Question about Ectaco EG900
ORD-456451 The unit was sent on January 21 2012, and I still don't have any news. Please I need to know the status. Tkanks.
  • Rosario Della Fortuna Feb 14, 2012
    The unit was sent to the warranty department. Thanks.
  • kakima Feb 15, 2012
    FixYa does not have a warranty department. FixYa is a worldwide community of members who offer online answers. FixYa does not handle hardware. You need to contact the company to whom you sent the unit.
Need to know what iI orded on may the 16
Robert Acton, I checked at the Amazon web site. They do not sell the item #HT8645300 you mention. Perhaps they sent you a purchase order or a contact number.
Jun 09, 2014 | Computers & Internet
Best way to access screen on CD4E FWD/AWD Transmission
You got issues other than filter or screen worries
Screens don't clog on a completely wasted & burnt
out unit & material filters don't clog enough to cause
issues
You need someone that knows that unit to diagnose it
I would check bulletins & other internet sites
Ford has some really bad transaxles & I haven't
checked the CD4E for you
I used to own a trans shop & to be honest, I really
don't want to know,as I don't get a good feeling,
I will leave that up to you to research
I do know if you using any trans with issues your on
life support & need you check book handy
Nov 14, 2012 | 2008 Ford Escape
Stanley 300 amp jump-start system status lights don't work. only low stays on
Sep 26, 2012 | Stanley 300 Amp w/12V USB Jump Starter -...
I paid for membership on January 19, 2012 order Number 39263 I can't copy worksheets because I don't know my username or pin #. The one I am using is wrong.
Please contact support [at] superteacherworksheets.com. We'll be happy to look up your login information for you and send your password. You can also contact us via our Facebook page.
Sincerely,
SupeTeacherWorksheets Support Team
Feb 09, 2012 | superteacherworksheets.com
Turns off showing E5
Unfortunately, unless you still have the Owner's Manual for you unit, you may never know what the E5 error code indicates. Windchaser went out of business about 4 or 5 months ago. And with them went any and all information about their AC units and other products they manufactured & sold. In addition, unless, it's an interchangeable part, there are no Windchaser OEM parts available at this time.
Amazingly, there are some retailers that still have the units for sale, but are not telling the customer that the company is out of business. I guess they just don't want to get stuck with the discontinued units.
I wish I had better news & information for you. But, it is what it is.
Aug 24, 2011 | Windchaser PACR10 Portable Air Conditioner
I have a Ford Explorer '07 4.0. Engine light turned on sometime back in January and it went off on its own. Now its May & Engine light once again turned on. Any solution?
First have the code checked. Parts store can do it. If you don't post a symptom, We can't diagnose. The light can come on for 100's of reasons. some as simple as the gas cap is loose. Let me know. I will help. Randy
May 20, 2011 | 2007 Ford Explorer Eddie Bauer
I've had the Tonebone Plexitube since January of this year, but have only played through it a couple of times. I recently took it out to really experiment with it and get to know the pedal. Right away...
It sounds like somehow the pre-gain is very high while the volume or post-gain is very low. Try turning the volume high on the effects unit and the gain low, and don't have the amp volume too low either.
May 18, 2011 | Radial Tonebone Plexitube Effects Guitar
Can emc ax150 work without the UPS cable?
I moved my AX-150 to a location that would not allow me to install the UPS as it has redundant power/UPS and you should not connect a UPS to the output of another UPS.
Without the UPS the AX-150 forces the Write Cache to be Disabled. Performance drops, form what I have tested, to around 25x slower. This is due to not just turning off the controllers write cache, but as with ALL RAID controllers, the onboard drive 8/16M write cache is disabled as well so the drives are even slower then they would be if they where not used on a RAID controller.
The write cache disable is your real killer! Actually the write cache is disabled one a week while the REQUIRED battery test is performed.
My solution was to write an APC SmartUPS Serial Emulator that talks to the AX-150 telling it that the UPS is working fine so the write cache never gets turned off, including during the weekly battery test!
Here is the needed RJ45 to DB9F. Colors are base on someone cutting off the end of a cat5 patch cable.
You can find the APC SmartUPS commands off the web.
Communications capture:
Normal Comms from/to AX-150
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
!!! Weekly Batt Test Time !!!!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
W >> !! Tests battery, like pushing the test button on the front panel
OK<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
X >> !! Self-test results
OK<0D><0A>
l >> !! Low transfer voltage
097<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
n >> !! Get Serial number
AS0632112344<00><0D><0A>
R >>
BYE<0D><0A>
!!! End of Test !!!
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
Y >>
SM<0D><0A>
Q >>
08<0D><0A>
f >>
100.0<0D><0A>
R >>
BYE<0D><0A>
I would be happy to share the Delphi source and EXE with anyone that would like to use it. Do not see a place to attach files here.
