Question about Dryers
I need the bracket that mounts a hometrends ceiling fan
  • 25 Answers
SOURCE: need a ceiling fan hanger bracket for 12/6 pitch roof (ceiling).
cut a wood shim.
Posted on Jan 15, 2009
SOURCE: Mounting a Hampton Fan Model 52-CL
hello d,
1. yes, with the proper rod, longer wires(3,4) and the blades must be over 2.5 metres (8 foot) above the floor.2. you need the proper type box; the mount/s and ball; the longer wires (3,4)with slender but connertors; and especially the safety pins, etc. with the proper rod, the fan will hang straight. and about 3 chock hours to do this here task. hope this helps.
Posted on Jan 16, 2009
jyackle5
  • 8197 Answers
SOURCE: Need a fan blade attachment
You can buy the blade attachments at home depot
Posted on Jan 22, 2009
  • 63 Answers
SOURCE: hampton bay portland 2 ceiling fan
not sure of your exact model...but I have installed many hampton bay fan... so far they have all worked for ceiling hugging mode.. keep reading your instructions
Posted on Mar 16, 2009
  • 34 Answers
SOURCE: I have a Hamptom Bay ceiling fan model number EF200D
home depot sells universal ceiling fan brackets for a few dollars, they will be near the lamp parts
Posted on Sep 10, 2009
How do I remove fan mounted close to ceiling?
There should be side mounting screws in the canopy which attach it to the mounting bracket. The screws are removed to allow the canopy and motor assembly to drop down free of the mounting bracket. A convenient hook is provided to allow wires to be disconnected.
Oct 23, 2015 | Hunter 20461 Brushed Nickel Ceiling Fan
Hampton bay ceiling fan broke. How to screw it back up
It already looks like it's "screwed up". ( LOL) BEFORE BEGINNING READ ALL OF THIS FIRST< PLEASE> First turn off the breaker that supplies power to the fan. Take down the whole unit up to the ceiling mounts. It looks like the wood is broken that the screw bracket used to mount the fan is on. If it is you will need to reinforce the wood and rescrew the fan mounting bracket on it. THe ball carrier from the bracket should now be secure and ready to mount the swing ball of the fan at the top of the fan unit motor. Next rewire the fan to the wires in the ceiling with the wire nuts you removed. Tighten the ball screw and push the cover plate up to the ceiling, fastening it in place with the screws provided to the ceiling plate...Done!
Jan 01, 2013 | Heating & Cooling
Who made an M52 series ceiling fan? 5 blades, 4 lights
I have a 52" A.C. Ceiling Fan, M52 Series, Fan 82F4, 120V, 60 Hz 1.0A, File No# E143948, TR/HD: 0596, Serial No# 026351-027900, and have had the fan stored for awhile now and it seems I've misplaced/lost, the mounting bracket that fits inside the cover where the stem and ball are located and mounts to the bracket box inside the ceiling. Any ideas of where I can find one so that I don't have to purchase an entire new ceiling fan (again). I've tried 2 ACE Hardware stores, Home Depot and Lowes and no one carries them.
Jan 31, 2012 | Dryers
Trying to remove a ceiling fan Hampton Bay model C 542 MP (CH) PBL . its flush mounted and cant get to mounting bracket.
Look for 2 to 3 screws at the top edge of the fan's ceiling cowl. Remove those and the ceiling cowl can be sled down, which will expose the the ceiling mounting bracket . They are fairly small head screws, so look carefully for them.
Hope this helped you and thanks for choosing FixYa.
Aug 14, 2011 | Heating & Cooling
Need to uninstall the fan as it has become a bit loose from the ceiling
The first thing to do is loosen the ceiling canopy, there is usually a couple screws at the top edge of the canopy. then you want to disconnect the wiring, do not forget the green wire also. then depending on the mounting type, it may just lift out, one side of the mounting bracket has a space to allow the ball to pass thru. Or you may have to unscrew a couple mounting screws at the ends iof the mounting bracket
Feb 06, 2010 | Hampton Bay 52 In. Indoor/Outdoor Tahiti...
Do not have room for a remote control receiver in my ceiling fan. Can i just buy a new hanger bracket that has the mounting room.
Hello, your installation will determine if you can use another type of hanging bracket. If you require that the fan must be mounted close to the ceiling there might be a way to install the remote by using plastic wire ties to sucure the receiver. There are many fans that state NOT FOR USE WITH REMOTE. Please check to see if your fan is one of thoes. If ceiling height is not a issue then a new hanger bracket should do the trick. Make sure that the bracket and the installation location will support the weight of your fan. SAFETY FIRST
Aug 25, 2009 | Dryers
No outlet box in ceiling, it has a hook is there a special bracket, my home was built in the 1940s and the ceiling fan in the kitchen was hung with a hookin the ceiling, there is no electrical outlet in...
They sell brackets at home stores, but I have nailed a 2x4 between ceiling joists & mounted an electrical box at proper height. If you aren't good with electrical, get an electrican to run power for you.
The hanger must be SOLID & the wiring GOOD.
Apr 25, 2009 | Hampton Bay 42 In. Antique Brass...
Cover does not attach to the universal bracket I purchased
Buy a drill and drill bit and make a hole in the bracket where needed. To make installation easier, use a larger that needed drill bit and add washer to screw, won't look as professional but you are not a professional anyway. Who goes around looking at ceiling fan mounts anyway???
Jan 13, 2009 | Hampton Bay 73554 Antigua Ceiling Fan
Dryers Logo
35 people viewed this question
Top Dryers Experts
