side of the normally open contacts on the magnetic moter starter, this is your start switch latch that will keep the motor running when the start push button is released.I'm not sure how you need the warning indicator light wired up, so please reply and let me know when it needs to come on and go off
Feb 04, 2010 | Delta TP300 Shopmaster 12-Inch Portable...
Moter runs fast then slows down
check for intake leaks or idle speed control problems.
Apr 28, 2009 | 1988 Chevrolet Camaro
Maisto Harley Davidson  1997 XLH Sportster 1200 Logo
122 people viewed this question
Top Maisto Toys Experts
ray gallant
17 SOUTH INDUSTRIES
17 SOUTH INDUSTRIES
Are you a Maisto Toy Expert? Answer questions, earn points and help others