Can give you snapshot of main command-response logic:
if Result = pmerGood then
begin
tRx := Engine.RxString;
if cbHex.Checked then
Msg(Engine.SeeBytes(tRx)+ ' >> ' + #$0D + #$0A)
else
Msg(Engine.SeeChars(tRx)+ ' >> ' + #$0D + #$0A);
PendingCmd := '';
Engine.CharDelay := 0;
CmdData := 'NA' + #$0D + #$0A;
if length(tRx) > 0 then
case ord(tRx[1]) of
$01 : CmdData := 'Smart-UPS 750 RM' + #$0D + #$0A;
$1A : CmdData := '#uD43127130133136uA43108110112114uI43253257261265uM432252292' + '33237lD43106103100097lA43092090088086lI43208204200196lM43182178174170e47200153045607590oD13120oA13100oI33230240220oM13208s431HMLq4820205081114172023p483090180270360450540630000k4310TNr483000060120180240300360420E443336168ON OFF' + #$0D + #$0A;
ord('A') : CmdData := 'OK' + #$0D + #$0A;
ord('B') : CmdData := '27.40' + #$0D + #$0A;
ord('C') : CmdData := '016.2' + #$0D + #$0A;
ord('D') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('E') : CmdData := '336' + #$0D + #$0A;
ord('F') : CmdData := '60.00' + #$0D + #$0A;
ord('G') : CmdData := 'S' + #$0D + #$0A;
ord('I') : CmdData := 'FF' + #$0D + #$0A;
ord('J') : CmdData := '0F,00' + #$0D + #$0A;
ord('K') : CmdData := 'OK' + #$0D + #$0A;
ord('L') : CmdData := '126.7' + #$0D + #$0A;
ord('M') : CmdData := '128.1' + #$0D + #$0A;
ord('N') : CmdData := '125.2' + #$0D + #$0A;
ord('O') : CmdData := '113.0' + #$0D + #$0A;
ord('P') : CmdData := '000.0' + #$0D + #$0A;
ord('Q') : CmdData := '08' + #$0D + #$0A;
ord('R') : CmdData := 'BYE' + #$0D + #$0A;
ord('S') : CmdData := 'OK' + #$0D + #$0A;
ord('U') : begin CmdData := '!!!$'; Engine.CharDelay := 600; end;
ord('V') : CmdData := 'FWD' + #$0D + #$0A;
ord('W') : CmdData := 'OK' + #$0D + #$0A;
ord('X') : CmdData := 'OK' + #$0D + #$0A;
ord('Y') : CmdData := 'SM' + #$0D + #$0A;
ord('a') : CmdData := '3.!$%+?=#|.' + #$01 + #$0E + #$1A + ''')+-89>@ABCDEFGKLMNOPQRSUVWXYZabcefgjklmnopqrsuxyz~' + #$0D + #$0A;
ord('b') : CmdData := '615.3.D' + #$0D + #$0A;
ord('c') : CmdData := 'UPS_IDEN' + #$0D + #$0A;
ord('e') : CmdData := '00' + #$0D + #$0A;
ord('g') : CmdData := '024' + #$0D + #$0A;
ord('f') : CmdData := '100.0' + #$0D + #$0A;
ord('i') : CmdData := 'FWD' + #$0D + #$0A;
ord('j') : CmdData := '0375:' + #$0D + #$0A;
ord('k') : CmdData := '0' + #$0D + #$0A;
ord('l') : CmdData := '097' + #$0D + #$0A;
ord('m') : CmdData := '08/03/06' + #$0D + #$0A;
ord('n') : CmdData := 'AS0632112344' + #$00 + #$0D + #$0A;
ord('o') : CmdData := '120' + #$0D + #$0A;
ord('p') : CmdData := '090' + #$0D + #$0A;
ord('q') : CmdData := '02' + #$0D + #$0A;
ord('r') : CmdData := '000' + #$0D + #$0A;
ord('s') : CmdData := 'H' + #$0D + #$0A;
ord('u') : CmdData := '127' + #$0D + #$0A;
ord('x') : CmdData := '01/01/10' + #$0D + #$0A;
ord('y') : CmdData := '(C) APCC' + #$0D + #$0A;
ord('z') : CmdData := 'CLEAR' + #$0D + #$0A;
ord('9') : CmdData := 'FF' + #$0D + #$0A;
end;
if CmdData <> '' then
begin
Msg(Engine.SeeBytes(CmdData)+ #$0D + #$0A)
else
Msg(Engine.SeeChars(CmdData)+ #$0D + #$0A);
Engine.SendMsg := CmdData;
end;
Bob A. Hay
Mar 02, 2010 | EMC 1U UPS 120V FOR AX150 (AX150UPS120V)...
Need to find a Redfield rifle scope repair shop-scope fogs up
iron sight inc.918-445-2001 4814 south elwood avenew tulsa oklahoma. 74107
Dec 11, 2008 | Redfield Ring and Base Sets for Knight...
Ectaco EG900 Logo
78 people viewed this question
Top Ectaco Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you an Ectaco Office Equipment and Supply Expert? Answer questions, earn points and help others
