Question about Rockford Fosgate Car Audio & Video
Where's the fuse located in a Fosgate p300-1 amp?
  • 356 Answers
It is just to the right on the rear of the amp next to the 12 V + - RTO +
Here is a link to a picture:
http://www.crutchfield.com/S-mj0Klw5sfLm/p_575P3001/Rockford-Fosgate-Punch-P3001.html
Posted on Feb 14, 2012
Where is the fuse located on my p500 2 rockford fosgate amp
Internal or external? Those are protected externally as close to the battery as possible. Check the wire size and color at the amp and then go look for it at the battery under the hood. You should be able to see the installers additions. Inside the unit is another matter.
Feb 03, 2017 | Rockford Fosgate Car Audio & Video
I have a fosgate 15' sub and a fosgate t1001bd amp in my chevy tracker, how should the amp be hooked up and where should the ohms be set?
You can not set the ohms, If you don,t no what your doing get help from some body that noe,s what in the hell there doing, That you don,t fry the amp, End blow the sub,
Nov 12, 2012 | Car Audio & Video
Where is the fuse located on the rockford fosgate p300-1 amplifier? my amp will not turn on and i checked the voltage on all connections and they were fine. I've read several people saying that you...
The 40A fuse should be immediately to the right of the B+ terminal. If you bought this amp used, and it's never turned on before, it's possible the previous owner removed the fuse. It's hard to miss if it's actually there, so you're probably seeing an empty slot where the fuse is supposed to be. With the radio turned off, insert a 40A ATC (blade style) fuse into the slot, and then power it up.
Nov 17, 2017 | Rockford Fosgate Punch P300-1 Car Audio...
I got a rockford fosgate 801s. and i cant find where the fuse is located.
Regards, Tony
May 22, 2011 | Rockford Fosgate Punch 801S Car Audio...
Were is the fuse located on the punch 300s?
I just read all the information about this amp on crutchfield and never saw anything about a built in fuse or external fuse. I don't think it has one.
May 22, 2011 | Rockford Fosgate Punch 300S Car Audio...
I have a rockford fosgate t1500 amplifier and two 12"kicker L5's duel voice coil. the subs are wired together as one. they worked for about half an hour. now the amp and head unit comes on but no...
This amp is rated at 200 watts when run at 4 ohm load when in bridged mode (mono).You will need to check the measurement of the load at the amp's positive and negative location where it meets the speakers. You are actually going to need to measure the load of the speakers on the amp. If it ran too low of a load, meaning less than 4 ohms, there is a good possibility that the amp overheated and damaged some internal components due to not enough resistance. Some of their amps have internal fuses that can be replaced. It may be time to visit a diagnostic shop.
Bruce
May 04, 2011 | Rockford Fosgate Punch 201S Car Audio...
Fuse location on a punch 301m
The older Rockford amps required external fuses. There were no on-board fuses.
Nov 24, 2008 | Rockford Fosgate Punch 301M Car Audio...
ROCKFORD FOSGATE Punch 301M Amplifier Problems!!!!!!!!!
Check the Inline Fuse -=Usually located Close to the battery in the engine copartment=- and also check the fuse in the AMP. Without knowing and seeing all of the details i would say to try to bypass the capicator, I know that i always unhooked my inline before jumping the car but i know it happens. Hopefully it will be just that a fuse or the capicator but if some sort of surge resulted from multiple failures get the amp bench tested at A car audio shop. Just some thoughts.
Feb 21, 2007 | Rockford Fosgate Punch 301M Car Audio...
Car Audio & Video Logo
1,362 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
