Home | Sony | SDM-HS73P (Black, Silver) 17" LCD Monitor | Display with a red tone
Sony SDM-HS73P  17" LCD Monitor
Problem for Sony SDM-HS73P (Black, Silver) 17" LCD Monitor
By baderous on Oct 24, 2008
When I turn the monitor on (plugged or not to the computer) i get something like a red colored tone instead of the regular background black color. I think it's an electrical problem but I would like to confirm first. Appreciate any kind of answer. Regards
Comments:
Oct 25, 2008
- Well, i've shutdown the monitor for at least half a day, and now it's working normally again. But yesterday it was very strange, because sometimes when i turned the monitor on the orange light on the button became flashing (meaning a self diagnose i think) and i needed to turn it off otherwise it would have stayed flashing for life, turning it on again and things were like they were, the red colored tone instead of the black background. But now it's been a few hours using it, and for now it's working properly, hope it doesn't happen again. Anyway thanks for the answer.
Regards
Nov 08, 2008
- Well, at that time, the problem occured again during 3 ou 4 days, but eventually, after shuting down the Monitor for the night, in the next day it turned to be okay again. It's been a while since it happened for the last time, so right now i guess i will wait to see what happens. If it becomes happening again than i'll maybe changing the screen. But thanks anyway.
Regards
Nov 08, 2008
- Forgot to mention, the red colored tone stayed on, it didn't fade way.
Feb 10, 2009
- Well, it's been a long time since i've used the monitor for a good couple of hours, and now i've noticed that the problem continues, sometimes, after the red tone appears, it goes back to it's normal state after some seconds but other times not.
I think it's better do someting about it...
Fran, how much those screens you say cost? And how can I replace them?
Regards
Clarification Request
Posted by bammbammfran on Oct 24, 2008
Usually red or pink colors are caused by bad or failing bulbs in the monitor screen.
Does the red stay on and then gradually go away or does the monitor shut down after it is started.
If a computer is hooked up does your power button light stay on bright or go dim or turn to yellow-orange ?
Solution #1
posted on Nov 06, 2008
Somewhat Helpful)
bammbammfran
Rank: Guru
Rating: 89%, 93 votes
If the redness fades away after it warms up, then it is the bulbs.
Eventually they won't even start up and you may cause damage to your inverter board.
Most screens use 4 bulbs, 2 on top and 2 on the bottom edge.
They can be changed , but it is a bit of work, plus he bulbs average 15 dollars each to buy, so sometimes finding a replacement screen that is good is easier to do.
I have some screens, but I would need to know your model number of the monitor and of the screen.
Fran
Comments:
Feb 10, 2009
- You would need to take it apart and get the numbers from the back of the actual lcd screen to find out if it can be found or a compatible one may be available.
Email bammbamm@ptd.net
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 30, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
they gradually go away so what could it b??
Popular Solutions for Sony SDM-HS73P 17" LCD
Questions and Unsolved Problems for Sony SDM-HS73P 17" LCD
Do you recommend Sony SDM-HS73P (Black, Silver) 17" LCD Monitor?
Answer
Answer
thin green like 3.5 inches long on the right side from the bottom
Answer
will not show display power button does not work(stays on) when connected to 110 display says -no... (More)
Answer
I have a Sony SDM-HS73 Monitor and the screen gets distorted and them will go crazy with lines and... (More)
Answer
plugged it into my laptop and did the same thing, so it is the monitor which is only 5 yrs old. Is... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony SDM-HS73P 17" LCD...:
Top Monitor Experts
Rank: Guru Guru
Solutions: 445
Experience: Experienced a lot in computer troubleshooting. Knowledgeable about cellular phones.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
