Question about Kenmore 24032\24036 Top Load Washer
Washer is stuck between cycles and wont drain or spin. put on drain and spin only and eventually a f 3 code comes up
SOURCE: kenmore he2 front load washer
I had the same draining problem as described by others, but the drain pump filter was not plugged. Instead, a large rubber band had somehow gone through the filter and was caught in the pump propellers. In my model (110.46472501), the pump can be turned and then pulled off of the filter apparatus by depressing a tab as the pump is turned (although I only learned this after taking out the pump and filter apparatus together), and the pump can then be cleaned. A perk in taking off the toe panel: attached to the inside of the panel was a trouble-shooting guide "for service technician only" which does include checking the drain pump filter for this problem.
Posted on Apr 20, 2008
  • 112 Answers
SOURCE: 90 Series Kenmore Washer Not going to spin cycle not draining water
If the unit is still agitating as it is supposed to, this is usually due to a faulty lid switch.
Posted on Oct 25, 2008
SOURCE: Kenmore washer not draining/also getting stuck doing nothing
i had my kenmore washer doing the same,looked at water pump but nothing was stuck inside ,i tried the lid switch and stuck a screwdriver in it to see if this would do the trick,nothing..but when i took it out, i could see where it had come apart...took it out and decided to use gorilla glue and clamp it back till the glue dries,before the glueing process ,i test the draining outside with a buckett..and bingo,it started draining the water,i only had the switch crimped with my fingers and at the same time pushed the switch down ,it worked..draing started..hopes this helps
Posted on Apr 13, 2009
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
Posted on Apr 19, 2009
kvhappliance
  • 218 Answers
SOURCE: Washer is Kenmore He2 model # 110.46462501
It sounds like you have something stuck in the pump.
To repair
Unplug machine.
Remove bottom front panel(remove 2-3 screws in the bottom) Pull bottom of panel out and down to remove.
Towards the center bottom you will see the pump. On the front is a round thing that resembles a filter. This is the pump filter screen...Get a shallow pan to put under screen. Turn lid counter clockwise to remove(turn slowly and allow water to drain. As you may need to dump pan several times before all water is drained out. Be carful or you could end up with water everywhere. Once the water is drained pull out screen and remove the debris and objects stuck in screen and filter housing you should also be able to see the impeller on the pump inspect for debris. Once everything is cleaned out reverse removal procedures put back together.
Posted on Mar 22, 2010
My washer says LE and hasnt drained all the water
I have the same issue - Had this washer for 6 yrs - up to now - it's been great. But, now I'm not sure what that problem is. Looks like the bin only spins counterclockwise - not clockwise. I can hear the motor trying to spin - then eventually I get the LE error code.
Dec 06, 2009 | LG WM1812C Front Load Washer
My washer stops at the spin cycle. The LD code
“F21” (AKA SD) is a Long (SLOW) Drain error (LD). If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jul 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Washer will not spin
I fixed it yesterday. After checking the continuity of my lid switch and pressure switch and finding them ok I removed the tubing from the pressure switch and applied air (blew into it). There was a clog and blowing on it removed it for now. Apparently the pressure switch was telling the machine that the tub was full of water and wouldn't let it start the spin cycle. I ran three loads last night and it worked perfect. I may have to remove the connection on the side of the tub and clean it properly if it clogs again.
Mar 23, 2009 | GE Washing Machines
Whirlpool calypso model GVW9959K-0 leaking during rinse cycle
hi my name is joyce
Sounds like your pump is leaking. if it is leaking when you are on a spin cycle.
now if it is stuck on f1 cycle and wont drain unplug and let stay unpluged for 60 seconds and replug and see if you can restart on drain and spin cycle. let me know if I can help with any other problems.
thanks
joyce
Feb 06, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Washer wont rinse
we had the same problem with ours....nd means not draining and that means that there is something, probably coins stuck in your drain hose. pull the drain hose out and check it for change and make sure something isn't stuck.
Jul 21, 2008 | Maytag Neptune MAH9700 Front Load Washer
Spin/rinse cycle
find tech sheet at bottom of washer and follow instructions for checking motor controller (at bottom rear)
Apr 13, 2008 | Frigidaire Affinity ATF7000E Front Load...
is the door lock lit make sure the door is closed all the way make sure the dispenser door is closed all the way their is a magnetic switch in it that will not let the washer spin if its not closed it also will not spin a small load try adding a couple of items let me know if this does it or not
Jan 11, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
104 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
