Question about GE Washing Machines
Wpsf5170woww washer will run for a minute or two then quit turning but keeps timing then will start again and stop and start
  • 163 Answers
SOURCE: washer doesn't work properly
yes you can and is easy, disconect the machine from the ac outlet, open the top to acces to the water level switch, check the thin hose atach to it, if its broken fix the hose or chage for a new one and thats is, if not, change the water level switch and you gat it..good luck
Posted on Aug 06, 2006
  • 50 Answers
SOURCE: WASHER RUNS FOR 1-2 MINUTES, THEN STOPS & STARTS FLASHING H/F
can u switch of hte michine at the wall and leave it for 20 mins and turn it on again
Posted on Jan 27, 2009
  • 119 Answers
SOURCE: Kenmore washing machine model 110 wash cycle stops
DOES IT DO THIS ON EVERY WASH OR SOMETIMES? IF SOMETIMES, CHECK LID SWITCH( THERE'S A LITTLE HOLE WHEN YOU OPEN THE LID, ON THE LID SHOULD HAVE A LITTLE PLASTIC PIECE THAT GOES IN THAT HOLE. THE SWITCH IS UNDER, INSIDE THAT HOLE. YOU CAN GET A PEN OR KEY TO SEE IF IT'S BROKEN.)
BOYNISMO@YAHOO.COM
Posted on Aug 21, 2009
SOURCE: Washer stops several times in the middle of cycle
i've had this problem for years. the product sucks. get a new washer
Posted on Mar 05, 2010
SOURCE: Cycle quits with 19 minutes remaining then again
I have a different model but mine does the same thing. How do we fix this?
Posted on Apr 20, 2010
Engine acts like it is out of gas keeps stalling i can turn it off for a few minutes will run for a mile or two then does it again
Vent valve has failed closed or cannister is clogged up. Have the evap system checked from the tank to the charcoal canister. If you need to drive to a mechanic, try driving with the gas cap loose.
Dec 16, 2017 | Hyundai Motor 1999 Elantra
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
My air compressor starts right up, runs for approximately a minute, then quits. If left sitting for a minute or two, it will start again, and run for a minute, then stop. If you shut the fuel off, it...
It sounds like the compressor is reaching the max psi it can hold. At this point can you use a air tool or blower? The reason it comes back on is to keep the psi at running level. It replentishes the lost or used air.
Bruce
Mar 31, 2011 | Honda Air Tools & Compressors
Too much pressure.
You need to keep the trigger pulled every time you start and you need to run the water for 3-5 minutes wide open before you start. Zero air should be in the line or this could cause it to **** out. You probably damaged the pump at this point.
Apr 27, 2010 | Dewalt DPH3100 Gas Pressure Washer
Motor keeps stopping
Hello. Get a bottle of carburator cleaner which you add to the fuel. follow the directions on the bottle. This should solve your problem.
Please rate my answer as very helpful. thanks.
Apr 25, 2010 | Honda Maxus Prosumer MX5223 Pressure...
How can I fix my whirlpool thin twin washer?
It almost sounds like your motor is kicking out on overload. The fact that it starts agitating after the fill can rule out the pressure switch. You have installed a new timer so we should be able to rule that out. It's possible that your pump is binding, which is attached directly to your motor and causing it to overheat. To tell for sure you would have to check the motor to see if it's getting power when it cuts out. Check your terminal block where the power cord comes in to see if all connections are secure. Other possibilities could be the clutch and brake assy. With out being there too see the problem, this is where I would start.
Apr 27, 2006 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
21 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
