Question about Vivitar ViviCam 3750 Digital Camera
What SD card do you use - Vivitar ViviCam 3750 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The 3750 uses MMC and SD cards, up to 2GB in size.
Posted on Feb 14, 2012
How to remove/load sd card stuck in Huawai M860
The SD memory card slot is spring loaded, to insert the memory card insert the card into the SD memory slot with the SD card contacts going in first and gently push it in until it locks in place. NOTE if the SD card does not slide into the slot easily then the SD memory card has been inserted back to front, turn the SD card around and insert it again.
To remove an installed SD memory card, press the SD memory card and it will pop out slightly then you can then pull out the SD memory card.
Mar 12, 2013 | Cameras
Hi..how do I transfer phone contacts to sd card?
hey you cannot transfer contact in sd card, unlike the picture images etc. but phone contacts you cannot,
Nov 15, 2009 | Samsung SCH-i760 Smartphone
-SD Card was renamed
From what I remember when this happens you empty the SD slot and do a soft reset. When the SD card is put back in it will be SD card. Similar steps when you put your SD slot device in.
Sep 11, 2005 | HP iPAQ HX4700 Pocket PC
Card Error
please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba Sora PDR-T20 Digital Camera
Card Error message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3300 Digital Camera
Card Error Message
1. Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. 2. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. 3. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. 4. The Toshiba PDR-3310 is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. The PDR-3310 may work with some MultiMedia Cards, but is not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-3310 Digital Camera
Card Error Message
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Card Error
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following: Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary. Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position. If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased. Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
Sep 11, 2005 | Toshiba PDR-2300 Digital Camera
Card Error
Sep 11, 2005 | Toshiba PDR-2 Digital Camera
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
Vivitar ViviCam 3750 Digital Camera Logo
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
