Question about Husqvarna Forest & Garden 125bt Backpack Blower
The on off switch does not work the backblower pullstart starts the blower i have to take spark wire off too stop
2 Suggested Answers
#1 Taper
  • 1040 Answers
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
Posted on Aug 02, 2011
Old M70-130067 Sno Thro my Dad says it just conked out cant pull the pullstart at all and the electric start doesnt even make a sound ...... oil looks fine ..... suggestions ?
assuming you have already tried to remove all external drive belts from blower (to remove all load from engine) try removing the spark plug from engine , and try pulling engine over with pull start (it cant start) if it still fails to move at all or is real hard to pull look farther for an internal engine fault , if it does move then you have an "Hydraulic" problem most times is caused by motors oil inside cylinder , most times caused by head gasket failure or turning engine on it's side will do it too
Apr 06, 2015 | Garden
Backpack blower will not shut off when knob is pushed to "stop". Have to disconnect spark plug boot to shut off blower.
Your off switch may be wet or disconnected. You can try spraying it with a little bit of contact cleaner or WD to clear the moisture. If this doesnt work you can pull a cover and trace back the wire and see if it just fell off or melted. Good luck and be safe!
Oct 04, 2014 | Stihl Br 320 340 400 420 Backpack Blower...
My blower stops working after a few minutes and then shuts off
When it shuts off pull the plug wire and using a spark tester see if yo still have spark. If you have no spark you probably need a new coil. If you stil have spark put the plug wire back on and spray a little ether *(product usually called "instant start") and see if it starts momentarily. If it does your carb is in need of a cleaning. Most have tiny screens that plug up over time. Replacing this screen is recommended. Cleaning almost never works!
Oct 01, 2013 | Garden
Blower vac doesnt have any spark .will not start
Gudday, try changing spark plug,check stop switch and wiring failing that try electronic ignition mag. pack...Give it a go......
Dec 31, 2012 | Ryobi Garden
STIHL BG75 LEAF BLOWER ELEC. SYSTEM
The unit uses a magneto system. To test the module remove the black wire from the module then reassemble unit and test for spark ( spinning by hand will not work, you need to use the starter rope to get the needed RPM to create a spark). If you have no spark with the ground wire disconnected the module is bad and needs to be replaced. If you DO have spark with the ground wire disconnected then you have a pinched wire going to ground or a bad stop switch
Oct 01, 2012 | Stihl Garden
MODEL RYO9600 LEAF PULLSTART BLOWER MISSING FLEX HOSE TO WAND
Go to this link for the Ryobi parts. You can get one for less than $5.
http://www.ereplacementparts.com/ryobihm-ry09600-backpack-blower-parts-c-7931_15636_130605.html
Oct 17, 2009 | Ryobi Garden
How do i fix the pullstart, including attaching to inner coil
You can remove the cover and you will then be able to view the pulley and crank as well. You can pry up tabs on pullstart, rewind and replace.
Sep 23, 2009 | Poulan Featherlite Gas Blower, with Low...
H1001d stopped working
You might have the blower wired incorrectly or a bad blower. Also make sure the hose is connected to the blower and pressure switch.
Dec 07, 2008 | Hayward H Series Induced Draft Abg 100,000...
Leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Oct 31, 2008 | Homelite 'Yard Broom' Leaf Blower
Husqvarna Forest & Garden 125bt Backpack Blower Logo
50 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
