My scht930 receiver lights red but will not operate
  • RICH COMISKEY Feb 14, 2012
    RED LIGHT GOES ON BUT NOTHING ELSE
Check your speaker position. Be sure you choose the right option. For example choose speaker A or B.
Posted on Feb 14, 2012
My remote is red light is flashing. I changed the batter and the battery in the unit is working. I can turn on the fireplace manually
  • The usual indication for a flashing light is a low battery. Suggest checking the remote again. Especially for corrosion at the battery terminals.
  • When you operate the remote will the receiver flash its LED indicator confirming that the command has been received.
  • The manual operation of the receiver located at the fireplace likely does not require batteries. For remote control operation good batteries are required.
  • If the red LED on the receiver is flashing the batteries need to be replaced.
  • If the LED at the receiver indicated that the command is received check the wires to the control valve from the receiver. The voltage is a very very low a millivolt signal.
Dec 01, 2015 | Heating & Cooling
Why does red light stay on?
The red light provides visual assurance that the freezer is receiving operating power.
Nov 10, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
How to get my garage door to open all the way?
Three blinking lights & door won't close by Candi
(Winston-Salem, NC)
Garage door will not open and close with remotes. Three blinking lights occur when we try to close door. What does this mean? It is a Linear unit.
I will assume you mean that your garage door will open with your remote but will not close. It should close if you press and hold the wall control button until the door is fully closed.
If that is the case, the 3 blinking lights indicate that your garage door's infrared safety beams are not properly aligned.
1) Check that the operator has power. The green lights on the sender and receiver should be lit.
2) If the receiver's green light is on, but the red light is off, the receiver has power but is not detecting the infrared beam from the sender. The red light might flash when the beam is partially detected. This can be caused by
mis-alignment or something blocking the beam.
Adjust the safety beam sender and receiver while watching the receiver's red light (stay out of the beam while aligning it). When the red light stays on, the beam is aligned and your garage door should operate normally.
http://www.linearcorp.com/pdf/manuals/LCO75.pdf
NOTE: If the receiver's red light remains off, check for:
1) Dirt on the receiver's lens,
2) Sunlight shining into the receiver's lens,
3) A short in the safety beam wiring (from staples or at the operator terminals).
Jun 15, 2014 | liftmaster Garage Door 1/2 Hp
Hi,Just purchased 2 antec gain Bluetooth receivers type bxr 100. Operating instructions are not included. Maybe it's just me, but i'm not succeeding in getting them to work. No lights at all when they
Make sure that the unit is fully charged by a micro USB the light on it will be red until it's fully charged put phone in search mode and press the center button until the light flashes red and blue after the phone finds it you should have an option to auto pair when it's not in use it will turn off when paired and working pressing either track button will start the music player then just play with the buttons and see what it does you can stop anything from the phone controls
Mar 18, 2014 | Antec BXR-100 Gry Audio...
The light on the Garage door blinks but doesn't stay on.
(Winston-Salem, NC)
Dec 02, 2013 | liftmaster Garage Door 1/2 Hp
Garage door light blinks but doesn't stay on
(Winston-Salem, NC)
Hello - Our Pioneer vsx-305 display screen doesn't light up anymore and we are unable to get it to work even though the on/off button appears to operating correctly (red standby light comes on). T
It is likely failing due to age.Cold solders fail, corrosion can cut a connection, a capacitor can harden and fail... a myriad of things can happen in time. Repairing it will cost more than an inexpensive replacement. The same receiver can be had on ebay from $60 up (with shipping). It is a cost benefit issue at this point.
Jan 10, 2013 | Pioneer VSX-305 Receiver
The power light blinks red! it can't turn On!
"If your 8002/7002 goes into protective mode (red power light flashing at two times per second) the receiver will not operate until it is reset. First try the reset procedure on the bottom right corner of page 81 in the manual.
If that doesn't work, press and hold the following three buttons on the front panel until the unit resets:
Pure Direct
7.1 Ch input
Clear
This latter procedure is not in the manual and I can't fathom why, as it can save the inconvenience of a trip to the service center."
Feb 03, 2011 | Marantz SR8002 7.1 Channels Receiver
Hello, I have to install a Hunter universal remote receiver, Model 27185 toa Hampton Bay ceiling fan w. light, Model 468-282 today. The receiver has 5 wires, red to light, black to fan, a live black to...
Red from receiver to blue light feed. Black from receiver to black feed to fan. White common from receiver to ground.(bare copper)
Black from receiver (hot) live in, to black from household wiring switch. Common in from receiver to neutral (white ) from house (switch.)
Sep 26, 2010 | Hunter Ceiling Fan Remote Receiver...
Program 2004 mercury mountainer garage opener
Verify the hand-held transmitter is operative.
Prepare for programming the universal transmitter by erasing all three channels (hold down the two outside buttons until the red light begins to flash [20-30 seconds]). Release both buttons.
Select one of the three universal transmitter channels to be programmed by pressing the desired button
Hold the end of the hand-held transmitter 25-51 mm (1-2 in) from the front surface of the universal transmitter so that the red light can still be seen
Use both hands to press the hand-held transmitter button and the desired button on the universal transmitter. Do not release either button.
Hold down both buttons until the red light on the universal transmitter flashes, first slowly and then rapidly. Release both buttons when the rapid flashing begins. The universal transmitter has successfully learned the new frequency signal and can be used in place of the hand-held transmitter(s).
If the hand-held transmitter appears to program the universal transmitter but does not open the garage door, the garage door opener may have a code protected or rolling code feature.
To operate, simply press the appropriate button on the universal transmitter. The red light is on while the signal is being transmitted.
IF THE GARAGE OPENER HAS ROLLING CODES---
program as above then------
Train the garage door opener receiver to recognize the universal transmitter.
Remove the cover panel from the garage door opener receiver.
Locate the training button on the garage door opener receiver. Location and color of the button may vary by garage door opener manufacturer. Refer to the garage door opener instruction manual or owner literature.
Press the training button on the garage door opener receiver for 1-2 seconds.
Press the programmed universal transmitter button for as long as the universal transmitter red light flashes (1-2 seconds). Release the button and re-press the button to confirm that the universal transmitter is trained to the receiver.
The garage door opener should recognize the universal transmitter.
Apr 01, 2009 | 2004 Mercury Mountaineer
18 people viewed this question
 Grubhead
Grubhead
