Question about Dryers
Kenmore Dryer won't re-light after initial start
The burner ignites during the initial start. Then, after cycling off, it fails to re-ignite. The igniter doesn't stay on long enough for the gas valve to open (~6 seconds) and the burner fails to ignite. I have replaced the Thermal Sensor but it did not resolve the problem.
  • E078246 Oct 27, 2008
    I had learned from a former repair tech that the coils were to blame. I obtained a kit and replaced and no more issues!
    Thanks!
  • 5,911 Answers
The following link explains a little theory about glow bar style igniters:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for replacing an igniter on a gas range, but the types of igniters used and the theory of operation is still the same. First, you will need to determine if your igniter is still good. The link provides you with the tolerances you need. If the igniter is still good, I would recommend replacing the gas valve solenoids (coils). There are two of them on the burner assembly near the igniter. One is a two terminal, the other is a three terminal. One coil is the gas main, the other is the pilot position. Typically, a weak or bad igniter will not allow the burner to ignite at all. If the coils are bad, however, they may allow initial ignition, but once the burner assembly gets hot, they may shut off. I've seen this happen before. Test your igniter just to be sure, but I'm leaning towards the coils being faulty. It is strongly recommended that you replace BOTH coils at the same time if one or the other is defective. They are generally sold as a set. If you post back with your COMPLETE model number I can assist you in trying to locate replacement parts if you like. I hope this information helps you. Let me know if you require additional assistance.
Posted on Oct 26, 2008
I have a Kenmore Elite older model dryer that will fire the burner up when started, but when the burner shuts down and then tries to cycle on again, the glow igniter starts but no gas is released and the...
most likely its gonna be your coil kit, but it could also be ur gas valve,but the gas valve is not common. I would go with the silinoid coil kit first, its much cheaper too
Oct 11, 2012 | Maytag Atlantis MDE7400AY Electric Dryer
The unit just stopped heating and drying the clothes.The burner on my LP Kenmore dryer won't light, otherwise everything else works just fine. I've have taken everything apart and cleaned out all...
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty
Jul 28, 2011 | Kenmore Dryers
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
I have a Kenmore gas dryer, model 80. The burner ignites but turns off fairly early during the cycle. It gets warm for a few minutes, but ends up not drying anything. I am trying to narrow down which parts...
Make sure the lint filter and the exhaust duct are clear all the way to the outside vent. If the gas cycles once and then does not light again the thermostat may be defective. If the gas lights but then goes off when the ignitor stops glowing then the secondary coil on the gas valve is bad. (This ignition cycle may continue to go on and off but the gas will not be lit enough to provide enough heat for drying.) The coil assembly can be replaced.
Aug 12, 2009 | Dryers
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Kenmore front load washer won't heat
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
Nov 17, 2017 | Dryers
Kenmore ddryer 11072812101
Your dryer does not have a pilot. The dryer has an igniter on the burner assembly. When you push the start button, the igniter begins to glow. Once it reaches a certain current potential, the gas valve is opened, gas flows and you have ignition. This is a a built in safety feature of the burner assembly that prevents free flow of gas without ignition. Without it, you could have a build up of gas inside the dryer cabinet followed by the loud "phoooom!' of an explosion when it finally DOES ignite. More commonly the igniter either fails to where it does not glow, or becomes weak and will not produce the required current to open the gas valve. The following link explains a little theory about glow bar type igniters and what their current potential should be:
I know the link is for a gas range, but the igniters in some of these appliances are identical and the theory is the same.
Another cause of an ignition failure are bad gas valve coils. There are two of them on your burner assembly. It is recommended that if one fails, you replace BOTH of them at the same time. If you go to searspartsdirect.com and type in the model number you provided, there's an excellent exploded view diagram of your burner assembly and parts. The igniter is listed as item number 4 (part #279311) and the safety valve coils are items number 13 (part #694540) and item 14 (694539).
If you can view inside your dryer under the drum, you should see an orange glow as the igniter comes on. If you do not see the glow, or if the igniter glows and there's no ignition after 90 seconds, I would recommend replacing the igniter. If the dryer ignites, then shuts off after a short period of time and will not reignite, you may have a bad coil (you may hear a rattling sound too).
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 26, 2008 | Dryers
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
230 people viewed this question
Top Dryers Experts
