Question about Home
My aqualisa hiqu shower keeps turning itself on. Had it about two and a half years and tonight it switched itself on the minute I walked into the room - is this just coincidence or did the pressure of me on the pipes or something trigger a loose connection and what is the cause?
  • 171 Answers
SOURCE: shower pressure.
Hi chicken69
I'm Harvey the Master Plumber.
You want to know why the presssure on your triton t80i shower has dropped by half?
It is very possible that some debrie has come up in the water and is partially clogging the shower. For this you would have to turn the water off and dissassemble the parts clearing all the small passages, a bit of wire or paper clip works. Perhaps for a pro? If you like you may choose to utilize our Repair Directory.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
  • 148 Answers
SOURCE: Our Aqualisa power shower lacks water pressure power
more than likely you have some debris near the shower head
take an adjustible wrench( crescent or channel lock
wrap a rag around the eustaceon( chrome tube coming out of shower wall srap around tube to protect the chrome hold it firmly with vicegrips or channel locks, take adjustible wrench or chanel locks and remove the chrome nut holding the shower head on to the eustaceon(turn counter cockwise be careful not to drop the tools that wil damage the tile or fiberglass
after removing showerhead
turn on shower to force and debris out and place shwoer head into stream of water to clean out any deposits the head may have some type of screen to strain the water
this should work if the flow has not incresed then there is a need to adjust the flow valve at the control
to reinstall the shower head reverse procedure
if you have any teflon tape wrap it around the threaded portion of the eustaceon
good luck
hoe this works
Posted on Dec 30, 2008
ffrn99
  • 6 Answers
SOURCE: Shower arm is loose
The best way is to cut a hole in the wall and fix it right. That will entail replacing the surface material, probably sheetrock. You could try some silicone sealant around the shower arm behind the eschusion. It will still move, but not much.
Posted on Mar 09, 2009
  • 2692 Answers
SOURCE: walk in shower leak into room below
I would unscrew shower head pipe and either pipe dope it or tefilon the threads and then reinstall it. I would also take the handle(s) rosettes off and look for a leak from there with a flashlight, while shower is on. I believe the most comon leak for walk in showers are the door seals. Are you sure it is not coming out from under the door? Another test that yuo may want to preform is to Stopper the drain, fill the shower pan with water and watch for bubbles, or look for leaks from below.
Posted on Mar 20, 2009
  • 4 Answers
SOURCE: Aqualisa Aquastream shower noise from pump/motor ?
Remove shower head and clean it on the inside.
Posted on Mar 30, 2009
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
6 yr old Aqualisa shower working perfectly well. But turned itself on last night. No light showing on dial/on switch. Wouldn't turn "off" for me. Ran for 15mins and then switched off!
Good Aternoon lrmulholland,
Do you know what model Aqualisa shower you have or are you able to take a photo of it for us? That would be very useful.
Kind Regards,
The Aqualisa Team
Sep 07, 2011 | Vacuums
The 'boost' button on my aqualisa digital shower won't switch off. It comes on when I press the shower on (without actually pressing the boost button) and when I press the boost button to try...
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Jul 29, 2011 | Home
Hello, my aqualisa shower is working intermittently, water starts and then goes down to a dribble, but not all the time. It is an aqualisa quartz.
If you are not getting any water through your shower it is possible that there is a restriction.
Please note that the air lock test is only neccessary if you're shower is the Pumped Digital Quartz or Quartz Thermo Mixer Shower and that you are on a Gravity Fed Water System (cold tank in loft).
The hose will appear fine from the outside,but the hose has an internal rubber liner which can become blocked/twisted.
To remedy this,unscrew the shower head from the hose anti-clockwise.Place the open end of the hose to it's lowest point (bath or tray).
Turn the water on.The water SHOULD come out in a straight line,if however the water comes out in a V-Shape the liner is twisted and the hose will need replacing.
Air Lock
If there is air in your pipework this will cause low flow and pulsing.To remedy this fault do the same above but run the water on FULL COLD for two minutes and then FULL HOT for three minutes.
If the water pulsates it is the air escaping.If it does this leave it until it corrects itself.
Hope that this info helps you,if it doesn't it sounds like you have a mechanical fault with the processor box.
Aug 24, 2010 | Kitchen Ranges
Aqualisa shower will not stop dripping after use. what is needed?
If you can confirm what model of shower you have I can talk you through how to repair the shower,<br /> <br /> Mike<br /> Aqualisa Showers
Aug 15, 2010 | Home
Get a knocking noise from an Aqualisa Quartz 2
It may be a water hammering effect from pressure in your pipes. You may need to install a water hammer to stop this. you can put in line that will stop this.
Dec 28, 2009 | Home
Aqualisa quartz shower. Knocking / dripping type noise coming from pump when powered but not turned on. Any ideas???
this is caused by the water pressure in the pipes check that all the pipes are secured firmly this should stop the problem a piece of rubber or foam placed behind the pump will also help
Nov 15, 2009 | Home
aquastuream loud noise?motor/pump
Mar 30, 2009 | Home
On and Off control not fully working
I've never worked with an Aqualisa, but often times a problem like that is simply mineral build-up within the valve components. I would recommend turning the water off at the main and carefully disassembling the valve. Give it a good clean with some CLR and a toothpick. If the valve has any springs you may look into replacing them, as that is a common problem as well.
DO NOT forget to turn the water off at the main shutoff point, or you're gonna be in for the shower of your life once you take that valve out. You shouldn't need much besides a phillips screwdriver, and possibly an allen wrench and some pliers.
Mar 27, 2009 | Home
Home Logo
160 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
