Question about Proform Exercise & Fitness
Shock lift stuck - Proform Exercise & Fitness
    Top Expert:
  • Proform Master
  • 12,223 Answers
I can not understan your questions> Do you have some electrical shock in the lift stuck?
sincerely.
ernesto cuadra
managua, nicaragua
Posted on Feb 14, 2012
Do I need to change rear shocks after a lift kit
SilveradoSierra.com • Changing shocks after rear blocks : Suspension
www.silveradosierra.com/suspension/changing-shocks-after-rear-blocks-t56785.html
  1. Cached
  2. Similar
Mar 22, 2013 - 5 posts Will the factory shocks still have enough travel or will they max out? I also did the ReadyLift 2.5 leveling kit. Same question. Do I need to replace ...
5 Things You Should Know About Car Lift Kits ' eBay
www.ebay.com/gds/5-Things-You-Should-Know-About-Car-Lift-Kits-/.../g.html
  1. Cached
  2. Similar
When drivers install car lift kits, their goal is generally to take their vehicle from its ... lift kit or a suspension lift kit will come down to the type of tire they want to install on ... when installing a car lift kit is to purchase the wheels after buying the kit.
2" Leveling Kit, which one to buy? Do I need new shocks too ...
www.dieseltruckresource.com/.../2-leveling-kit-one-buy-do-i-need-new-shocks-too-1...
  1. Cached
  2. Similar
May 2, 2007 - After what I went through to install the leveling kit on my truck $250 ... I, personally, did kept the stock shocks on my truck and it seemed to do ...
Do I really need shocks with leveling kit? - Ford Truck ...
www.ford-trucks.com > ... > Super Duty/Heavy Duty > 1999 to 2016 Super Duty
  1. Cached
  2. Similar
May 4, 2011 - 15 posts - ‎7 authors If you're still running factory shocks, it's worth changing them out even if you don't do the leveling kit. The truck will need to be aligned after a leveling kit. .... eye as the stock. install your lift and have the alignment checked. if it ... Do you need new shocks with rear lift blocks? 11 posts 6 Oct 2012 How much lift before longer shocks are required? 12 posts 15 Apr 2010 More results from www.ford-trucks.com
Your Lift Kit How to Guide on Lift Kits for Coilers & Independent ...
www.4wheelparts.com/buyers-guide-reviews/lift-kit-how-to-lift-kits-coilers.aspx
  1. Cached
  2. Similar
The following parts do not qualify for Free Shipping: ..... The downside to all coil spring suspension lift kits is that they alter the operating angles of ... That changes the axle location (axle moves to the rear in front, and forward in the rear), ... manners and efficient operation you will need to go with a long arm suspension lift. Do need to change rear shocks after lift kit Google Search
Jan 25, 2017 | Cars & Trucks
Looking for replacement shock for seat bar lift.
Amazon.com: HomCom 3.2" Universal Replacement ...
www.amazon.com/...Replacement.../B008XVEZG8
Amazon.com, Inc.
Rating: 4.2 - ‎123 reviews
Office Chair Pneumatic Gas Lift Cylinder Piston Replacement - Universal Size ... much right on the money and I have to say that the price just simply cannot be beat when you start looking for pneumatic gas lifts! ... ·With PP gas bar cover ....Replacement Office Chair Gas Lift Cylinder Pneumatic Shock - 5" Travel - S6111.
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar ...
www.4wheelparts.com > Suspension
Lift Kits -Body Suspension Lift Kits, Bump Stops & Sway Bar Bushings ... ShockAbsorber Bushing. Upgrade or replace your ... Shock Link Kit. Shock Link Kit. Lift ...
Complete Suspension Systems and Lift Kits - 4 Wheel Parts
Dec 27, 2015 | Toys
My 97 Ford Expedition has air shocks and my right
Check the little hoses that goes to each shock.. probably one is broken or crushed. or the shock is bad.
Sep 06, 2014 | Cars & Trucks
My 1998 cady sts is really high in the back looks like it is lifted.... why?
The vent solenoid is stuck closed on the ELC unit (electronic level control). You can replace the vent valve but it is mounted to the ELC unit witch is attached to the rear axle assembly on the top of axle assembly above the right muffler. To temporary level car, disconnect the compressor electrically then disconnect the air line on one of the rear shocks, let air out till car is level put air line back on shock. Thank you
Sep 03, 2010 | 1998 Cadillac Seville
My rear shock is definately needing rebuild of some sort, the shock is stuck down and i have to hold the rear wheel down and lift the seat to make it go back up. just curious as to what part of the shock...
The spring holds up the weight of the bike.If its stuck down.the main shocky rod is bent or the internals of the shocky are broken,causing it to lock.I don't think its parts but a new unit.Hope this helps
Sep 12, 2009 | 2004 Honda CRF 250 R
I want to know how to lift the front end of my 2000 GMC Sierri but dont want to buy a lift kit
It depends on how many inches you want to lift it. Keeping it simple. replace your shocks with air shocks or better go to summit.com and find out about their spring spacers. that way you don't replace your springs or shocks
Aug 10, 2009 | 2000 GMC Sierra
Rear on my 1005 cadillac deville is stuck up high in the air.
you might want to check your air control box under car near rear shocks,this starts the air compressor to lift or lower the air shocks
Feb 18, 2009 | 1995 Cadillac DeVille
Shock size
they are talking about the lift it has, if it's stock, you need a 0 lift shock.
Dec 22, 2008 | 1998 Jeep Cherokee
Lift kits
if you have old shocks you can measure full out then full in and give that measurement to your lift company of choice. if not then measure from the center of the axle to the top of the wheel well, if your fenders are cut you can measure(on ground) from the top to bottom shock mount and give that measurement to your fav lift shock company. Good Luck
Jun 30, 2008 | 1992 Ford Bronco
Exercise & Fitness Logo
55 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
